Question about Xerox WorkCentre 6015NI
CRUM ID 093-962 - Xerox WorkCentre 6015NI
F2 ERROR
F2 04 Content Improper cartridge (Destination error, life cycle
error)
Detail The destination of the machine differs from that
of the CRUM.
The life cycle information is other than "Not
used (FFh)."
Cause CRUM chip defect
Improper developing unit
Check
and
remedy
Replace the CRUM chip.
Replace the developing unit.
Identificat
ion error
The trade mark code of the CRUM differs.
The company code of the CRUM differs.
Model
error
The boot program model code does not
coincide with the CRUM model code.
Type error When the CRUM type is other than genuine/
conversion/production rotation.
Destinatio
n error
The machine destination differs from the
CRUM destination.
Data
abnormali
ty
When an error value is included in the initial
check information. When the max. toner supply
time is 00.
When the print hard stop is 00.
Misc error When the Misc information is other than "Not
used (FFh)
Feb 10, 2014 | Sharp AR-5316 Advanced Digital Imager...
Solution for f2 error code
F2 - 04 : Improper cartridge (Destination error, life cycle error)
Detail : The destination of the machine differs from that of the CRUM.
The life cycle information is other than "Not used (FFh)."
Cause : CRUM chip defect - Improper developing unit
Check and remedy : Replace the CRUM chip - Replace the developing unit.
Identificat ion error : The trade mark code of the CRUM differs.
Model error : The boot program model code does not coincide with the CRUM model code.
Type error : When the CRUM type is other than genuine/conversion/production rotation .
Destination error : The machine destination differs from the CRUM destination.
Data abnormality : When an error value is included in the initial
check information. When the max. toner supply time is 00.
Misc error : When the Misc information is other than "Not used (FFh)."
Oct 20, 2012 | Sharp AR-M160 Laser Printer
Crum id 093-960 what does itmean
This is happening with my XEROX workcentre 6015B. The error message says: ID de CRUM 093-960 Restaurar cartucho amarelo (replace yellow cartridge, which I've done)
Feb 14, 2012 | Dell 5110cn Laser Printer
Error U2-40 Call for Service
Clear the trouble with SIM 16.
Content CRUM chip communication error
Details Error in MCU-CRUM chip communication
Cause CRUM chip failure
Developing unit contact trouble
MCU PWB failure
Check
and
remedy
Check installation of the developing unit.
Replace the MCU PWB.
Remarks CRUM communication error
Jul 06, 2010 | Sharp AR-M237 Digital Copier
I have an older Sharp AR-168S printer with U2-40 error code.
U2-40 CRUM communication error
Detail-Toner cartridge CRUM data read
error
Cause-A toner cartridge of a different
destination is installed.
EEPROM trouble
Check the destination setup.
Toner cartridge CRUM PWB trouble
MCU PWB trouble
CRUM connector disconnection
Check and
remedy-
Install a specified toner cartridge.
Check the SIM 26-6 setup.
Replace the EEPROM.
Replace the toner cartridge.
Check connection of the CRUM
connector.
Execute SIM 16.
Feb 09, 2010 | Sharp Office Equipment & Supplies
Crum data read trouble in sharp ar 207
The CRUM chip is what tells the copier that the correct toner is installed. It is specific to the toner cartridge. If it is a new cartridge then it should have a new CRUM chip and there should be no problem. If it is a recharge it's possible that the chip was not changed or the wrong one was used.
Oct 16, 2008 | Sharp Office Equipment & Supplies
Please help with diagnosis of following error for Dell 5110CN CRUM ID -093-693
crum has happened to me when using the wrong toner cart or using a non-Dell cart. If that is the case, replace the chip from the old Dell cart into the new non-Dell - easy to do by prying the small circular top off. You'll probably need to switch to non-Dell toner on the printer - go through menu to find it and your toner usage software will be disabled - that's life.
I also had this happen with real Dell toner cart and I did the same thing to rectify.
Mar 16, 2008 | Dell 5110cn Laser Printer
Error message CRUM ID 093-693
please help with diagnosis of following error for Dell 5110CN CRUM ID -093-665
I tried everyting. I took the imaging drum out and poot it in, and notihng. This imaging drum worded before OK.
Tom
Dec 12, 2007 | Dell 5110cn Laser Printer
Xerox WorkCentre 6015NI Logo
121 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
