Question about HTC G1
My HTC G1 phone won't just recently won't hold a charge longer than 30 minutes.... even it it is not being used. What can I do? The phone was purchased new last November
I plugged in my HTC g1 and it just vibrates and won't turn on.
try to complete the charging process before you power in your phone
Sep 07, 2011 | HTC G1
I lost my charger, is there any store here in manila that sells charger only
You can use motorola V3 charger as an alternative charger,htc charger is difficult to find and expensive as well,i'm also using the same phone as yours and i never had a problem using motorola charger,but if you really want HTC charger,you can go to CITY PLAZA at Quiapo,manila,but not sure of getting original charger,only class A is available,or even go to any mall nearest you,might spot original HTC charger as well.
Aug 06, 2011 | HTC G1
Can a htc g1 screen show without an simcard ?
Yes. A SIM card only holds the account information so the phone knows what account to charge minutes and other things to.
Mar 09, 2011 | HTC G1
My htc G1 won't turn on at all. The light doesn't even come on when I charge it.
try a hard reset......hold power and menu buttons togather to get phone reset menu....follow on screen directions and choose full system reset/restore.......
Dec 22, 2010 | HTC G1
I charge my battery for my G1 all the time but my battery runs out fast even when im not using the phone
Hi
The battery need to be replace. It is already weak.
Get the original battery from HTC company and charge for six hour.
Thanks
Aug 29, 2010 | HTC G1
After a hard reboot, my HTC G1 works fine, then locks up about 5 minutes later. I've tried both soft and hard rebooting. What's the next step?
Factory restoring is the next step. To do this, when booting the phone, you will need to hold the home button and power button as the phone is booting. Keep holding these even while the G1 screen is displayed. After about 30 seconds, the screen will change to a triangle. On the triangle screen, you will then wait approx. 5-10 seconds and then press the home and power buttons one more time. This will bring up an options menu that will let you wipe and restore your phone settings. As long as you have your gmail information in the phone, you will not lose your contacts.
Apr 10, 2010 | HTC G1
My tmobile g1 doesn't hold a charge. i get up to 90%, 100%, even 70% charging at night, remove from my computer (charging source), next morning the battery is dead not using it at all. please help, this is...
did you FULLY charge it the first tim eout of the box before using it? They say if you dont do that, the battery will never fully charge... def a bad battery tho!!!!
Aug 26, 2009 | HTC G1
My G1 worked perfectly fine last nite and this morning it didn't turn on please help!!!!
if none of these suggestions work your phone is defective...hold the power button longer to turn it on. if not that your battery is dead. if your phone isnt charging up, your battery charger is defective. if you know someone with a usb charger, you can try theirs
Aug 19, 2009 | HTC G1
G1 keeps turning off by itself
g1 keep cutting off when im using the phone and turns it on and it cut back off and after charge phone it work right for a minute and turn back off
Jun 21, 2009 | HTC G1 Smartphone
T Mobile G1 GPS Problems
G1 Gps Problem Fix - I recently had the same issues with the gps giving me the location of cell towers instead of actual location. After looking around the forums, i found the fix and it worked.
Clear you maps cache by going into your application data.
Settings : Applications : Manage Applications : Maps : then push "clear data"
Make sure both your wireless and gps are turned ON
Turn off Phone
Take it outside somewhere that is clear of obstructions (like a large parking lot, or field)
Turn on phone
Once on, press maps
Let it sit in one spot for about 5-10 min, then press my location.
It should find you in just a few seconds. Mine took about 30 seconds.
This should fix most problems you are having.
Oct 26, 2008 | HTC G1
HTC G1 Logo
113 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
