Question about Orbit Random Sander, 6"
Ryobi random orbit sander won't start - Orbit Random Sander, 6"
Ryobi problems
This is not that bad of a problem we should be able to resolve this-
bring a lamp or radio which ever one you have used and know it works plug it into the wall outlet if your lamp or radio work then we know its the plug, now plug in yr Ryobi random orbital sander it should work to do not involve an extension cord while we are trouble shooting if neither have worked on the same plug you must have a 3 way light switch on the wall that needs to be turned on, try and slightly spread the the metal blades on yr Ryobi outward for a better contact between cord blades and wall plug make sure you have firmly pressed in the the on off switch.
Ryobi tests all of its factory reconditioned power tools before they are sent back to be sold in stores to the public...
Aug 10, 2014 | Ryobi Factory Reconditioned ZRRS290 2.6...
Where can i obtain a sanding pad for a ryobi HRS115K Orbit sander
The 4 1/2" 8 vac hole Hook & Loop back-up pads for the Ryobi Sander are no longer available, But you can apply a new hook surface to your present pad $3.75 each conversion disc at Supergrit abrasives , Gettysburg, PA 800 822-4003
Jul 03, 2014 | Tools & Hardware - Others
Ridgid random orbit sander will not turn on
Mine also, in the middle of a job and it just stopped, no warning , did not slow down or bog just quit.
Apr 26, 2014 | Ridgid R2601 5-Inch Random Orbit Sander
Porter Cable random Orbital Sander (Quicksand) Model 333, Double insulated When sanding, it stops and starts, it sounds as thogh it is stuck and then gets going for a short while
Hi, Sanders are prone to getting lots and lots of dust inside the unit. The cooling fan makes this problem inevitable. The only way to fix this is to take it apart and and blast it with a pressurized air tool. Hopefully this will bring back some life to your sander. The effectiveness of this procedure is dependent on how well you can remove all of the dust. hope this helps.
Nov 16, 2010 | Porter Cable 332K Quicksand Random Orbit...
My 5" random orbit sander model 333 is spinning out of control. What do I do?
I may not have the whole picture, but all random orbits spin wildly if they are not pressed onto the wood a little. Do you mean it is not oscellating, but just spinning when it is on the wood? That would be an issue requiring cleaning or repair, otherwise, just don't turn it on until you have placed it on the wood to avoid marring.
Farmerbear:)
Sep 07, 2010 | Porter Cable Random Orbital Sander, 5"
Orbital sander doesnt orbit!
Never start the Sander without first placing it against the surface to be sanded. In free air the Sander will not osolate.
Jun 12, 2009 | Makita BO5010 5" Random Orbit Sander
Porter Cable Random Orbital Sander rotates but does not "orbit"
Just solved my problem with Porter Cable 333 orbital sander which just groaned. I thought the worst. I carefully took it apart on the garage floor and immediately suspected it needed lubrication as the motor turned hard. I used my flexible long plastic tube lubrication and put some on the bottom bearing shaft the best I could. I worked it around and around. I began to feel it turning easier. I applied more oil and kept moving and it became completely free. I put a drop on the top bearing even though it was loose. I put it all back together and it works like new. Lesson: do not look for the worst when a tool quits. Suspect the culprit to be lack of lubrication!!!
May 20, 2009 | Porter Cable 332K Quicksand Random Orbit...
Orbit Random  Sander, 6" Logo
483 people viewed this question
Top Orbit Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Orbit Air Tool and Compressor Expert? Answer questions, earn points and help others
