Question about Kenmore 30 in. 42474 / 42475 / 42479 Electric Cooktop
My burners go from off to hot. What needs to be replaced?
  • 82 Answers
If you don't have any temperature control, the switches probably need to be replaced.
Posted on Jun 19, 2009
My left front burner was turned off for almost half hour but remained hot. the hot surface light was still lit. I had to throw my main breaker to turn it off. What could be my problem
Sounds like the thermostat on that burner gas gone. When you switched the breaker back on, did the burner get warm after being cold? If so, you need a new controller. They are easy to change if you can get to the back of the unit. Make sure you turn off the breaker and physically remove the plug.
Nov 24, 2013 | Whirlpool RCC3024 Electric Cooktop
Burner stains Hot cookie sheet accidently set on
abrasive cooker cleaner. and pad. should clean it off. give it a good scrub.
Oct 27, 2013 | Kenmore Cooktops
Large burner elements ignite, and igniter spark fails to stop, then the burner shuts off as if ignition failed. Tiny central burner element does NOT light at any time. Apparently the safety cutoff...
There is a thermistor that must be in the flame area that needs to get hot. When hot it will turn the igniter off and keep the flame on. Check it's location and if it is in the flame then it needs to be replaced. not sure about the central flame problem. could be the switch.
Sep 20, 2010 | Gaggenau 36 in. KG 291 Dual (Electric &...
Both 6" plates on samet hob not getting hot enough. Replaced both plates changed, but still have same problem, not getting hot enough. What can problem be? Plates are getting hot but not hot enough to boil...
-The burner itself has burn connector. Take it out and check. If it burn very bad then need to replace new burner. Or may be the connector itself.
Good luck
Mai
Jan 25, 2018 | Cooktops
Burner light stays on
This is caused by a faulty sensor that is located between the burner element and the top. To replace the faulty part you will need to uninstall the cooktop and remove the glass top. The sensor is a rod a little smaller than a pencil that you will see right on top of that burner.
If you choose not to replace the sensor it will not cause any issues other than you will have to live with that light constantly on and you will know when the top is hot for that element.
Jun 19, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
One of the burners on my Jenn-Air electric cooktop does not turn on and get hot. 3 burners do work. Any suggestions?
the contact may be loose but most likely the burner needs to be replaced. the one you use the most usually goes first, and not getting hot enough is the common indicater of a shot burner
Jul 09, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Great old Jenn Air range needs advice!
YES THEY USE DIFRENT SWITCHES AND IF THE 1 YOU HAVE PROBLEN IS THE DUAL BURNER THER IS A SERVISE FLACH ON IT YOU NEED TO GO TO SERVISE MATER.COM AND FIND THE UPGRATE
Jan 25, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Burners of electric cooktop not getting red hot
Hello
Welcome,
Sounds like you have a bad surface heat controller.
Nothing to do but call a hands on tech to replace a part.
please remember to leave a rating before you sign off
Dec 11, 2008 | GE 30 in. JP340 Electric Cooktop
Looking for Cause of Fault Code on GE Range top JP939
Have SAME EXACT issue - F113 on Left burner. Indicator says HOT and not even on. Called a service company (NOT GE SERVICE). They said the Element Radiant is no good and must be replaced. Part is quoted as $323.98 !!! What a rip off from GE !
Jul 02, 2008 | Cooktops
Burner too hot
you set it fro low and goes straigt to high???? no adjustment in heat setting either of or high?? if so youll need to repalce the infinte switch controllins that burner
Mar 11, 2008 | GE 30 in. JP326 Electric Cooktop
Kenmore 30 in. 42474 / 42475 / 42479 Electric Cooktop Logo
65 people viewed this question
Top Kenmore Cooktops Experts
mcgsp
Level 1 Expert
Kolbrun...
john mabry
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
