Question about RIM BlackBerry 8700g
Track wheel only works vertically
Cannot move it horizontally! Any suggestions?
Hold alt while scrolling to go sideways.
Posted on Sep 18, 2009
Explain how the monitor buttons work
Monitor Icon Description of icon function moncont.gif Power - Turns the monitor on or off.
Brightness - Using this button or wheel the user can increase and decrease the brightness on the screen.
Contrast - Using this button or wheel can increase and decrease the amount of contrast on the screen.
Horizontal Size - Allows for the picture on the screen to be stretched to the horizontal edge of the monitor.
Vertical Size - Allows the picture on the screen to be stretched to the vertical edges of the monitor.
Horizontal Position - Allows the picture to move moved horizontally, once in the center the user can then use the Horizontal size to stretch it to have an equal amount of black border on each side.
Vertical Position - Like the Horizontal Position, using this button or wheel the user can move the picture up or down to center the picture more appropriately.
Full Screen - Sets monitor to full screen.
Degauss - This button will degauss the CRT, restoring possible color impurities. After this button has been pressed the degaussing circuit will be activated and then deactivated after a few seconds. Pressing and holding this button for a few seconds may cause your computer monitor to reset all data.
Corner and Trapezoid Correction - Using this button or wheel the user can either round the edges of the picture or move the picture inward like an hour glass or outwards.
Vertical Linearity - Sets the width of the vertical lines.
Moire - Removes or reduces the Moire effect, if any.
OSD Controls - If the monitor contains OSD controls, allows for the OSD menus to be adjusted.
Power Management - Allows the user to define the power management settings through the monitor itself and not the software.
Monitor Status - Displays the current monitor settings such as refresh rate and other settings.
Language - Sets the language on the monitor.
Aug 16, 2014 | Computers & Internet
Check print path error after belt replacement (HP 1055)
Did u observed the belt having 50% vertical tracks & 50% horizontal tracks?. The vertical tracks as well as horizontal proper position?.. understand the snap., re install the belt once again as shown in fig... i hope UR problem will be resoled..
Apr 15, 2014 | HP DesignJet 1050c plus InkJet Printer
Power driver seat will not fully move forward or backward.
make sure nothing is lodged under the tracks this is common things get thrown under the seat and stops them in the track
Mar 31, 2014 | 2002 Chevrolet Tahoe
Whats the difference between a vertical and horizontal mills?
Horizontal and vertical just refers to the orientation of the spindle, each has their advantages and disadvantage, the vertical mill is more for standing mechanists and doing more detailed work while the horizontal are designed for cutting heavy pieces.
Jan 23, 2014 | Tools & Hardware - Others
My picture tube displays all black except one thin horizontal line in the middle. There are no horizontal or vertical adjusts that I can fine. Is the picture tube burned out with just this one line?
Hello
A thin horizontal line across the screen denote that the vertical swep or output has damaged, or there are some loose solder points to vertical output section. Loose solder problems are very common to the vertical output sections of most of the picture tube based TVs. Just open your Tv, and pull out the main baord out of it, which has the vertical output section circuit. You must have some knoldge in electronics to proceed. Locate the vertical output section. usually, this section will be composed of an IC, which will be screwed on to a metal heatslink, to radiate heat out of it when it works. Check whether there is any loose solder terminals at this section, especially look for it at the solder terminals of IC and other components around it.
It is very difficult to detect the loose solder points, as some of them may be so microscopic to detect. Just do, what we do at service table, with this type of fault comes to us. Just resolder most of the suspected solder terminals by applying a little more solder without making any sokder bridge short between adjecent solder terminals.
If this does not help you, check the input voltage to the vertical IC. If found OK, replace the vertical output IC. If there is no voltage to this IC, check the track that brings voltage to that IC. Usually, this voltage will come from one amoung the terminals of LOT [Line Output Transformer]. Check the track, rectifier diode, limiting resistor etc. This is really a skilled work, and you should have all tools for an electronic work, and a skill to detect the faulty component. OK
Sep 16, 2011 | Durabrand DWT1905 TV
My KING KC-115C Horizontal metal cutting band saw cuts off track.
I used to work for Doall saw company. While I am not familiar with the particular model you have, I have seen issues like it in Doall saws.
Firstly, If bearing guides are not adjustable, replace them. There should be only about a 32 of an inch play between them (in addition to the thickness of the blade). Secondly, for a prodution horizontal bandsaw you should have the blade tensioned a @30,000 psi. Thirdly, if after that, you are still having problems, I would suggest checking the bearings on your drive and idler wheels for runout (in addition to the condition of the tires).
Nov 18, 2009 | EZQuest King (K529900) Burner
MY BLACKBERRY'S SCROLL WON'T WORK IF I TRY TO CLICK ON AN ICON....
Steps to be followed
1.Click Menu key
2.Goto Options icon
3.underthat select SMS/KEYBOARD option
4. Increase the Track ball sensitivity to 100 horizontally and vertically Both.
After this track ball works....
if its not working walk in to Service center
Nov 09, 2009 | RIM BlackBerry Curve 8310 Smartphone
I have a Mitsubishi CS-3125R that displays a horizontal line with sound. I suspect the horizontal transistor is out and cannot find one. Any ideas?
You are misleading yourself. When you have a horizontal line across the screen it means that the vertical circuit is not working. You see, the vertical circuit moves the beam up and down which is not happening. The horizontal circuit moves the beam left and right and it is working. Your set probably needs a new vertical output IC and some electrolytic capacitors that work with it. The caps dry up with time and harm the output IC.
Jun 04, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Trouble tracking vertically
dust stuck inside the trackball on the vertical axis maybe. Otherwise faulty device, you should return it
Sep 19, 2007 | IOGear HAND-HELD RF WIRELESS MOUSE...
No horizontal red convergence control
Probably the red convergence output IC has failed. The chip is basically a stereo amplifier that serves as a horizontal amplifier and a vertical amplifier. I suspect the vertical part has failed and is not uncommon. Should be generic STK392-150's or maybe STK392-110/120 I believe. By the way when the line moves up and down that means the vertical is working when it moves side to side the horizontal is working.
Feb 03, 2007 | Philips 60PP9202 60" Rear Projection...
RIM BlackBerry 8700g Logo
146 people viewed this question
Top RIM Computers & Internet Experts
ismael castillo
David
Jerry Greenberg
Jerry Greenberg
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
