Question about Dirt Devil Breeze Bagless VacuumVacuum
Vacuum stopped running - Dirt Devil Breeze Bagless VacuumVacuum
Agitator bar on UH4700RM wind tunnel doesn't turn
Unfortunately you machine is a re manufactured vacuum and has a 6 month warranty. (The RM suffix indicates this ) You should take it to your local vac shop and let them look at it. It's probably a minor issue.
Aug 08, 2017 | Hoover U6630-900 WindTunnel Bagless...
Tip
What to do when your vacuum brush stops spinning
Household vacuums come in all shapes and varieties, but many of them are similar on the inside. There is often a brush running across the length of the vacuum's nozzle, and it spins as the vacuum runs to help **** up debris. But sometimes the brush will stop running, and you'll notice a severe decline in your vacuum's performance.
Usually when the brush stops spinning, it's because something inside the vacuum is binding it up. Dirt can get lodged inside, and hair can get wrapped around a shaft. If there is too much pressure, the drive belt can even snap.
You can usually see and clean the brush just by turning the vacuum upside down, but to get to the other internal parts you have to take the vacuum apart. On canister vacuums, this is usually pretty easy because it's just the nozzle that needs to come apart. Full-size vacuums can be taken apart as well, but the process can sometimes be more involved.
If you can get the nozzle or the vacuum's base apart and get to the parts inside, you should see the brush (which is part of a long shaft), a drive belt, and some sort of mechanism that drives the brush, which is commonly a paddle or a motor.
Hair can get caught up in any of these components and cause them to not be able to spin, as can dirt and other debris. If you clean all of the components out and put the vacuum back together, it should work just fine. The brush, over time, may become frayed or damaged, and the drive belt sometimes will snap, but otherwise a good cleaning will usually make your vacuum run as good as new.
on Jun 01, 2010 | Vacuums
Hoover 5163 Fold Away
Cutting out the thermal protector is a way assuring a sale of a replacement motor in the near future.
Apr 04, 2014 | Hoover Vacuums
Won't turn on stop running in the middle of room.
Mine did the same thing. The electrical cord is loose where it plugs into the machine. When you pull the vacuum into the room it puts just enough strain on the cord to break the electrical connection. Push the plug on the cord firmly into the vacuum.
Sep 08, 2013 | Eureka 3276AZ Pet Lover Bagless Upright...
My bissell ran over the cord and stopped sucking
The belt probably broke or stretched and that is why it stopped working. Here is the belt you need:
Bissell Lift Off Belts
Feb 07, 2010 | Bissell 3750 Lift Off Bagless Upright...
Motor won't stop running
You have a bad relay board. An Electrolux dealer can get you a new one.
Nov 10, 2009 | Electrolux Central Vacuum
Vacuum stopped working and wont run
Check the cord to be sure its not broken anywhere.
Check the roller, it may be clogged
Oct 30, 2009 | Oreck XL Ultra Bagged Upright Vacuum
It just stopped running.
This most likely is your electrical switch on the vac. you will need to take it in for repair. simple cost effective repair
Oct 26, 2009 | Hoover Vacuums
I was vacuming and it stopped running. will not
either you have a break inside the power cord or the wires have come loose on the motor.
Jul 31, 2009 | Eureka 4700A Maxima Bagless Upright Vacuum
Fantom vacuum
sounds like a partly clogged filter
Mar 10, 2008 | Fantom Vacums FM741 Twister Bagless...
Dirt Devil Breeze Bagless VacuumVacuum Logo
29 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
