Question about Dryers
GE dryer breaker keeps tripping. Change breaker but it still keeps tripping. This problem started after replacing broken belt. I must let you know also that the front of the dryer fell forward pulling on wires. Also the dryer was not in use for about three years. The dryer is about 25 years old and looks new brand. I open up and look for loose or broken wires.
  • chris weier May 11, 2010
    is there a humming noise before the breaker trips, burning smell?
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 211 Answers
May be a shorted heat strip
Posted on Sep 23, 2017
  • 249 Answers
SOURCE: Broken belt
remove top first, then front just a few screws,then put belt around the drum and pulley and reassemble,bye.eire
Posted on Dec 04, 2007
SOURCE: How to open the dryer and replace the belt
all dryers open from the top so open the dryer door and look inside the top edge you will see two screws . remove the screws and lift the top panel . the front panel has two screws on the top one on the left and one on the right remove them both and lift up the front panel to remove it. the only way you can install the new belt is removeing the front panel because the belt goes around the drum from the front. once you remove the old belt out put the new one in . the belt goes around the drum from the front and then to the motor and idle roller . you can reach the idle roller from the front left corner or from the back of the dyer? i like to install them from the back cause its more easy. in the back of the dyer where the hose goes connected to the blower is the top with four screws remove the hose from the blower tube and remove the four screws. after you remove everything you should be able to see the dryer motor and idle rooler put the belt over the motor first then over the idle rooler .always make sure when you do this the dyer is unpluged and after your done plug it back and turn it on to make sure it runs correctly . if it runs ok put everything back together again.
Posted on Jan 11, 2008
Jimster
  • 240 Answers
SOURCE: whirlpool electric dryer keeps tripping main circuit breaker
First off, be sure the pigtail is wired correctly to the back of the unit. Black and red to the outside terminals, white to the middle, green to the frame or cabinet (should be a green screw close-by). If that is ok, you probably have an issue with possibly a bad pigtail, bad outlet, wiring issue, or possibly a bad circuit breaker or breaker box. Probably going to be more of a electrical problem than a appliance problem. Good Luck!!!!
Posted on Feb 02, 2008
TheMobilian
  • 8220 Answers
SOURCE: installed new motor in my old ge dryer
I bet you did not get the center bearing in exactly right and the drum rubbed against the element. Seen it.
Posted on Jun 14, 2009
Number5Gayle
  • 98 Answers
SOURCE: GE DVLR223 dryer wont start....breaker is not tripped
check all the connections on the back of the dryer, if a few screws are loose, that could be the problem.....now the other thing....it might need a new motor. Unplug it before checking it out!!
Clean out your vent hose and the outside of the Vent to prevent fires.
Posted on Jul 31, 2009
I have a ge washer that trips the breaker when it starts to agitate. I've replaced the belt but still trips breaker it spins and drains on that setting put soon as it fills,starts the breaker goes
Once a breaker "trips", it is more-likely to trip the next time at lower voltage/wattage levels. Hire an electrician to replace the breaker.
May 31, 2015 | GE Washing Machines
My white knight tumble dryer wont start
Nothing works or drum fails to turn (tumble dryers)
Ensure that the power supply to the dryer is switched on, the timer is set to the desired drying time and the door is correctly closed. If you have a condenser model, also check that the bottle is empty and is fully pushed into the machine.
http://www.whiteknightrange.co.uk/whiteknight/faq.html
The first thing to establish when troubleshooting the clothes dryer is whether the dryer will start or not. If it won't, start by checking the outlet and the circuit breaker. Is the dryer plugged in or has it tripped the circuit breaker? If the breaker has been tripped, flip it back on and try the dryer again. The drum should turn without a problem.
If both plug and breaker are fine, you'll need to inspect the door switch as you continue to troubleshoot the tumble dryer. When you close the door on the dryer, a plastic peg should click and operate the switch which allows the dryer to work. The peg might be bent or broken, in which case it won't connect with the switch. You can try to straighten the peg, but if it's broken, you'll need to replace it. If the peg is fine, the switch has probably failed and will need to be replaced.
http://www.doityourself.com/stry/troubleshooting-a-clothes-dryer-drum-doesnt-tumble#b#ixzz3FOOQgtAT
Oct 06, 2014 | White Knight Press Genuine Tumble Dryer...
What causes ds5400eb2 dryer to keep tripping circuit breaker
heating elements broken & shorted out get a service tech please
May 04, 2014 | GE Dryers
Dryer wont start
As long as you're sure it is plugged in to an outlet that has power (make sure the breaker is not tripped), there are 2 things that keep a dryer from starting. There is a switch that needs to connect by the dryer door being closed. and there is a switch on the belt tensioner that shuts the dryer off when the belt breaks, and will not allow it to restart until the belt is replaced. Check the drum drive belt to see if it is broken, that is the most likely cause.
Dec 13, 2013 | GE Profile Harmony DPGT750EC Electric...
My dryer will not start
If you hear the motor then the belt is broken If you have the control panel working it is no guarantee that the breaker didn't trip Find the breaker in your breaker panel and reset it.
Nov 29, 2013 | Speed Queen Dryers
SHORTED THE DRYER BY TOUCHING WIRE TO BODY, THERES POWER INSIDE THE DRYER(LIGHT ON), BUT NOTHING HAPPENS WHEN SWITCH IS ON, CONTINUITYIS GOOD ON START SWITCH, WHERE DO I GO NOW
Power to the dryer is 220 volts, with half of the total voltage supplied by each of two breakers. The breakers are combined into one larger breaker, but each side of the breaker connects to a different buss bar in the breaker box. What it sounds like is that one half of your breaker is tripped, and the remedy is to trip the double breaker in order to reset the half that is tripped. If tripping the breaker off and back on does not restore the operation of the dryer, trip the breaker back off, unplug the dryer, and check for any burned wires at the terminal strip where the cord connects to the dryer. Replace any defective or burned parts.
Best regards, --W/D--
Mar 06, 2011 | GE DBXR463EBWW Electric Dryer
Dryer keeps tripping the circuit breaker
hello mam please change the mains breaker after tripping for several times the breaker will be defected and check the power socket outlet by removing the socket there should not be any loose connections and skinned wires.
Oct 02, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer started up as normal, but, midway through cycle, it stopped running. Timer was still going, but dryer is not spinning.
Can you hear the motor turning? If yes, it probably has a broken belt that drives the drum. If no, check the house electrical power panel to reset the dryer breaker(maybe, only one of the breaker pair tripped). If breaker trips again, you have an electrical short in the dryer cabinet somewhere, usually in the heating element in back of the drum. Good luck!
Jul 09, 2009 | Dryers
GE dryer does not run and just hums
Yes, open it. You'll probably find a broken or loose belt.
More help?, let me know.
May 09, 2009 | GE Profile DPSB619ED Electric Dryer
Dryer trips breaker as soon as i try to start it.
Use or borrow a volt ohm meter and check for a grounded hot wire. You may also be exceeding the start up load on the 20 amp breaker. Test this theory (after you make sure that there are no ground faults) by starting the dryer in a "air fluff" mode without heat. If the dryer starts in the "no heat mode", switch the heat on - if you blow the breaker you know that the 20 amp breaker cannot handle it. Before you do any of the above - check your dryer manual for the service requirments. If you don't have the manual go to the mfg. web site and download it.
Feb 04, 2009 | GE DBXR463GB Gas Dryer
Dryers Logo
125 people viewed this question
Top Dryers Experts
