Question about Epson Stylus Photo R1800 InkJet Printer
Adding new media types in print box/How do you get them to show up?
I added many new profiles of papers, but when I go to print there are
only a few listed. How do I add the new ones in "print" in the media tab?
  • Anonymous Nov 15, 2007
    The EPSON R1800 Driver does not offer the user a way of adding new media types. You can go back and manually enter a custom ICC to match your paper, but it is a real pain in the ... . The driver keeps flipping back to default settings. All in all, I'll never recommend this printer to anyone.
I have the same problem........everytime I print a photo i have to reset everything
Posted on Feb 11, 2008
HP officejet pro 7680 print settings for iron on transfers
as a paper profile when loading use a paper that is nearest to the paper type being printed- EG- plastic sheets would become Vinyl paper/ transparency or banner profile.#
alternatively go to HP website and then to paper profiles and download the ICC profiles required follow the user manual to install to printer.
Jan 17, 2014 | HP OfficeJet Office Equipment & Supplies
When I copy to photo paper it reduces automatically, why
Print on special and custom-sized media
To print on special or custom-sized media (Windows)
1. Load the appropriate media. For more information, see Load media.
2. With a document open, click Print on the File menu, and then click Setup,
Properties, or Preferences.
3. Click the Paper/Features tab.
4. Select the media size from the Size is drop-down list.
To set a custom media size:
a. Click the Custom button.
b. Type a name for the new custom size.
c. In the Width and Height boxes, type the dimensions, and then click Save.
d. Click OK twice to close the properties or preferences dialog box. Open the
dialog box again.
e. Select the new custom size.
5. To select the media type:
a. Click More in the Type is drop-down list.
b. Click the desired media type, and then click OK.
6. Select the media source from the Source is drop-down list.
7. Change any other settings, and then click OK.
8. Print your document.
To print on special or custom-sized media (Mac OS)
2. On the File menu, click Page Setup.
Chapter 2
28 Use the device
3. Verify that the correct printer is selected.
4. Select the media size.
5. To set a custom media size:
a. Click Manage Custom Sizes in the Paper Size pull-down menu.
b. Click New and type a name for the size in the Paper Size Name box.
c. In the Width and Height boxes, type the dimensions and set the margins, if
desired.
d. Click Done or OK, and then click Save.
6. On the File menu, click Page Setup, and then select the new custom size.
7. Click OK.
8. On the File menu, click Print.
9. Open the Paper Handling panel.
10. Under Destination Paper Size, click the Scale to fit paper size button, and then
select the customized paper size.
11. Change any other desired settings, and then click OK or Print.
Print borderless
Borderless printing lets you print to the edges of certain media types and a range of
standard media sizes.
NOTE: Open the file in a software application and assign the image size. Make
sure the size corresponds to the media size on which you are printing the image.
You can also gain access to this feature from the Printing Shortcuts tab. Open
the printer driver, select the Printing Shortcuts tab, and select the printing
shortcut for this print job drop-down list.
NOTE: Borderless printing is not supported on plain media.
To print a borderless document (Windows)
2. Open the file that you want to print.
3. From the application, open the print driver:
a. Click File, and then click Print.
b. Click Properties or Setup.
4. Click the Paper/Quality tab.
5. Select the media size from the Size is drop-down list.
6. Select the Borderless Printing check box.
7. Select the media source from the Source is drop-down list.
8. Select the media type from the Type is drop-down list.
Print borderless 29
9. If you are printing photos, select Best from the Print Quality drop-down list.
Alternatively, select Maximum dpi, which provides up to 4800 x 1200 optimized
dpi* for optimum print quality.
*Up to 4800 x 1200 optimized dpi for color printing and 1200 input dpi. This setting
might temporarily use a large amount of hard disk space (400 MB or more) and will
print more slowly.
10. Change any other print settings, and then click OK.
11. Print the document.
12. If you printed on photo media with a tear-off tab, remove the tab to make the
document completely borderless.
Change settings from an application for current jobs (Windows)
To change the settings
1. Open the document that you want to print.
2. On the File menu, click Print, and then click Setup, Properties, or Preferences.
(Specific options may vary depending on the application that you are using.)
3. Change the settings that you want, and then click OK, Print, or a similar command.
Change default settings for all future jobs (Windows)
1. Click Start, point to Settings, and then click Printers or Printers and Faxes.
- Or -
Click Start, click Control Panel, and then double-click Printers.
2. Right-click the printer icon, and then click Properties, Document Defaults, or
Printing Preferences.
3. Change the settings that you want, and then click OK.
9. If you are printing photos, select Best from the Quality drop-down list.
dpi*.
print more slowly.
10. Select the media source. If you are printing on thick or photo media, select the
manual feed option.
11. Change any other print settings, and then click Print.
Nov 04, 2011 | HP J4680 Office Jet All-In-One Printer
Media is not picked up from the media tray
save the document to your desktop or copy and paste into word or notepad..
tell ya printer settings to clean nozzles.
remove paper.
place paper into tray area but not a whole lot....15-20 sheets...
now print...hows that..:-)
Sep 15, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Won't print on the photo paper
You didn't mention what paper you're using so for simplicity I'll assume it's an HP paper. When you installed your printer, it installed profiles for the HP papers and associated them with the printer. If you go to the Printers and Faxes folder, right-click on your printer and choose Properties, you'll get a dialog box for your printer. At the top it'll say something like HP Photosmart D7200 series Properties. Click on the Color Management tab, it'll show you a list of profiles associated with your printer. Your paper profiles will be named something like HP PS D6100_7100_7300-Advanced Photo. Don't worry about the names or selecting them, as long as they're listed you're OK. If they're not listed you'll need to re-install your printer software. Close the Properties box and the Printer and Faxes window.
Now go to LR, select your photo and go to the Print module. Scroll down the right panel until you get to the Print Job Header at the bottom. If you don't see any choices, click the triangle and open it up. Uncheck Draft Mode Printing and Print Resolution. Under Color management, click the triangles to the right of Profile:. This will open up a list of all paper profiles visible under LR. If you don't see your HP paper profile, click Other and it will list all the paper profiles on your system. Find your HP paper profiles and click the box next to each, this will make them visible in the LR drop-down. Hit Close and select the profile for the paper you're using.
Now click the Page Setup button, that will bring you to a dialog box where you can select your printer, page size and layout. Make these choices and then click on the Properties tab for your printer.
Now things get a little sticky... The HP driver has an infuriating habit of changing settings you've already made when you change something else. You'll come up in the Printing Shortcuts tab, ignore this and click on the Features tab. It's been quite a while since I used this printer so I may be wrong about the right order to do things, but here's what I remember: First, select your paper size. Click the Borderless box if that's how you want to print or uncheck it if not. Your Paper Source should be Main Tray for 5x7 or larger, Automatically Select for 4x6's that go in the top holder. Select Best or Maximum dpi for Print quality, then choose Paper Type, set it for Other Photo Papers since you'll be selecting the paper profile from LR. Hit the radio button for Print At Actual Size, go to the bottom and turn Photofix off.
Now go back to the top and click on the Color tab, select Print In Color and under Color Management, select Application Managed Colors.
Now go back to the Features tab and make sure nothing has changed. If it has, reset it, check the Color settings again, check the Features settings one last time. Then hit OK and you're back in LR.
Before you print, go over to the left panel and hit the Add button at the bottom. This will save all your settings and lots of time and aggravation by not having to go through the whole process again next time you want to print something. Name your profile with at least the size, layout and paper type you've set up and it will show up under User Templates. Then the next time you want to print on the same paper at this size, you just have to select this template.
Now hold down the Alt key, hit Print,
Nov 24, 2008 | Office Equipment & Supplies
I have Printmaster 10 and 17. On 10, I can print to the edges of the labels and others things, on 17 I can't. I know that I reconfigured 10 to do this, but it was years ago and I can't remember the step...
Custom Paper Wizard PrintMaster® 17 Gold and Platinum include a Custom Paper Wizard that allows you to add new or unsupported paper stock to PrintMaster® for printing labels, stickers, envelopes, half-fold greeting cards, note cards, business cards and postcards. The remainder of this note describes how to use the Custom Paper Wizard. Follow the procedure below to add a new or unsupported paper stock to PrintMaster® 17 Gold or Platinum using the Custom Paper Wizard.
NOTE: The options that appear in the Custom Paper Wizard vary depending on the project type for which you are creating new paper stock.
  1. In the PrintMaster® Design Workspace, click Tools from the menu bar, select Custom Paper Wizard and click New Custom Paper. The Custom Paper Wizard window will open.
  2. In the Select Stock Type: list box, select the appropriate project type (Label, Sticker, Business Card, Envelope, 1/2-Fold Greeting Card, Note Card or Postcard) and click Next.
  3. If creating a Label or Sticker paper stock, select the label type. An example of the selected label type will appear on the right.
  4. Click Next.
  5. In the screen that appears, select the similar stock type and enter the paper height, width and margins (if instructed to do so).
    NOTE: The Example box at the bottom of the Custom Paper Wizard window will explain what information is needed for the selected field (e.g., Paper Width, Left Margin, etc.) with both text and a diagram. The Example box on the left side of the Custom Paper Wizard window will show an example of the new paper stock as the fields are completed.
  6. Depending on the paper stock, the "Contains mid-page perforation" box may be active. If the paper stock that is added has a mid-page perforation, click once in the empty box to check it.
  7. Enter a Name for the new paper stock in the Name of stock: field and click Next. This name will identify the added stock type and will appear when creating a new project (e.g., Label, 1/2-Fold Greeting Card, etc.).
    NOTE: If adding a new paper stock for an Envelope project type, click Finish. A message will appear indicating that the new stock has been added. Click OK. The new envelope paper stock can be used when creating a new Envelope project.
  8. The next screen or screens that show will depend on the project type for which the new paper stock is added. Enter the needed information and click Finish. A message will appear stating that the new paper stock has been added.
  9. Click OK.
  10. To access the new paper stock, create a new project that uses the stock type (Label, 1/2-Fold Greeting Card, etc.) and select the name of the new stock entered in Step 7 (above) from the available stock list.
NOTE: If the paper stock that is added does not display in the list, click or go to Custom Paper Stock Does Not Display (Technical Note ID: 43399) for additional information.
Using the Custom Paper Wizard Tutorial
Consult the "Using the Custom Paper Wizard" tutorial in the Help Center of PrintMaster® 17 for additional information. The tutorial can be accessed in the manner shown below.
  1. Launch PrintMaster® 17.
  2. Click Help on the menu bar and select Help Center.
  3. Click the View or Print Tutorial icon (light bulb).
  4. Under Choose a Category, click Program Tutorials.
  5. Under Choose a Topic, click Using the Custom Paper Wizard
Oct 13, 2008 | Computers & Internet
Pixma MP610 problem: Just got this printer set up. Tried it a few times. I am running it with Mac leopard. When I try to print from the computer there is NO OPTION to set media type or page...
Make sure you are adding the correct driver..
Check print and fax under system preferences..
Make sure you are not adding the gutenprint driver which is embedded on your mac..
You can check the driver version, if you see gutenprint on your driver, delete it and re-add the correct driver.. it should say canonxxxx then try to check print settings again...
Aug 22, 2008 | Canon Office Equipment & Supplies
Printing on CD labels seem to ruin fuser in Phaser 7300
Probably the labels have a slight plastic fiber or coating in them and is getting a coating on the heat roller.
Here are part numbers of the correct CD labels you can run without a problem.
Xerox Matte Coated CD Labels, 6-Up, 11x17
Reorder 3R12373
75 sheets per box
spacer.gif Other items to consider: Return to Top spacer.gif Item Color Price/Unit Quantity Xerox Gloss Coated CD Labels, 6-Up, 11x17
Reorder 3R12372
75 sheets per box
Item Color Price/Unit Quantity Xerox CD-ROM Glossy Coated Labels, 4 x 7
Reorder 3R6322
50 CD-ROM Labels, 25 Sheets per carton
White - Glossy Coated 1-9 Box $17.44 10-49 Box $16.90 50-99 Box $15.65 100+ Box $14.89spacer.gif
Feb 22, 2008 | Xerox Phaser 7300DN Laser Printer
Printer issues
If you are using Glossy paper, when you go to print make sure to go into the printer Properties from the Print dialog box and select Glossy paper in the type. This will put the printer into it's highest print quality mode.
So from most windows applications, it would be :-
CTRL-P (to print with dialog box for changes)
Click on Properties
Select a Media type of glossy photo paper
Select standard or high print quality.
p.s. you may need to experiment which if the media types gives you best quality for the paper your using, unless it's Canon paper and then just match it up.
Oct 29, 2007 | Canon Pixma iP6600D InkJet Photo Printer
Epson Stylus Photo R1800 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
