Buick LeSabre Heater blows only cool air...even w/ defroster on. This is a ... Heater fandoesn't come on . ... The blower works but there is no heat coming out.
? 4:22
https://www.youtube.com/watch?v=2vmfxYg8LoY
Sep 27, 2009 - Uploaded by mgittelman
The blower motor is a common heater/AC repair within the skill level of ... However if the power wire is a single light purple wire and the ... for blower motor and fuel and relay good but no powercoming on both any ideas? ... my o5 seira, when i start the engine with the air switch on it blows my blower fan ...
? 6:22
https://www.youtube.com/watch?v=hgar6Q1lV6A
Apr 5, 2013 - Uploaded by Fixbook
Here I show how to determine the problem if your air, or blowermotor is not ... Click here to check out the the "Car Runs on 2 cylinders" series: ... How to Fix Over-Heating engine & No Heat in car - Buick (2000 yr) Park Ave . ... Car fan / AC only works on high - Replacing the Blower Resistor - Duration: 4:24.
hello the resistor heater under dah passager side got a relay on it when the relay go bad sometime it simply doesnt come on or always stay on and drain the battery simply change that resistor 7/32 socket disconnect and reinstall hope it help pierre
It is out under the hood ,mounts in the heater case it has 4 wires going to it if your car has manual air and 4 wires coming out if is automatic control air.
find wires to fan motor,get jumper wires go directly from battery to fan,make sure you have positive and negative right,see if fan works if not fan motor is bad and needs replaced,thats were i would start!! Hope this helps!!!
