Question about GE JVM1190 Microwave Oven
Trying to replace fuse
Our microwave suddenly stopped working and we think we blew a fuse and would like to change the fuse to see if that was the problem
jsrock516
  • 5911 Answers
SOURCE: GE JVM1440 Spacesaver Microwave
You can fix it without the aid of a repairman. Simply unplug the microwave and remove the outer casing. There should be a few screws around the bottom edge and back panel. Once you have the unit open, look for where the power cord comes in. There should be a circuit board with a fuse mounted to it. This is your input line filter. The fuse should be a 20 amp appliance fuse that you can pick up at any hardware store (Lowe's and Home Depot both carry them). DO NOT op test with the outer casing removed. Potentials of about 14,000 volts are present in the high voltage network of a microwave oven. Close the unit up BEFORE you power it back up. Let me know if this helps.
Posted on Aug 11, 2007
  • 574 Answers
SOURCE: Advantium microwave won't stop.
If it runs when the door is open it's a bad interlock assembly
Posted on Aug 31, 2009
Testimonial: "Thanks for taking the time to reply."
  • 4 Answers
SOURCE: convection microwave oven suddenly stopped
If there is no power to the unit at all, no lights, no nothing, but there is power at the outlet, then you are most likely going to need a new board. the Electronic control board controls everythign on that unit. I woudl call GE direct for service, adn depending how old it is they may be willing to give a parts and or parts & labor concession - they are usually pretty good about that kinda stuff.
Posted on Nov 02, 2009
  • 9 Answers
SOURCE: stopped work when open microwave door no power now
I finally was able to fix similar problem. The "primary" door switch (top switch) had a burned contact inside the switch body, as well as burned surrounding plastic. It would no longer "click" and tended to stay in "closed" position. [The switch is a "normally open" design (NO).] When this occurs and the door is opened, the "monitor" switch causes the fuse to blow out. GE wants $50 for this part. However, I was able to find a universal design of microswitch at Fry's Electronics. It had the same rating (15 amp at 250 volts), same body size, both NO and NC terminals, but with a lever arm which I had to remove by opening the case. Cost was $2.47 + tax. (PRICELESS!). So far so good. I also had to buy a set of Torx driver bits for tamperproof screws to be able to remove the oven cover. (The hole in the end of the bit goes over the tamperproof pin of the screw).
I also viewed a YouTube video which was helpful at http://www.youtube.com/watch?v=YsWTCnACqdY
Posted on Nov 18, 2010
tbirdfan1
  • 3051 Answers
SOURCE: My microwave suddenly has no power, clock etc. I
Hello there and thank you for choosing fixya:
This is a very common issue with microwaves
Yes you are right it does indeed have a fuse inside of it
you first need to unplug it of course then take out all of the screws that are along the outer edge on the back there may be 4 or 6 ok next there are 3 or 4 screws that are on the sides that need to be removed ten if you take a small flat tip screw driver and insert it in the seam at the top towards the front you should be able to slide the cover back about 1 to 2 inches then it will lift up and slide off
Next if you look towards the front on the same side as the power panel yuwill see a electronic board it has the fuse on it it looks like this picture i have below simply remove the fuse and replace it WITH THE EXACT TYPE OF FUSE OK
then plug it in and ensure every thing is working if so great go ahead and unplugit again and put the cover back on ok but if not please post me back so i can continue the troubleshooting from there ok ? here is the pict
Best regards mike
Posted on Mar 04, 2011
My oven was working and it stopped suddenly. Now I cannot turn it on.
Sounds like internal fuse blew inside of microwave
Sep 10, 2017 | Microwave Ovens
I have a samsung microwave model # smh1816s working fine all of sudden stop working no power is there a fuze if so where
They do have a fuse. They also have thermal cutoffs and possibly a thermal flame sensor fuse. the main fuse would be near the control panel the thermal flame sensor is usually near the back of the cavity usually on the left side on the outside of the cavity.
Nov 13, 2014 | Microwave Ovens
My microwave stopped working all of a sudden. Heard a pop sound and it stopped.
Could be a capacitor or a diode and I imagine the fuse blew too.
Does the clock work? If not the fuse has blown. You have to take off the cover. Take the screws out of the back and sides and pull backwards on the cover until it comes off then there should be a fuse in a holder near where the power cord comes in. Don't forget to unplug the unit. Some microwaves have the fuse in a plastic holder right in the wire. the fuse will look like a small tube with metal ends and only replace with the same type of fuse, about 15 amps. the amps will be on the fuse, look close on the metal ends.Put in new fuse and try again if it blows again you need to have someone with experience look at it.
Oct 13, 2014 | Sharp Microwave Ovens
Glmv169gsb stopped working
You blew the fuse on the control board. Unplug it, remove the cover to expose the guts, and you should see a fuse. Replace it and try again. If it blows again, then you will likely find it cheaper to get a new microwave than have the control board replaced.
Nov 13, 2013 | Frigidaire GLMV169D Microwave Oven
Whirlpool Microwave (model WMH1164XVS-1 ) does not turn on
This could be a lot of things. IT might be a capacitor or diode. MY money is on the capacitor. Since it works for a minute before it quits.
May 06, 2013 | Microwave Ovens
Viking Microwave Model VMOC205SS little over 4
9 amps is approx. correct. Does magnatron make an odd sound when running? If not, you will need to discharge cap then clean terminals with alcahol. Replace diode as well. Should run correctly.If blows again, replace magnatron. Suggest you put a 12 amp fast blow fuse in circuit and nor a 20 fuse.If you dont have a grill or an oven, use a 10 amp fuse.
Sep 17, 2009 | Viking VMOC205SS Microwave Oven
Microwave just died
The Microwave should be on a different circuit than the fridge. If the fridge kicks on at the same time you have the microwave on high you can damage them with low voltage causing high amperage and blowing the fuse, try replacing the microwave fuse and try to run it off a circuit that the fridge is not on, New hoses have a dedicated plug for just the microwave oven, I own a 1.4 cubic foot oven and it had to have it's own plug due to the breaker size and wire size, it pulled to much power to be on that circuit. So change the fuse if that does not work and post here and will see what else to check, and please rate if this helps.
Aug 08, 2009 | Hotpoint RVM1435 Microwave Oven
Goldstar MIcrowave stopped working when light bulb blew out.
when that happen to me i change the bulb and the fuse in of the microwave f the don't work send it to the company that made it and they should tell what wrong.
Mar 11, 2009 | Goldstar MV-1501 Microwave Oven
GE JVM1190 Microwave Oven Logo
131 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
