Question about Whirlpool GD5SHAX Side by Side Refrigerator
Whirlpool Ice Maker won't fill
Whirlpool GD5SHAXKQ00 side by side Refridge with built in icemaker, infrared sensor, not wire type..
Icemaker tray won't fill.
Checked that water is on. Unplugged, and turned water off. Checked solenoid at bottom left side - has 190 ohms of resistance. turned water back on. Turned power back on. Little red light flashes on momentarily and then off for what seems like an inordinate amount of time. Never did see it come on again. Heard solenoid operate but only for about 1 second. (Could have been the solenoid for the in-door water dispenser). Heard a second solenoid (slightly different sound) but again it only operated about 1 second. The water line seems to run between the refridge and freezer walls. Might be frozen but I have no idea how I would defrost it being between the two walls.
What is my next step. Is that little red light supposed to stay on or does it flash only intermittendly. Being infrared I'm suprised I can even see it.
Is their a troubleshooting guide?
gwshaw71
  • 83 Answers
SOURCE: Whirlpool icemaker
Your unit has infered sensors on the frezzer left and right walls. There is a diagnostic test sheet brown in color in your kick plate.All you have to do is open frezzer door look on the right sensor it should blink twice followed by a 1-2 sec delay,if that is good press in flapper door on right sensor do not block path of infered beam you will not see a beam its invisable.Once you hold in flapper on right sensor the led should be solid.If solid optics are good if not solid led replace optic sensors
Posted on Feb 15, 2009
  • 163 Answers
SOURCE: Icemaker not working,water pours from dispenser side
it could be water valve or ice maker that has gone bad.check all connectins to icemaker and tubing to icemaker and water valve.
Posted on Mar 20, 2009
  • 531 Answers
SOURCE: Top shelf of freezer is warm. Icemaker not working.
check your defrost
Posted on Apr 01, 2009
ginko
  • 19396 Answers
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 22, 2009
MNfisherman
  • 11896 Answers
SOURCE: no water comes out of ice and water dispenser.
Either the inlet filter is plugged, or the valve is not opening. You will have to trace the water line to access these.
Posted on Jul 06, 2009
I have a Whirlpool refrigerator with an ice maker and when the icemaker is filling with water it leaks from the front of the tray into the ice storage bin.
1. icemaker is not level. (check and re-level)
2. icemaker has a crack in the mold.(replace i/m)
3. Water level set too high.(remove front cover and adjust water level screw counterclockwise)
Feb 23, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Whirlpool refrige. side by side and the ice maker has stopped working. The infrared light keeps blinking. I have unplugged it a couple of times as well as turned the infrared off. Any advice?
The laser , is supposed to blink . This laser , tells the icemaker to stop making ice , when the bin is full . Pour about 2/3 cup of water into the icemaker . If it doesn't dump the cubes into the bin , the icemaker is bad . Or , if there is ice in the bin , which hasn't dumped , the icemaker is bad . If the icemaker dumps the ice ( from water pour ) , then look above the fill cup , and see if the black fill tube is frozen . If so , then replace the water valve and turn the freezer temp down slightly . It will take several days for this fill line inside freezer to thaw . If icemaker dumps , and black tube NOT frozen , replace the water valve . The valve , is where the wall water line connects to on the refrig
Sep 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The laser , is supposed to blink . This laser , tells the icemaker to stop making ice , when the bin is full . Pour about 2/3 cup of water into the icemaker . If it doesn't dump the cubes into the bin , the icemaker is bad . Or , if there is ice in the bin , which hasn't dumped , the icemaker is bad . If the icemaker dumps the ice ( from water pour ) , then look above the fill cup , and see if the black fill tube is frozen . If so , then replace the water valve and turn the freezer temp down slightly . It will take several days for this fill line inside freezer to thaw . If icemaker dumps , and black tube NOT frozen , replace the water valve . The valve , is where the wall water line connects to on the refrig .
Sep 05, 2009 | Whirlpool Refrigerators
Side by Side refrig. ice maker has water in tray but does not dispense ice.
Check to see if the coils under refridge are clean . If they are , replace the icemaker . An icemaker has to be 5 degrees to dump the cubes . Dirty coils can raise the temperature to 6 or even higher , therfore the icemaker will make ice , but not dump them .
Aug 26, 2009 | Whirlpool Refrigerators
I have a whirlpool refg. with built-in ice maker model# ED25DQXDW02. Everytime the frig. goes to fill the tray it fills it then over flows some. Is this a problem I can fix myself.
probably have to replace the icemaker take it out and look at the mold and see if you have some teflon coating that has come of and or some water deposit buildup under im on heater on bottom of icemaker. this causes it to let the water drip down on the back of im an causes iceblock in the dispenser bucker. you can order an icemaker 1- 877-262-1479
May 27, 2009 | Freezers
Icemaker not producing ice
you need to troubleshoot the problem, if the wire arm that tells the ice maker to stop making ice when full is in the upright position the ice maker will not make ice. the problem has to be either the switch on this arm malfunction. but probably in MOST cases it is your electronic water valve which has gone out. this is located on the water supply line on the back of the fridge at the bottom probably behind some cardboard or plastic. it is the same kind of water valve as a dishwasher uses, if it malfunctions it will not deliver water to your tray, manually fill the tray and put the arm down, if the maker dispenses the ice out of the tray, chances are your electronic valve is broken.
Apr 07, 2009 | Whirlpool ED2FHEXN Side by Side...
Mar 20, 2009 | Whirlpool Gold Black-on-Black 25.4 cu. ft....
Icemaker does not make ice after first harvest.
theres whats called a cam inside of the ice maker and that is more than like;ly the problem. you can but your own ice maker from place like first service. good luck.
Jan 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool GD5SHAX Side by Side Refrigerator Logo
223 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
