Question about Linksys Wireless-G WRT54G Router
Reset password how do I password protect?
How to change password on blackberry when you don't know the password?
If you or a user turns on content protection for a BlackBerry device that is running BlackBerry Device Software version 4.3 or later, you can reset the BlackBerry device password using a BlackBerry Enterprise Server version 4.1 SP5 or later. The BlackBerry Enterprise Solution uses the remote password reset cryptographic protocol to reset the BlackBerry device password when content protection is turned on. The BlackBerry device does not prompt the user for the old BlackBerry device password.
The remote password reset cryptographic protocol is designed to provide the following features:
* permit the BlackBerry device to encrypt the content protection key again with the new password, without the old password being available
* prevent a hardware-based attack on the BlackBerry device from recovering the content protection key without knowing either the BlackBerry device password or the IT policy private key that the BlackBerry Enterprise Server generates for the BlackBerry device
* prevent the BlackBerry Enterprise Server from accessing any data that a potentially malicious user could use to recover the content protection key
To reset the BlackBerry device password, you send the Specify new device password and lock device IT administration command to the BlackBerry device. You should send the IT administration command to a content-protected BlackBerry device that is in the possession of the BlackBerry device user only. If you send the IT administration command to a BlackBerry device that is in the possession of a potentially malicious user, that user can use a hardware-based attack to recover the key pair that the BlackBerry device created when it received the IT policy. The potentially malicious user can use the key pair to decrypt all the data on the BlackBerry device.
* Process flow: Resetting a BlackBerry device password when content protection is turned on
Proceed on this link : ID PASSWORD RESET
Aug 06, 2011 | RIM BlackBerry 8703e Smartphone
What is the color password protect - diable overide - reset turn off?
Hi
Password protect is to make a password to the menu and only you can have access to it
disable overide is to overide the toners when are near end
and reset is to reset the menu to start menu
Jan 03, 2011 | Xerox Phaser 8560MFP Laser Printer
I HAVE FORGOTTEN THE PASSWORD
Well you can reset your password but that will depend whether your Administrator (Windows) root (Linux) user's account are password protected or not. If they are not password protcted then log in to your system with administrator or root and then reset your password but if that also is password protected and you have forgotten that password also then there is no option in windows other than reinstalling. ya but you can do it in Linux without reinstalling.
Nov 11, 2010 | Computers & Internet
Versa VXi PC Notebook: Password bios protect, how to reset bios password ...
I know some methods to reset bios password.
1. The best and easiest method: Close OS and shut down the electricity power of computer. Open your computer box, take out the cmos battery from the mainboard. Then the bios password will be reset to blank. Put it back after a few minutes.
2. Follow some hard tutorials, it is difficult to do. It is better that you are a expert. For example this tutorial: Bypass BIOS Password or Crack CMOS Password?
3. Use the bios password recovery tool , but that is not free!
So I would suggest you the 1st method. Hope it helps.
May 17, 2010 | NEC Versa VXi PC Notebook
How do you unlock the password protected document on word2007?
Hi.
It is so coincidence that i just read the article " How to Password Protect Microsoft Office 2007 Documents "
it not only tell us the way to password protected but to unlock password protected document.
maybe you can you can find the solution form it. here it is:
http://www.blog.recoverlostpassword.com/how-to-password-protect-microsoft-office-2007-documents/
Apr 23, 2010 | Microsoft Office Word 2007 Upgrade:...
How to reset password for access service mode
There is no reset for service mode! There is for admin mode and if machine is password protected.
Apr 13, 2010 | Minolta bizhub 350 Black and White Copier
I have my computer password protected and I forgot the password
i can solve this problem for you! just mail me
djkaja@gmail.com
Apr 14, 2009 | Computers & Internet
Password reset
That could be a bios password or a hard drive protection password. If it is the bios, you should click on F2 while laptop is in the boot process, and see if it will go into the bios. If it will, you can reset the password there as long as you know what the old password is.
If it a hard drive protection password, you should be able to reset it in the same screen that is asking for it. Again, you have to know what the old password is before you will be able to change it.
Mar 14, 2009 | Toshiba Satellite A215-S4747 Notebook
It keeps restarting on me
Without more details I'm going to make a guess on this. It sounds like you have the HP Protect tools installed. If you do have the HP Protect tools installed and that was the password prompt from HP Protect tools giving you problems, your best solution may be to do a hard reset. I had problems with the **** HP Protect tools and had to hard reset to remove it. NOTE that a hard reset will also clear all the files and data on your pda
Dec 12, 2007 | HP iPAQ hw6515 Pocket PC
Linksys Wireless-G WRT54G Router Logo
22 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
