Question about Leisure Cookmaster CM101NR
Fan oven is dead as the proverbial. Blew electrical circuit when it stopped working.
Fan oven doesn't work, dead as the proverbial, blew electrical circuit when it ceased working.
My zanussi oven blew, I changed element still not working, seems my bulb blew 2 and connection as I taken it out, would this stop the circuit from working as I have no power to cooker and switches ect are...
When the element blew , it may have taken out either the selector switch or possibly the toc, if the bulb has blown the oven should still heat up .
Mar 06, 2015 | Zanussi Ovens
Hi I have a Samsung SMH9187 micowave that is dead (no display, light, fan, mirowave).
Sounds like the main fuse blew. It's either near where the power cord enters the cabinet, or behind the control panel (if an over the range unit).
You may also have some type of failure in the high voltage circuit; based on your description of the symptoms.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Aug 16, 2014 | Samsung SMH9187ST Microwave Oven
Roper mhe14xm stopped heating. blew a breaker, the microwave comes on, but does not heat. It has a
If this was preceded by failure of the cooktop lights, then you probably need circuit board repair.
Check and see if the cooktop lights and vent fan both work. If not, that's a clue.
Always unplug an oven before removing or inserting bulbls, or there can be a filament short which sends a surge through the controller.
But the first thing I would suggest is a hard reset.
Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
If it still fails and comes up with a "d" error, then you might check the door switches. Help file here.
Once all that is checked, and ruled out, repair or replacement of the circuit board is probably indicated.
Dec 12, 2011 | Microwave Ovens
Have a simpson 2002 65-647 fan forced oven. fan stopped working yesterday and blew a house fuse. What is the likely problem and is this am easy fix?
Hi - you have an electrical fault somewhere in the oven, it has to be a short circuit to earth for the house fuse to blow.
Likely causes - the elements have short circuit - may have a hole visible on the elements somewhere, wires have come off or burnt off due to loose connections and touched the metal frame, or the fan has shorted out...
It may well be viable to obtain the services of a repairman, it maybe a simple issue as above, then again perhaps not..
KK
Jul 03, 2011 | Ovens
The oven blew the electrics and now the heating does not come on. the grill and fan both work but not the oven
If the fan is working o/k, then you need to replace the oven element, located at rear of oven compartment behind panel.
Please rate my solution.Thanks.
Nov 12, 2009 | Belling XOU252 Electric Single Oven
Element blew in oven; now stove doesn't work....
Sounds like the loose oven element caused a short circuit, which may have fried a wire inside the range. Or, it may have tripped the circuit breaker (or blown the fuse) for the range circuit. Check your electrical panel. If the circuit is open, don't reset it until you've removed the remnants of the oven element.
Sep 14, 2009 | Frigidaire Ovens
Goldstar MIcrowave stopped working when light bulb blew out.
when that happen to me i change the bulb and the fuse in of the microwave f the don't work send it to the company that made it and they should tell what wrong.
Mar 11, 2009 | Goldstar MV-1501 Microwave Oven
Wall Oven No Power
yes the oven thermal fuse blew when the fan went off its also called a tco switch if you pull out the oven and take the top off there will be a tech sheet there that will give the location of the tco some are on top some are on back this can also happen if the oven is too tight in the cabinet not enough room around it to let the heat dissipate its a round metal disc with two wires on it
Jan 30, 2008 | GE JKP30WMWW 27" Built-in Single Electric...
Leisure Cookmaster CM101NR Logo
24 people viewed this question
Top Leisure Kitchen Ranges Experts
Andrew Taylor
Andrew Taylor
ray gallant
Tom Chichester
Are you a Leisure Kitchen Range Expert? Answer questions, earn points and help others
