Question about Vehicle Parts & Accessories
My 2008 mercedes s 550 hand brake spring get loose how can i fix it
Rear left brake spring get loose out off its poticion
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 48 Answers
BUY A BMW
Posted on Dec 04, 2014
My 2008 mercedes ml550 power lift gate has quit working and all lights on rear of vehicle quit working, turn signals, 3rd brake light, reverse lights, rear camera. On occasion all work ok
You should check the rear sam control unit.It is located in the right hand side of the trunk.remove the panel and you will see a fuse block.look directly below it.that is where the rear sam is located.remove the connectors and check for corrosion.this is a very common problem.the rear sam will need to be coded so take it to a reputable repair facility.
Dec 12, 2016 | 2008 Mercedes-Benz Mercedes Benz Ml Class
On Mercedes Actros 1841 (2008 year of manufacturing) parking brake light blinking (on and off) even parking brake is not applied and truck is driven. What will be problem and solution?
check for loose connections or wire grounding out near the park brake switch
as it should be air controlled spring brakes for the park brakes check for a problem air switch in the park brake air lines
Oct 21, 2016 | Mercedes-Benz Cars & Trucks
How to adjust the brake parking cable on a 2008 mercedes benz gl450
www.ask.com/
www.wikipedia.org/
www.infolinks.com/
/2008 mercedes benz gl450 parking brake adjustment procedures
OR look
www.youtube.com/parking brake adjustment for 2008 mercedes benz gl450
Apr 22, 2015 | Cars & Trucks
How to replace left front parking lamp on 2008 Mercedes S 550
This video is for another model but I believe it is a good guide to the procedure.
follow the link
https://www.youtube.com/watch?v=D9LiaRugcjQ
Feb 20, 2015 | 2008 Mercedes-Benz S 550
2009 Mercedes-benz CLS 550 fuse locations
under the bonnet thats where merc has fuse boxes
Jan 01, 2014 | 2007-2010 MERCEDES BENZ CLS 550 CLS550...
Pug 206 t reg handbrake locks on left hand side rear wheel any ideas how to fix this or how a can cut handbrake cable
sorry friend , but im not an expert. ANYWAY, I SAW YOUR CALL! cutting a hand brake cable is a nonsense and worse, a big danger. This back wheel is permanently sttoped or braked because the spring mechanism that bring them to free wheel is stucked. the springs can no longer pull the braking system to the home position. The solution is disassembly the back wheel drum, clean it , replace the springs ( if the foot brake, an independent system ) is working ok.this is only the basic procedure. Check also if the cable in the back ( divided in two for separate back wheels ) is not "dry" out of lubricating!
Dec 26, 2012 | Cars & Trucks
Rear wheel locked
Rear wheels brakes they have to be clean because the brake shoes debris look the drums all so hand brakes at list 3 click before to lock the hand brakes wheels.
Sep 20, 2012 | 1993 Mercedes-Benz Mercedes Benz 300 Class
2008 Suzuki GSX650F rear brake light doesnt come on only the fron
its the rear brake light switch thats not working it could just be stuck in,,,the switch is near the foot brake leaver
Feb 06, 2010 | 2008 Suzuki GSX-R 600
Shimano Dura Ace Brake lever chatter
A few suggestions:
Lube/replace your cables and housings. If your housings are getting rusty on the inside, it will prevent the tension in the spring of the calipers from returning the brake levers to "home" position. Also, dura-ace levers have an internal return spring that is prone to breaking or coming off its peg (this can't be repaired without disassembling the lever).
Make sure your calipers are clean and move freely, and have sufficient spring tension to return to "home" position.
Be careful not to get lubricant on the braking surfaces, obviously.
As an experiment, remove the wheel and pinch the calipers together with your hands. Then, check to see how loose the brake lever is.
Mar 26, 2009 | Shimano 2008 Dura-Ace BR7800 Rear Road...
Vehicle Parts & Accessories Logo
35 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
