Re: Wash cycle has finished still cannot open the door
Try unplugging and plugging back in, give it a couple seconds. If this doesn't work, you can remove the front cover reach up and pull the manual door latch.
Martha, Try running another cycle, for some reason I think machine is sensing it still has water in it. If after running another cycle dose'nt do it, check links below to see (2nd link) how to open door manually with out damaging machine. press the helpful button
reset it
push sound for 10 secs
or
open top
spline screws top back
an reach down to the door latch
bottom of latch t is a small loop for your finger to pull/push it down
you can get to it same way from the bottom front cover
unplug unit
3 spline screws on bottom front washer cover
reach up an pull the loop on latch
good time to clean out the trap since your (t)here.
There is a safety (Anti-Child Entry) switch that is not resetting. First try to reset the machine. This is done by unplugging it from the power source for 30 minutes and then plugging it back in. If that doesn't work you need to Push the Wash Button X 3 seconds to disable it.
Your Maytag
Neptune washing machine displays error codes, also called "help codes,"
to identify specific problems with your washer. Once you close your
Maytag Neptune's door, the machine locks the door, goes through the
selected wash cycles and unlocks the door when the laundry is finished.
Error codes appear when there are problems with the door, the inflow and
drainage of water and the motor.
Do
Your Maytag Neptune washer displays the "do" help code when the washing machine
is trying to start a cycle, but the door is open or not locked
properly. If this message is displayed, close the door securely and
restart the washing cycle.
FL
The "FL" code indicates that the washing machine was unable to
lock the door after you closed it. Open and close the door tightly, then
Sd
The "Sd" code indicates that you have added too much detergent to
the washing machine and your laundry has too many suds. The machine
will stop displaying this code if it has successfully run the suds
recovery cycle, which removes the excess suds from the wash load. If the
code remains, reduce the amount of detergent in the load. Use less
detergent for similar loads of laundry in the future.
PF
The "PF" code indicates that a power failure has occurred.
Restart the wash cycle. If the code still appears, check that the
washing machine is still plugged in to the electrical outlet.
Nd
The "nd" code indicates that your Maytag Neptune is not draining
as it should. Check that the drain hose isn't kinked and that the stand
pipe isn't clogged. If you find either of these problems, fix them
before restarting the washing cycle.
LO
The "LO" code appears when the washing machine has finished the
selected wash cycle, but cannot unlock the door. Verify that the door is
closed properly, push the "Off" button, and wait two minutes. The door
should unlock and the error code will disappear. If the error code
remains, unplug the washing machine, wait two minutes and plug it back
into the electrical outlet.
Lr
The "Lr" code indicates that the washing machine's motor is not
running as it should. Have your Maytag Neptune washing machine serviced
by a certified Maytag repair professional.
f22 is a door lock error try this hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway. If you're getting an F22 error, you will want to check anything to do with the door latch switch.
Try taking the top of the machine off and checking all of the electrical connections, including the one to the door lock. I have to do this about once a month with my machine and it seems to work.
Okay, ther manufacturer recommends unplugging the washer for at least 30 minutes to reset the computer. It could be you have a momentary glitch causing some problems. If you still have the same problem after leaving the washer unplugged, the following link explains the "FH" error code:
If your clothes are stuck inside and you still cannot get them out because the door will not unlock, you will have to use the manual release to open the door. The next link explains how:
michele99, So when you put it on drain, do you here the machine trying to drain the water? After it finishes draining, (you have to wait a few minutes, it should then have a blinking light
on the Finished/Door locked light.
Are you waiting for it to finish?
Press "end of cycle" for over 3 seconds, & wait for 2 minutes to open door. You can then re-start the wash. It is possible you cld hv damaged fhe door switch. For front loaders you do not open the door during a wash, never. Less problems.
