Question about HP LaserJet 6L Printer
Hp 6l will not feed paper - HP LaserJet 6L Printer
vijay
  • 27 Answers
SOURCE: HP laserjet 6L
Get it cleaned in paper sensor area and check up the drivers as well as data cable which connects, the pc and printer. Change the data cable if necessary. Give me feedback so that may be some more help can be provided.
Posted on Mar 12, 2007
SOURCE: Driver for HP Laserjet 6L Pro
Your problem could be either due to the malfunctioning of the driver or you may have installed a wrong printer's driver.
This can be rectified by reinstalling the printer;s driver. Please find the proper driver in the following link.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=21878&prodTypeId=18972&prodSeriesId=27724&swLang=8&taskId=135&swEnvOID=228
~regards,
Jegan
Posted on Jun 03, 2009
  • 1684 Answers
SOURCE: paper feed feeds more than 1 sheet at a time
he problem you are having is caused by a worm separation pad assembly. This assembly is what separates the paper into individual sheets. It takes about 30 minutes to disassemble the printer and replace the part. Most printer repair shops will do the repair for you but the cost may be a bit much. If you are interested in doing the repair yourself we do stock the part. We can provide the separation assembly and a service manual on CD that gives directions for replacing the parts plus other information about the printer. The part and guide runs $14.95 plus shipping. Let me know if you need one, tech
Posted on Apr 27, 2010
  • 270 Answers
SOURCE: I have a HP Laserjet
Take the cartridge out. Flip the release lever on the left side of the printer. Then grab the black plastic shaft above the fuser assembly and turn it with your fingers. The piece of paper should exit. You can turn it either way, it won't hurt the machine as long as you don't force it.
Posted on Nov 17, 2010
vinay229229
  • 1121 Answers
SOURCE: Hi, I have a HP
One thing pl understand this is old printer, while handling you should be carefully, parts are became delicate because of old age.check that paper pick up roller surface got smoothness or dirty, first clean with wet cloth surface of the roller & check, even its not picking up replace both pickup roller & separation pad.best of luck..Vinay.
Posted on Sep 05, 2011
HP Laser 6L - Printer makes a squealing noise but does not advance the paper to complete the print.
Old age printer, it needs to replace feed roller assm,pick up roller & separation pad to avoid pickup issues.must be replace these item at a time to avoid tension.
Sep 23, 2011 | HP LaserJet 6L Printer
HP Laserjet 6L Dark Printing
Check your Toner, and also the thermal roller of the printer..
Thank you
May 29, 2008 | HP LaserJet 6L Printer
Hi, I have a HP Laserjet 6L. I recently made the mistake of pulling a paper jam out incorrectly, I pulled the paper out from the paper feed tray rather than pulling it out from inside once the toner...
Sep 05, 2011 | HP LaserJet 6L Printer
Paper feed feeds more than 1 sheet at a time
Apr 26, 2010 | HP LaserJet 6L Printer
Paper jam on lowest roller of paper feed path cannot find a way to release roller as paper held so tight all prutruding has torn off
Hi there
Just try turning the rollers by han till you clean all out, if the roller is damaged then it not any use it will not print right again, you may need get a new one.
All The Best Pineworks
Mar 04, 2010 | HP LaserJet 6L Printer
Canon faxphone L80 parts available? paper feed shaft broke in half
The L80 printer guts are very similar to the HP 5L and HP 6L printer (Not well known, but the printing engines on many HP printers are made by Canon). In fact it is almost possible to use a 5L/6L toner cartridge in the L80, but as I recall there was a plastic nub that prevented it from fitting properly. This is probably meant to force the user to buy more expensive Canon toner carts instead of using cheaper generics for the 5L/6L. Try HP PartSurfer and you may be able to locate the part that you need.
http://www.partsurfer.hp.com/cgi-bin/spi/main
Jul 29, 2009 | Canon FAXPHONE L80 Laser
Multiple paper feed with 5L
You need a separation pad kit for your machine. The parts are relatively inexpensive. There are 2 ways to accomplish the fix. You can install a separation pad overlay kit which can be done without disassembly which is simply adding a peice of rubber over the existing pad or a complete roller & pad kit which requires disassembly of the machine. The easiest is the overlay however best and longest fix is the full kit replacement. Here's a link to each of the kits off of ebay.
Overlay Kit: (5 minute install) Approx. $10.00
http://cgi.ebay.com/HP-Laserjet-5L-6L-3100-3150-Jam-Repair-Kit-Feed-Fix_W0QQitemZ230300272758QQcmdZViewItem?hash=item230300272758&_trkparms=72%3A1205%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14
Full Feed Replacement Kit: (30 minute disassembly required) Approx. $25.00
http://cgi.ebay.com/HP-LASERJET-5L-6L-3100-FEED-JAM-REPAIR-KIT-VIDEO-8-PCS_W0QQitemZ120319146203QQcmdZViewItem?hash=item120319146203&_trkparms=72%3A1205%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14
Here's a link to a fre service manual for the machine just in case you get into difficulties:
http://www.feedroller.com/Store/Service%20Manual/LASERJET%205L,%206L,%206L%20Gold,%206L%20Pro%20Service%20Manual.pdf
Hope that helps you. If so please rate me with a FIXYA!
Oct 19, 2008 | HP Office Equipment & Supplies
Printer feeds all the paper
The separation pad is worn out. Go to printerworks to get the parts
Feb 22, 2008 | HP LaserJet 6L Printer
HP laserjet 6L
Mar 12, 2007 | HP LaserJet 6L Printer
HP LaserJet 6L Printer Logo
27 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
