Question about Canon S200 InkJet Printer
I am using canon S200SPx...from the last week,nothing is getting printed on the paper.i have changed the catridge...but it is of no use..
  • sharu_k31 Jun 20, 2009
    i have changed the catridge, cleaned the print head..but no use
  • 31 Answers
If the ink is already empty u need to replace but if not, u said that in dried in the printerhead u need only to clean with alcohol by using cotton or cloth cotton type cause sometimes ink are only block by the dried ink
Posted on Jun 20, 2009
    President:
  • 2,306 Answers
Ink is dried in the printhead, replacement is best, qy6-0038-000, around $24.00.
Posted on Jun 19, 2009
I have changed my black and COLOR CARTRIDGES AND THEN I TRIED TO PRINT SOME THINGS and a screen popped up ann said TO PULL THE JAMMED PAPER OUT AN I DID BUT YOU CAN SEE WERE A LITTLE IS STILL IN THERE...
First remove all the catridges from the printer and use a low pressure air blower and flush out the papper and also check for any peice leftover then insert the catridge and switchon while doing thes remove the power from the printer
Sep 04, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Canon JX 210 P Ink Level reset?
its not recommended to refill the cartridges as it causes problems!It recommend getting a geniune cart!
Apr 05, 2010 | Canon FaxPhone B95 Plain Paper Inkjet
My MF8180C Printer/Scanner has an error I can't fix
Remove the entire catridge, close it and turn it on. It will complain of no catridge. Turn it off, insert the catridge and turn on. This should work.
Also, make sure your paper is not cold, you can heat paper up before using in future.
Regards
Sep 15, 2009 | Canon MF8180C Color Laser MFC Printer
Will only print in blue ink
most likely you are out of ink other than blue, try to refill the other colors or get new cartridges.
Mar 26, 2009 | Canon Office Equipment & Supplies
Color not coming out right when printed
In this case what i would request u to do is....... Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be  dry...........
Take the Colour catridge first turn it upside down and u will see a small copper plate on the  catridge from where the ink comes out.......
Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10  Seconds......
Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same  way........
Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a  Copper plate on it with small boxes just clean that copper plate with the Dry Paper
Towel..........
Know insert both the catridges inside the Printer... Good Luck
Jan 28, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Canon S200SPx
I cannot print. it is showing service error 5600. What is the solution
Nov 06, 2008 | Canon S200X Ink-Jet InkJet Printer
Power for Canon Printer S200spx
my Canon S200spx, had a problem. become a line when i print my doc. all my doc become messy and dirty....
Aug 04, 2008 | Canon Pixma MP500 All-In-One InkJet...
Lines when I print on photo paper
this is usaually because of print catridge,before that u check in driver properties that the print quality is set on best or picture mode,even if the results are same just clean the contacts points behind the catridge,on the assy on which the catridge is getting fixed.or replace the catridge at last
Jan 17, 2008 | HP PSC 1315 All-In-One InkJet Printer
Not getting the black
Strongly suggest you use canon cartridges - have found all others to be rubbish
Dec 24, 2007 | Canon PIXMA iP1600 Printer
Canon S200 InkJet Printer Logo
144 people viewed this question
old marine
old marine
