Question about GE WVSR1060GWW 3.2 Cu. Ft. Super Capacity Top-Load Washer, with 6 Wash Cycles, FlexCare Agitator,
Slow agitator Agitator seems reallyloose
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 29 Answers
Sometimes it is a very simple fix.
Agitator dogs.
4 little plastic thingies that wear out so the agitator has nothing to grip.
I'm not sure if they are specific to each model washer but it's about a $5.00 try.
You have to take the agitator out.
I watched YouTube.
Pretty easy and far less expensive than a pro!!
It took 10 mins. The hardest part was getting the agitator apart, which takes elbow grease!!
Posted on Sep 25, 2014
Jimster
  • 240 Answers
SOURCE: Agitator loose
Just reach down between the basket and the agitator, and lift really hard straight up. Be sure not to hit yourself in the head when it pops loose. GE agitators just snap on to the air-bell underneith. Be sure that bell isnt loose after you remove. Good Luck!!!!
Posted on Feb 03, 2008
farfield
  • 462 Answers
SOURCE: washer agitator won't agitate
Look at the center. can you pull the agitator up and out of the tub? You can try it with the motor running but don't grab it too snugly. Try and push it up and down while running. If it seems to try and move there used to be a rubber spindle on the trans shaft under the agitator that would become separated. I don't know if yours has one or not but the agitators were a bugger to remove usually because of the corrosion that happens. A special tool that was an air bladder used to fit under the agitator and you'd blow it up like and inner tube and pop it off. If you get the agitator off you try to get it to agitate and if you cant stop it by hand your at the problem either you'll see it obviously or it will come apart inside the agitator.
Posted on Mar 11, 2009
WonderTech
  • 268 Answers
SOURCE: my agitator is not working in my washer- it is a
The agitator is driven by a couple of different methods. The first is the agitator is splined and slips onto the matching splines of the agitator shaft from the transmission. The second is the use of a bell coupling which is splined to the agitator shaft as well and the agitator snaps onto the coupling. If the agitator does not agitate, first remove the agitator and watch the agitator shaft to see if it is working properly. This will require a small load setting of water and the machine set to run. If the agitator shaft is working properly, it is either the splines on the agitator or the bell coupling that is defective. If the agitator shaft does not work properly, the problem is in the transmission.
Hope this helps.
Posted on Aug 07, 2009
GM Elec
  • 1000 Answers
SOURCE: We can't remove the agitator
Once you remove the cap on the agitator, remove the bolt and pull straight up on the agitator. It will come off the drive shaft and you can pull it out of the tub.
See the illustration below.
Regards,
Posted on Aug 19, 2009
  • 32 Answers
SOURCE: the agitator will not agitate
it striped the splines in the plastic need new agitator
Posted on Oct 20, 2009
Loud constant noise (metal on metal clicking / whirring / grinding) during spin cycle
renault laguna 2006 diesel. unlock code for radio... modell renrdw100-10 .
n874 security...
pls..
thanks
Nov 22, 2013 | Whirlpool Washing Machines
Whirlpool washer 1987 model CA7800XPW1: the agitator slow and/or stops only to resume to full speed at other times. I can't get the agitator off; got the back off and the belt looks OK; it seems like...
The agitator should be able to be removed once the bolt in the center of it is removed,the oil you see is from the transmission that contain the gears that make the agitator swoosch back and forth,if ya see a lot oil its leaked out of the trans. and the internal gears are stripped.It could be that the center spine of the agitator itself where it connects to the trans. shaft is stripped but unless the agitator comes off where will be no way to see if that is it. IF you want to invest in tl that most likely you will never use again there is a tool out that is a rubber bladder that slips under the agitator and is filled w/water when its filled it expands and pushs the agaitator up from the bottom
Gene
Aug 06, 2011 | Whirlpool Washing Machines
Kenmore Series 80 washer. Agitates too slow
check the dogs in the agitator take off the cap it should rachett if it turns free replace the dogs in the agitator
Jul 12, 2010 | Kenmore 24032\24036 Top Load Washer
Agitator very slow
I changed the motor coupler, but now it fills and spins ok. but agitate very, very, slow
May 16, 2010 | Washing Machines
Agitator will not spin easily from pully below or
transmission out buy new washer cost to great to repair 15 year old washer
Feb 03, 2010 | Maytag LAT3600A Top Load Washer
Washer does spin but barely agitates
It sounds like the agitator dogs are worn.
To remove the agitator, pry off the agitator cap and remove the bolt that holds down the agitator. With the bolt out pull up on the top section of the agitator (auger) to remove it. Underneath the auger you should see 4 small white or beige plastic gears (dogs). . Replace those and it should be ok.
The part number is 80040
Let me know if you need more assistance.
Apr 08, 2009 | Kenmore Washing Machines
Slow spinning agitator with knocking sound
agitator dogs. take them out and replace.
Feb 28, 2009 | Whirlpool Washing Machines
Agitator runs at a very slow pace.
it sounds like the belt may be stretched not allowing it to agitate as it should
Jan 17, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator slipping
change your agitator dogs in agitator
Nov 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Remove Agitator Whirlpool style Top Loader
i think that the agatator may have a screw in the side of it nearer the bottom stem if so slacken off and pull ajatator off main shaft
if no screw just pull agatator off
sometimes takes a bit to get off
do not turn machine upside down
Feb 01, 2008 | Washing Machines
GE WVSR1060GWW 3.2 Cu. Ft. Super Capacity Top-Load Washer, with 6 Wash Cycles, FlexCare Agitator, Logo
89 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
