Question about Orbit Irrigation 57009 WaterMaster Pump Start Relay
Wont stay on when holding switch - Orbit Irrigation 57009 WaterMaster Pump Start Relay
I have a 1987 Heritage softail sport that the turn signals wont stay on by themselves.They will only stay on and blink when when you depress and hold the right or left switch.Is this normal on this bike or...
No, not normal. Could be the switch or the self latching relay (that's what hold the blink function until you cancel it or it times out). I'd start with the relay unless the switch feels different or has been wet etc.
Feb 19, 2015 | Motorcycles
2001 dodge intrepid High beam lights wont stay on unless you hold the handle
HEloo ,
It indicates problem with handle, replce the combinationin switch (Headlight handle) it will solve your problem.
Thanks.
Oct 10, 2014 | 2001 Dodge Intrepid
1999 olds aurora wont run unless hold key in a certain position
sounds like the ignition switch has an internal problem and requires changing.
Apr 03, 2014 | 1999 Oldsmobile Aurora
My daytime running lights work, high beams will come on but switch wont stay on, have to hold it. Low beams do not work and daytime running light dash indicator stays on all the time. Is it a relay or...
if you have to hold the switch so the high beams stay on then that indicates a bad/worn switch,you could have 2 problems the day time running light relay may have a problem with it.i would first replace the headlight switch at the base of the steering colume as by the info you supply its not changing to the high beam side without holding the switch in position.
May 25, 2011 | 1998 Pontiac Sunfire
My dryer WED5820SWD wont stay running unless I hold in the start switch. It happened the other day in the middle of the cycle, also the wrinkle guard stoped working as well. I think that it is the timmer?
Sounds like you have a bad door switch, if it wont stay running and reason for the wrinkle guard not working is the electronic control (circut board) is bad.
Aug 05, 2010 | Whirlpool WED5800S Electric Dryer
I turn my system on and it will not go to media icons
turn off switch on back of ps3 hold down the power switch on front then turn switch on the back on hold the front power switch till you hear 2 beeps then let go
Aug 27, 2009 | Sony Playstation 3 (PS3) Console
Headlights wont come on and bright lights won't stay on hold bright light switch and blower works
I had the same problem. The solution is simple; the ignition switch needs to be replaced. This is an easy do-it-yourself project. Here are instructions:
http://forums.vwvortex.com/zerothread?id=2532481
Check for a switch on ebay, they are about $15. After 10 years they wear out.
Oct 07, 2008 | 1998 Volkswagen Jetta
Orbit Irrigation 57009 WaterMaster Pump Start Relay Logo
29 people viewed this question
Top Orbit Garden Experts
squeely
richie46
Are you an Orbit Garden Expert? Answer questions, earn points and help others
