Question about Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound
Torque specs on lower unit 1983 85 hp force outboard
What are the torque specs to put back on
I have a 50 hp Johnson outboard or do I disconnect the shift linkage to get the lower unit off
have a look at the videos
How to remove the lower unit on a outboard engine - YouTube
? 3:24
https://www.youtube.com/watch?v=R6wVMc8GD0w
Mar 29, 2015 - Uploaded by Greg Drinkwater
How to remove the lower unit on a 1989 Johnson 88 SPL Help me remove lower unit. Johnson 90 hp ...
Johnson 50hp Outboard Lower Unit - YouTube
? 2:15
https://www.youtube.com/watch?v=DnU7vKcJkeE
Apr 9, 2016 - Uploaded by Stacy Wyoming
Removing Bearing Housing From a 50 HP Evinrude - Duration: 2:15. Brandon's Garage 274 views ยท 2:15 ...
how to remove lower unit on johnson outboard - YouTube
? 0:47
https://www.youtube.com/watch?v=_ygxZSxU6-I
May 24, 2016 - Uploaded by 2222buster2222
How to remove your lower unit on a 1984 Johnson Outboard 70HP.
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump ...
? 24:26
https://www.youtube.com/watch?v=Hv8gXqsO2fg
Jun 3, 2015 - Uploaded by Ralph Pierre
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump Service. ... Just bought a Bass Tracker ...
50 hp Johnson outboard remove lower unit Google Search
Jul 07, 2017 | Johnson Boating
I need the Torque specs for a 2006 ford escape breaks front and back please
Pad material will cause these problems.... Buy good Cermic pads and new rotors and you won't have that problem
Jan 22, 2015 | 2006 Ford Escape
I have a 1998 Johnson 130 hp outboard motor. Have already taken lower unit off but can't get it apart. Is there a secret to taking the lower unit apart? I would like to have a diagram.
Here is a site where you can purchase the service manual to repair your outboard motor:
http://www.tradebit.com/G/manuals/-/0-0-johnson+130+hp
Jul 13, 2011 | Computers & Internet
Need to know how to change lower unit on 1971 johnson 25 hp motor
put into nuetral,undo the five bolts around lower unit,take off sideplate halfway down leg casing,loosen the two bolts clamping the gear rods together,then lower unit should slide down[if driveshaft isnt stuck in the crankshaft spline].assembly is reverse,but take care putting water tube back into rubber grommet,and tighten gear rod clamp only after making sure that g/box is in nuetral,when gear lever also in nuetral,or matched together
Jul 01, 2010 | Light Outboard Motor Boat Bass Fishing...
What oil do i use in the lower unit of a 1989 90 hp mercury outbord
go to a marine store and get lower unit gear lube. it comes in a squeeze tune and just remove the plug and squirt it in . both screws need to be out tho upper one lets air out as you push new in lower .the put upper back in first keeping oil in till you put in lower plug
May 01, 2010 | Light Outboard Motor Boat Bass Fishing...
Force 90 outboard locked in forward gear after impeller replaced
i have fought with mine in the past also.
put lower unit and the control in neutral
remove all spark plugs and have a helper turn the fly wheel clockwise while you install the lower unit i had to use channel locks to put the lower unit to neutral
good luck i hope this helps
Apr 09, 2009 | Light Outboard Motor Boat Bass Fishing...
Torque spec. for shocks
use 2-3 drops loctite 242 (blue) to threads of bottom bolt and torque to 25-40 lbs.
Same with the lower stud .....
happy trails
Apr 08, 2009 | 2000 Harley Davidson FXDWG Dyna Wide Glide
I need the rear shock torque specs for a 2007 sport trac
Torque Specifications Description Nm lb-ft lb-in Brake caliper bolt 32 24 — Brake disc shield bolt 8 — 71 Fuel tank filler pipe bracket bolt 15 11 — Fuel tank filler pipe hose clamps 3 — 27 Halfshaft nut and washer 275 203 — Lower arm inboard bolt 250 185 — Lower arm outboard bolt 275 203 — Parking brake cable bracket bolt 10 — 89 Shock absorber lower bolt 275 203 — Shock absorber rod nut 65 48 — Shock absorber upper mount nut 30 22 — Stabilizer bar bracket nut 48 35 — Stabilizer bar link nut and grommet 30 22 — Toe link cam adjuster nut 275 203 — Toe link outboard bolt 325 240 — Trailing arm bolt 300 222 — Upper arm outboard bolt 225 166 — Upper arm inboard nut 250 185 — Wheel speed sensor bolt 8 — 71 Wheel knuckle bolt 275 203 —
Mar 30, 2009 | 2007 Ford Sport Trac Limited
Torque specs
Hi my name is Allen!
I work for a Dodge Dealership. There are no torque specs for the upper or the lower ball joints on any of the Chrysler Vehicles. As long as you get them as tight as you can they will be fine, don't worry they are held in by road force anyway. Note: Be careful that you don't strip-out the nuts by getting them to tight.
For further asistance you may reach me at FixYa!
Dec 28, 2008 | 2003 Jeep Grand Cherokee
Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound Logo
57 people viewed this question
Top Polaris Winter Sports Experts
Larry Fostano
Larry Fostano
toddgilbert
toddgilbert
Todd Arndt
Todd Arndt
Are you a Polaris Winter Sport Expert? Answer questions, earn points and help others
