Question about Ovens
Neff b1442 oven thermostat not kicking in? - Ovens
barkencoa
  • 3463 Answers
SOURCE: Neff U1422 oven overheating
Hi
Yes it does sound like faulty thermostat.
You will have to remove the oven from the oven housing, and remove the top cover, and possibly the front console.
Then you will have trace the sensor back to the main oven, and unfasten sensor in oven
You will probably have to remove the rear
panel as well to get the thermostat sensor out.
One other possibility is the sensor may have become detached inside the oven, this will then affect the oven temp.
Good luck
Hope this will prove helpful.
Posted on Nov 22, 2008
SOURCE: Neff U1410 main oven trips the main RCD. Occurs
I have a u1421 with the same problem! I notice the fan doesnt run too well, sometimes it doesnt run at all, needs a prod to get it running. I suspect with no fan, that the element gets far too hot, and then starts to leak to earth, tripping the RCD. I'm gonna try buying a new fan motor - you should ckeck if your fan is running full speed OK.
Posted on Nov 02, 2009
  • 41 Answers
SOURCE: How do I replace the lightbulb. NEFF B1442 series 3 Oven
1. Some glass covers are held on with a wire clip over them. It should be visible.
2. Some have a 'ring' which is screwed to the oven cavity around the light cover. On that design the screws need to be removed from the surrounding retaining ring.
3. On may later model the glass light cover screws into place. Those covers should 9hopefully) be able to be unscrewed the same you you'd remove a jar lid.
Posted on Nov 07, 2009
2coolrick
  • 560 Answers
SOURCE: Neff oven not heating have replaced fan element
it has to be the temperature control itself...thats the only other component, aside from the high-heat cut out switch which rarely goes bad.
Posted on Jun 05, 2010
barkencoa
  • 3463 Answers
SOURCE: Neff double oven u1442, main oven thermostat light
If the oven is heating up o/k, then I would suggest that the oven pilot bulb has failed, I have come across this on several occasions, it usually just means replacing the oven pilot light.
Posted on Mar 18, 2011
Testimonial: "Thank you barkensoa, is the bulb easy to replace?"
HOW DO YOU REMOVE CONTROL KNOBS TO REPLACE THE ON THE NEFF B1451 OVEN
I have a Neff B1451 oven and have removed the thermostat knob just by pulling and wiggling it. Thats all you do. If then you want to rpelace the thermostat, there are two screws holding the unit onto the oven which are accessed by taking the silver metal shrouds off first.
Jun 24, 2011 | Neff B1432 Single circotherm plus Electric...
Neff double oven u1442, main oven thermostat light does not work even though oven heats up. Is there a fix?
Mar 18, 2011 | Neff U1452 Double circotherm plus Electric...
Jun 05, 2010 | Neff U1721 Double circotherm Electric Oven
The bottom (fan oven) of my Neff U1721 made soft bang noise and failed. The fan stopped, the oven light went out and the thermostat light. I replaced the burnt out heating with a new element with a 32.5...
The power to the fan and thermostat is the fault. You will need to trace wiring from these elements to power source and I suspect that where the power cord meets the oven is where you'll find the cause.
Dec 15, 2009 | Neff U1721 Double circotherm Electric Oven
Nov 07, 2009 | Ovens
Neff u1421 bottom oven fan is working t/stat
Can only be either element or thermostat. I suggest you check element and connections
Aug 26, 2009 | Neff U1421 Double circotherm Electric Oven
Neff B1442 Oven -- Defective timer and clock
Hi.
Is it flashing AUTO, If it is and you can'y reset it back to manual, then you have faulty timer.
Hope this helps
Nov 25, 2008 | Neff U1661 Double circotherm super...
Hi
Good luck
Nov 22, 2008 | Neff U1421 Double circotherm Electric Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
