Question about Garden
Gear diagram agrator tiller - Garden
Do you have or can you find Agrator Rototiller Gears ?
Agristore USA ' Replacement Parts ' Agrator Tiller Blades
www.agristoreusa.com/collections/agrator-tiller-blades
Tiller Blade for AGRATOR D-UR $6.75 · Tiller Blade for AGRATOR D-UR $6.75 · TillerBlade for AGRATOR D-UR $8.50 · Tiller Blade for AGRATOR D-UR $8.50.
Sep 25, 2015 | Garden
Thee is no serial or model no. plate on my mtd yard machine tiller. I need a diagram of the gear mechanism, when I split it apart all the gears a nd chain fell out.
Had the same problem with my MTD Yard Machines 5 horse tiller. I called MTD at 800-800-7310 and with the model and serial and such off the engine - which are stamped into it - a nice lady was able to narrow down my tiller year. From there with horsepower details she narrowed further to one of two models that I could look up on the MTD corporate home page and get a schematic.
Hope that helps.
Jun 17, 2010 | Mtd Products Yard Machines 158CC Tiller
I have a Ariens tiller model #901001. The rear
YOUR PROBABLY HAVE A GEAR CHEWED UP?CONTACT CHOOCHOOPARTS.COM FOR DIAGRAM? DID YOU CHECK OIL...IF OUT OF OIL IN REAR TINE TRANSM ...YOU CHEWED UP THE BRASS GEAR ....I REBUILT MY MAIN TRANSM...EASY TO WORK ON...AWESOME MACHINES.
May 04, 2010 | Garden
Put tiller in till gear, goes fine for 30 sec and jump out of gear. tine stop. How do i fix it
Try adjusting the linkage or the shifter cable. If its too tight that will happen. I have almost the same one you do. Look at your manual and check out the blow up diagram. there is a way to adjust most models. If not you may need to replace the cable. But...before you do that make sure your cable isn't meeting with resistance somewhere causing it to be too tight.
May 04, 2010 | Craftsman 8.50 Torque Rating Rear Tine...
How much gear oil 72'' tiller
In Gearboxes use gear oil (type GL5-85W 140 or Triple Zero
Grease; which can be poured, and has "EP" i.e. "Extreme Pressure" additives.) Fill the gearbox to approximately half-full level.
Apr 09, 2010 | King Kutter II Gear Driven Rotary Tiller...
Gear installation for tiller
try PartsTreeRepairClinic they may hgave a video
Jun 16, 2017 | Craftsman Garden
Stateman Tiller tine not engaging
Sounds like the worm gears are worn to the point they will not engage.
Feb 20, 2009 | Craftsman Rear Mount Tiller
Garden Logo
47 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
