Question about Harman Kardon HS 200 Theater System
Crash The system stops again and again
Firefox crase every 15 minuts plz fix 4 us
Mozilla's Firefox Internet browser is one of the most popular browsers in the world, second only to Microsoft's Internet Explorer.
As of April 2011, Firefox held a 21.63 percent share of the worldwide browser market. Unfortunately, problems with plug-ins, websites and general operating system incompatibility occasionally cause Firefox to become unstable and crash.
To prevent these crashes from occurring again, the cause of the crash needs to be identified so an effective fix can be implemented.
Take note of the action or circumstance that lead to the crash.
Pay particular attention to the timing of the crash and whether it occurred while launching Firefox, when trying to view a specific website, when attempting to download a file or at a seemingly random time.
Repeat the action that caused the crash to see whether it causes Firefox to crash again. Some crashes are caused by memory problems or other external factors and may be a one-time occurrence.
Repeating the action determines whether the crash was caused by errors within Firefox or if there were other factors involved.
Hold the "Shift" key down on your keyboard and relaunch Firefox.
This will launch the application in "Safe Mode," disabling all plug-ins and themes.
Repeat the action that caused the crash; if the problem was caused by a plug-in or theme then the crash will not occur this time.
Open a new Firefox tab and type "about:crashes" without the quotation marks into the navigation bar.
Press "Enter" to load the Firefox crash log listing.
Select the most recent entry and scroll through it to find the name of the plug-in, theme or other component that caused the crash.
Disable or update the component to remove the cause of the crash.
This information should be contained in the "Details>Signature" or "Details>Crash Reason" sections.
Open the Tools menu in Firefox and select "Add-ons" if you cannot resolve the crash problem by disabling or updating a plug in.
Scroll through the list of installed browser add ons, disabling add ons one at a time in an attempt to correct the error.
If the crash occurs when trying to view certain types of content, such as streaming video or other media files, focus in disabling add-ons that are related to that type of content.
Open the Help menu and select the "Troubleshooting Information" option if crashes occur only when attempting to download files.
Locate the "Application Basics" entry, then click the "Open Containing Folder" link to open the folder containing your Firefox profile.
Exit Firefox, then select the "downloads.sqlite" file in your profile folder and delete it.
This removes your download history, eliminating any problems with the file and allowing Firefox to create a new file when it launches again.
Update Firefox.
Some crashes are caused by problems within the Firefox program itself, such as problems with specific operating systems or crashes that occur only in new Firefox releases.
Updates may contain fixes to these Firefox crashes, eliminating the crash problem once the browser update is installed.
Nov 19, 2013 | Computers & Internet
I have a 2010 nissan altima and the airbags had deployed. i have since had the airbags replaced and now the vehicle will not start. can u please help me?
If the air bags deployed, the system thinks there was a collision, Check your fuel pump crash sensor. This system stops the fuel pump in the event of a crash...
Mar 16, 2011 | 2010 Nissan Altima
Blue screen appears at start up boot screen and restarts again
press "F8" while statrting , and then select "safe mode"
Feb 01, 2011 | Computers & Internet
My laptop always crash and the only way to recover it is to re format it.i already do almost everything like change the hardrive.memory.it willrun for a few days and then crash again.we thought at first...
Hello.
This is a tough one.
My first thought is that if you reformat your laptop and it crashes, sounds like a hardware (most common: memory or hard drive) problem.
But, you've tested / replaced the memory and the hard drive. Be certain that you have the correct memory for this laptop. Also, run hardware diagnostics.
When you reformat, don't add anything. Just the operating system. Boot it and test for awhile to see if the operating system is stable. Then, add software one at a time and test each time. It may be a long process, but it's possible that your software may be infecting your system.
Hope this helps.
Jul 11, 2010 | Computers & Internet
B1231 crash detected lgogitudinal Accelaration
I would assume the acceleration sensor, (probably a mercury tilt switch), is improperly mounted. It has to be perfectly vertical.
Jun 08, 2010 | 2007 Mazda 3
Tested only the motherboard it stops with the acer logo screen,not booting further
Your Operating system is crash,.you need to reinstall it again to make it work!!
Feb 22, 2010 | Acer ASPIRE T180-UA381B DESKTOP PC
Hi new renault twingo thats had crash, air bags gone off wont start is there a saftey system that stops starting
there is a built in airbag electronic control unit that disables the car in a crash so you need to replace this aswel as the airbags
Nov 07, 2009 | Audio Players & Recorders
Crash!!
Could be Heat, sounds like the system is shutting down to protect the processor. Let it sit shut down over night and see if it runs longer when it's cooled down. Is the fan running?
Aug 29, 2008 | Acer Aspire 5315 Notebook
Acer 5050 crash problem.
It is highly unlikely its a crash......two operating systems cannot....CANNOT crash similtaneously. Its impossible! unless the hard drive you run both on is faulty BUT you wouldnt get Windows to load. Not even for a bit....you say all lights will stay if they were lit up but they some how dont stay on.........I think thats what you mean.........then you say you checked again and there were rectangles that look like a book that stopped blinking yet the power lite stayed on....Im at a lost But I dont think its a crash......only software crash it might be a hardware pronlem....
Sep 12, 2007 | Acer Aspire 5050-3242 Notebook
Harman Kardon HS 200 Theater System Logo
24 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
