Question about Canon Ir1018 Ir1022 Fixing Unit / Fuser Unit - Part Number Fm2-9046-000
How change paper feed roller ir 1022 - Canon Ir1018 Ir1022 Fixing Unit / Fuser Unit - Part Number Fm2-9046-000
muleskinner2
  • 270 Answers
SOURCE: repeated paper jam in the fuser unit
There could be two problems with the copier:
1. There has been a Canon mod for the two pads already suggested earlier. Remove the two pads and place a foam strip that is runs across the top of the lower right access door basically between those two pads. This creates more even pressure across the deflector for the upper paper cassette.
The style of roller above the exit for the paper cassette is now gray in color instead of black.
Posted on Nov 13, 2007
SOURCE: paper jamming and feeding unevenly
I have the exact same problem. Until last night it worked perfectly, and when it ran out of paper, I put more papers in the back of the printer correctly and since then it won't print, it pulls paper to the right and the paper jams. I tooked the printer to the service and they say that I'm lucky that the warranty did not expired yet, cause the problem is a "manufacturing mistake", and that they will take it to the Canon service.
I realy hope they will do the job. I'm expecting to repair be done till tomorow.
Posted on May 08, 2008
mohammed387
  • 1952 Answers
SOURCE: Paper Jam on Rear
clean this roller
Posted on Jan 22, 2009
SOURCE: canon pc 420 paper feeds only part way
I had the same problem. I found a parts diagram here http://techno-parts.org/canon/220/320_220.php which showed that the springs hold the bar down. On mine, on each side, one of the spring tabs was broken.
I made a metal pin for one side and insert a screw on the other. Be sure and wrap the spring over the nylon bushing.
Posted on Apr 04, 2010
Joed911
  • 4338 Answers
SOURCE: Paper feed issues when there
85% of paper jams are caused by worn rollers . The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Replace the pick-up and feed rollers.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on May 19, 2011
Removed foreign object inside your printer. then turn off.. the red light blinks and can't feed the paper..
This seems to be fault in the transport of the paper in the rollers. So if you have used any adhesive sticker printing, it is possible that some glue has got clogged into the rollers. If not there can be some jammed paper in the rollers or the mechanism.
So start this work only if you are mechanically able with the right tools.
Remove the covers to get access to the mechanism . Remove the motor drive assembly , the fitting of the motor to the mechanism. Once this is removed the rollers can be turned manually so that you will be able to feed a paper to see the progress of the movement while studying if there is any obstruction or damage to the paper.
There is a in-detect sensor, usually an opto-coupler , make sure this is not clogged or dirty as this IR detection feeds the signal to the processor for starting the motor drive feed.
Reassemble but make sure the rollers are aligned to be in equal gap to feed the paper without a side pull. Now you must print and see if the fault has changed. If not repeat the above work to confirm the area of obstruction.
Feb 09, 2011 | Office Equipment & Supplies
Paper can not feed into printer
Feb 07, 2011 | Canon PIXMA iP1300 Printer
PRINTER IS SAYING THERE IS PAPER JAMMED AND IS NOT FEEDING PAPER THROUGH BUT I CANT FIND THE WHERE THE PAPER IS JAMMED OR HOW TO ACCESS THE ROLLERS WHERE IT MAY BE JAMMED PLEASE HELP
Jan 24, 2011 | Canon Pixma MP450 All-In-One InkJet...
My espon nx300 printer keeps feeding the paper crooked. It crinkles on the right side of the paper, causing the paper to jam each time.
Nov 03, 2010 | Epson Stylus NX300 All-In-One InkJet...
Paper stuck or jam in rollers
Oct 30, 2010 | HP Deskjet 870cse Printer
Uneven copy quality- Canon Copier
If the toner isnt burned on paper it means that you have to change fixing roller bushings and fixing roller.
Because you have uneven pressure between fixing and press roller
May 27, 2010 | Canon imageRUNNER 1023iF Black and White...
Paper get jaming often.plz give mew solution
Some ir-2230 have an pressure problen on right lower door.
But check the pick up,feed,separation rollers, vertical path rollers,..... clean it, change it,...
Or send more detailed question-Why,when,how....
Oct 28, 2009 | Canon IMAGERUNNER 2230 Copier
Paper feed problem
With that many labels I would replace the paper feed roller, RL1-0266-000, about $8.00
it will save you lots of headaches and a spare will fix it next time it happens.
Sep 01, 2009 | HP LaserJet 1022 Printer
Canon Ir1018 Ir1022 Fixing Unit / Fuser Unit - Part Number Fm2-9046-000 Logo
71 people viewed this question
old marine
old marine
