About ever 20 minutes or so the wine cooler makes a chattering sound for just a second or two. It seems to be working fine however the noise is a nuisance.
Comments:
Feb 16, 2008
- Thanks timstv,
Sunds like a very likely solution. Will take a look when we get back from our winter vacation.
The compressor has rubber grommets that isolate/insolate it from metal on metal. What is happening is that one of these has worn through and now when the compressor kick in or out it shake which is normal but gives you that metal on metal clanking which is not normal. Look at the back and see where the compressor is held inplace by pins you will see rubber donuts/grommets. One or more are wore out. You can probably find some on a unit at a salvage yard on a small fridge and you may be able to buy some an appliance supply warehouse....
upper temp lowers to 32 rises to 45 over and over bottom temp stays at 62 wont go lower on danby...
(More)(More)
upper temp lowers to 32 rises to 45 over and over bottom temp stays at 62 wont go lower on danby dual temp wine cooler
Posted. Thank You!
Congrats on your 3 solution. You're helping others! Someone may even thank you with a Testimonial.
13 month old, DWC283BLS, motor running, power appears ok, judging from LED readouts and interior...
(More)(More)
13 month old, DWC283BLS, motor running, power appears ok, judging from LED readouts and interior lights, but compressor will not come on, temp not coming down in both compartments. Is there a reset somewhere?
Posted. Thank You!
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
