Question about Fein FMM250Q Select Multimaster Oscillating Tool Kit
Fein Blue smoke and won't get high rpm.
  • Fein Master
  • 1,822 Answers
A defect armature that happends oft by this tool multimaster there was a little serie of this 250 watt budget machines that have hiddens defects in the armature if you look at that part then you see not a burned field or armature but the tool becomes very hot to hold in your hands. if you are by a service dealer he can confirm the problem that in most cases not was your fault because if its not burned , but when its burned then replace BOTH the electric field and the armature if you can become that cheap , most times this budget tool is not to expensive to get new. but in that case the 350Watt tool little difference but more to do with.
Posted on Jan 13, 2016
2 Suggested Answers
  • 52 Answers
SOURCE: fein multimaster looses rpm after startup
Sounds like one of hte brushes is hanging up in the brush holder allowing macine to slow up. Check this 1st and make sure brushes are about 1/4" long.
Posted on Jan 11, 2009
Navara 2.5 diesel only reaching 2,000 rpm
Blue smoke is oil. Compression check. and check plugs for fouling.
Apr 26, 2014 | 2005 Nissan King Cab
Fein multimaster
interference suppression capacitor or electric field .
Apr 19, 2014 | Fein FMM250Q Select Multimaster...
Overfill oil
Sounds like the engine is tired. Blue smoke is oil burning. Hard starting is oil on the spark plugs and/or low compression. This also can be due to someone adding too much oil.
Sometimes, the carburetor Needle valve hangs u pa bit and the Crank case oil gets mixed with gas so now the oil level is high. Too much oil in a motor is bad too, that would cause theblue smoke too.
Jul 20, 2013 | Yard Machines 11A08MB006 22Inch 139cc MTD...
Black smoking on idle
Your engine would smoke if you are running at too high RPM or have had your RPM at a high level before. The engine is getting overheated. When you say it only smokes until about one mile it sounds like a problem with the engine. starter.
Source here ...
Jul 12, 2013 | Cars & Trucks
1994 corvette running too rich black smoke and coughing low rpm
the brake servo needs refitting and ensuring correct torque
Jun 11, 2013 | 1994 Chevrolet Corvette
Fein multi tool won't release sanding attachment
A waste of time to spend with this budget machine, unfortunately, be replaced is usually not make sense relative to the new value of the whole and in rapid succession, the following defects no spare parts to get for only a complete new head . thats fast about 50 % of the new price , NOT REPAIR is a good no the best advise in that case. if its not a FEIN supercut its not worth it to even do something to in that case it has only the name FEIN but its having very soft metals.
Oct 14, 2012 | Fein FMM250Q Select Multimaster...
Black smoke in the exhaust and in high rpm white on passat 1.9tdi
this case , you have to check turbo charger , when high RPM white smoke means lubricate oil goes to engine so give white smoke . on low rpm trubo close coming black smoke means no enough air gose to engine so this need to replace turbo . some type of turbo can be clean the wase gate ( which open with diafam beside turbo) make sure it's moving when accilerate. check vacum is ok . then clean wase gate > only some type have wings inside )if no replace turbo
Jul 30, 2011 | Volkswagen Passat Cars & Trucks
2002 rm 250 smoking
Probably due to a bad crank seal on the clutch side. The extra smoke is from the trans fluid burning through the cylinder.
May 26, 2009 | 2003 Suzuki RM 250
Fein multimaster looses rpm after startup
Jan 11, 2009 | Fein FMM250Q Select Multimaster...
RPM will start to slow and then almost quit
fein i believe is made in europe. i am guessing its the hz problem co`s the electronic to failed
Feb 22, 2008 | Fein Multimaster Rs - Msxe 636 - 2 Rs
Fein FMM250Q Select Multimaster Oscillating Tool Kit Logo
60 people viewed this question
Top Fein Tools & Hardware - Others Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Fein Tool and Hardware - Other Expert? Answer questions, earn points and help others
