Question about Samsung SCH-a670
Charger wont charge the phone - Samsung SCH-a670
Samsung galaxy Y pink wont charge
i tHink iNnn yOur cEll pHone cHarging piNn iZzz dEstroyed !!....!! rEpair yOur cEll pHone tHen iTz wOrking !!....!!
Apr 07, 2013 | Samsung Galaxy Y Gt-s5360 Pink Factory...
Phone randomly turns off Wont hold a charge with a new battery, wont charge when connected to charger
Theres a possibility that the IC on your phones motherboard was damaged. if you already tried known good battery and charger and still wont get any charge then your phone motherboard is alread damage and needs replacement or you can buy a standalone charger for your battery.
hope this help
Sep 03, 2010 | Cell Phones
When I plug in the charger it wont charge Im not getting like unauthorized charger message it just wont charge
I advice you try get a similar charger to charge your phone, if the similar charges your phone, it means your charger is bad and will need to get another charger or the phone.
But if it did not charge and you still get the same message, it means the charging port on your phone is the problem, the charging port on your phone is bad and can not read the charger, so you will need to replace or change the charging port on your phone. Doing thi will solve the problem on your phone.
Take care.
Jul 19, 2010 | Motorola Mobility Hint QA30 Cell Phone
My sanyo pm 8200 wont hold charge!
Since the battery and charger are new and yet it does not still hold charge.
Have put the battery in another similar phone and try to charge with your charger to see if it will hold charge? if you have.
It means the charging port of your phone is bad and you will need to replace it.
The charger is not charging the battery in anyway because the charging port is bad, so just change your charging port, your phone will now hold charge.
Take care.
Apr 14, 2010 | Sanyo PM-8200
My phone wont charge.... i have bought a new battery, charged it for 24 hours, and it still wont charge. even when it does charge it wont keep the charge for more than a day. why wont it charge. plzzzz...
It could be the charger itself that has the issue. If you have another charger try that. If you have done this and it still won't hold a charge I would contact your service provider they will try to trouble shoot issue but more than likely will get you to send phone in through warranty if your still eligible. If not eligible for warranty and don't have insurance ask about upgrade options. Hope this helped.
Apr 13, 2010 | Samsung Blackjack SGH-I607 Smartphone
Razor cell phone wont charge
steps... 1) check by using another charger...if it gets charged then change ur charger.. 2)if its not getting charge then replace the battery and then try charging...if its again not working then battery problem..change it 3)if the battery s in proper condition then the problem s with the phone charging socket..change it for cost!!!!!!!!
Oct 26, 2009 | Motorola Mobility RAZR V3
Wont charge
Try a car charger. If the car charger works, then it is either
A) Your power outlet
B) Your wall charger Power Supply unit
C) The phone connector on your wall charger.
If it doesn't work on the car charger, then it is most likely your phone charging system or the connection for charging on your phone. Either way, you will most likely need a new phone. Sorry.
Sep 23, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Env2 charger wont fit in the hole and wont charge my phone
The issue is the charger port on the ENV2 breaks fairly easily. Thefirst step is to contact your carrier to see if it is covered underwarranty. If it is, great get it replaced.
If not, you have 3 options:
1. you can get the charging port repaired. The cost is about 50 dollars. I recommend Cellulardr.com
2. you can get a new phone. cost ???
3. You can get an external battery charger to charger the battery separatefrom phone. cost about 25 dollars. Check out the following link forones that are available on ebay. A extra battery is a good idea as well so you can have one charging at all times.
LG VX9100 ENV2 External Battery Chargers
Hope that helps
May 28, 2009 | Verizon Communications enV2 Cellular Phone
Battery wont charge in phone or charger that came with it? how can I charge it?
battery may be bad and need replaceing, or the charger has a short in it or is not functioning properly. if you plug the charger into the phone its self the phone should come on with or without the batery in it. if it dont then i'd try a different charger or get a new one.
May 10, 2009 | Cell Phones
NOKIA 6600 wont charge and turn on
hey,
how about check your charger .. maybe there is a problem with your charger... try another nokia charger
Cheers
Aug 28, 2008 | Nokia 6600
Samsung SCH-a670 Logo
12 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
