Question about Karcher K 5.85 M Electric Pressure Washer
Karcher K 3.96 M will not build pressure - Karcher K 5.85 M Electric Pressure Washer
4 Suggested Answers
  • 33 Answers
SOURCE: karcher 2500 no pressure problem
sounds like you have an inlet blockage to the pump or not enough volume to feed the pump. make sure hose is turned full on when washing and see what happens. if not you may have to remove adapter wher hose screws in and check for a blockage.
Posted on Apr 21, 2009
wmpcs
  • 100 Answers
SOURCE: Our Karcher pressure washer just quit working, so
It really depends on the model of the machine, can you provide us with the model number?
Posted on Oct 29, 2010
  • 92 Answers
SOURCE: Tried to use my karcher
Dear jingles 2,
I am assuming that the electric motor turns and that the pump works also. I always try a test by removing the gun and try the machine without a gun...but very important with water being fed. NEVER run a power washer without water supply!! I remove the gun to test without load.
Now most probably your machine just the same will not build up pressure. If without gun attached, it builds up pressure...... you will surely see the difference.
Now if there is no pressure it could be a problem with the valves. To check this put on the machine with water being fed and without gun. Try to block the outlet with your hands or 2 figers ( HOPING YOU HAVE SAFETY ELECTRICAL SYSTEM!!!!).....if you feel from this outlet that your fingers are being sucked....then the suction valves need changing. There are 3 valves for suction (and other 3 for delivery)....if only one of them got stuck open, maybe with some dirt...the machine loses power.
You can test the other 3 valves by putting you fingers on the inlet for a few seconds....if you feel pushing...inlet valves are also faulty.
Loss of power could also be to a faulty regulating valve (Spill Valve). I rarely service spill valves...I always change with a new one. In fact if I service the Valves I change the spill valve.....and if I service the spill valve I change the valves. Ofcorce all gaskets must be changed.
If you are going to service your self...you have to open the cover (using a Torx screw driver T15)....then you locate the head. If you remove the head there is oil, which also have to be renewed.
The spill valve you find where you see 2 wires coming out from a place near the head. This calls for special Technician know how....but if you have the tools and spares neccessary...it is childs play.
I wish to add hat if a valve is found blocked but not damaged..you may not need to change the three valves. Check the valves by putting water into them placing them upside down....if by gravity the water escapes the valves need changing. Important that all 6 valves I advice to change if there is a doubt. Also before doing this did you check if the machine still stops when closing the gun? In fact I doubt it, because of the problem you mentioned.
Regards,
Fulltech.
Posted on Apr 24, 2011
Why won't my brand new karcher k2700 psi pressure washer start
no water connected to the machine
pull the trigger to allow pressure to build up or to switch the pump on
Oct 26, 2016 | Karcher Garden
Karcher K2.94 intermittent pumping and buzzing
try the machine with the lance removed from the gun.
buzzing is usually the noise made by the motor when it cant turn. if the pump start to pruduce pressure but the pressure builds up too high then the motor will stop turning... faulty lance or faulty spill valve (dump valve)
If you have a Karcher then you should always post your machines barcode.
The karcher barcode is on a silver sticker and is usually 15 digits long. Example 156987400000123 is actually model 1.569-874.0 and serial number 00123....
Aug 05, 2013 | Garden
My karcher 250 pulsates when i turn it on, any idia how to fix it thanks
Several things can cause this problem. It is trying to build up pressure and something is preventing it.
1. check water pressure comming out of the the spicket.
2. Make sure the hose and connectors aren't leaking.
3. make sure there isn't any water leaking from the washer.
If all is ok I would guess the pressure pump has gone out that's the noise you hear pulsating trying to build up pressure.
Terry
Jan 15, 2011 | Garden
My Karcher pressure washer pulsates and the water pressure is not as good as when I first got it
your pressure bypass valve is leaking water pressure by and not building full pressure
Sep 12, 2010 | Karcher Garden
Karcher K4.97M electric waterblaster cycling
It sounds to me like the unloader valve is bypassing internally.
Nov 16, 2009 | Karcher K2.26 Electric Power Washer
Karcher G 3050 OH the pressure is not constant, I think that is the pumps pressure regulator but I'm not sure
Check the suction line for leaks. It needs constant water
supply to build a constant water pressure. You may also
check the pressure regulator for leaks. You may also
check the carbide or ceramic pistons for breaks. Send you e-mail for further assistance.
Sep 06, 2009 | Karcher G2500PHR Factory Refurbished 2,500...
Karcher 2500 no pressure problem
Jul 13, 2008 | Karcher 2500 PSI Pressure Washer
Karcher K 5.85 M Electric Pressure Washer Logo
236 people viewed this question
Top Karcher Garden Experts
John Trevino
Are you a Karcher Garden Expert? Answer questions, earn points and help others
