Question about Acer Aspire 5100 Notebook
Screen wont come on
Didi boot up normally then half way threw a task i was doing laptop told me its got a problem and shut down now i carnt get screen on. thankyou
  • meli19x Nov 07, 2007
    whenever i turn my laptop on, the machine is running and you can hear that its on but the screen continues to stay blank and wont come on at all....can you please tell me what 'os' is, that i have to reinstall as stated on someone elses reply who has the same problem as me.
  • Lishie Williamson
    Lishie Williamson Nov 13, 2007
    screen says going to sleep and nothing else happens
  • 1,006 Answers
Posted on Nov 03, 2007
I want to factory reset my Hp 15-1039wm but i have no disc i was told do from command prompt how do it
First of all, try the following.
Boot the computer normally and log-in.
At the black screen, hold down the ctrl and alt keys and press delete.
Select Task Manager.
Click on File and select Run new task.
Type rstrui - also enter a tick in the box for 'Create this task with administrative privileges' - and click Ok.
When the system restore interface has loaded, pick a restore point at least 48 hours ( or the earliest one available if less than 48 hours ) before the log-on issue first occurred and then proceed with the system restore.
If the above doesn't correct the issue, try running through the procedure detailed in the link below.
Mar 23, 2015 | HP Computers & Internet
I don't no my password but i didi not change the password
Try booting the computer to safe mode...this is accomplished by starting up the computer and just after the BIOS screen, press you will see a list of options....go to safe mode and press enter....when you get to the screen that has the administrator....once in, go to control panel, then user you can select your user account and reset or remove the password...once you've done this ypou can shut down and restart it normally
Apr 26, 2011 | Computers & Internet
My Sony Vaio VGN-NS110D Laptop computer won’t boot up, it cycles through to a black screen with the mouse pointer there which I can move. Apparently this is called the ‘black screen of death’! I can’t do...
Try these 1) Shut down the system 2) Remove the battery 3) Hold down the power button for say 2 minutes 4)Put the battery back 5) Boot the system
If you still hit the black screen with a cursor: 1) Wait for 2 mins at the black screen 2) Just type in your windows password (if you don't have one hit enter) and press enter 3) Wait for another 2-3 mins 4) Hit Alt Ctrl Delete and go to task manager (this time it should take you to the task manager) - fingers crossed LOL 5) Now do new task - explorer.exe
Hopefully you should be back in action.
Note, this is a work around and for a permanent fix either try and clean your system (check for viruses) or reinstall the system. Hope this helps.
Oct 07, 2010 | Sony Computers & Internet
My Compaq sr1800nx desktop boots to a black screen with white text with the options of F1 setup or F2 continue instead of the normal boot up. If I select F2 it will continue and boot up normally.
Sounds like you have to open task manager. probably threw ctrl+del keys together. then once the task manager is open you have the option of typing explorer.exe
once the windows desktop apears go to start then run and type chkdsk c: /R this will recover bad files that are possibly missing from the boot volume. the issue happens when software tries to alter the master boot record where windows load's the operating files off of the main drive root partition. hope this helps you.
Good Luck
Aug 12, 2010 | Compaq Presario SR1800NX Desktop PC
Dell Inspiron 1545. When booting to vista the screen goes black. When booting to safe mode the screen works normally.
Please reinstall the Video Driver and check if the same issue persists. If the issue started within last 90 days, you can try the System Restore
Jul 01, 2010 | Computers & Internet
Wont display the desk top
Try rebooting, tap F8 to get into the multi-boot options. Scroll down and choose "Last Known Good Configuration" windows should boot up normally. If you have made any hardware changes or if windows perfromed a corrupt update, that will require some additional help.
Jan 12, 2010 | ASUS Eee PC 701SD
My dell inspiron 1525 continuously keeps locking up. The screen just freezes up. I am unable to bring up task manager or hit escape. The only thing I can do is shut the power down / bring back up. This is...
Try this steps:
Turn off your laptop.
Power own your laptop then press release the F8 key until this option will popup.
Select Safe Mode.
Wait until Windows succesfully boots up using safe mode.
If you can succesfully log-on on your Safe Mode.
Press Windows Key + R
The run window pops up type MSCONFIG
Click Start Up as show below
Uncheck all check Items and click OK
Reboot your laptop and boot windows in normal mode...
Hope this helps...
Oct 21, 2009 | Dell Inspiron 1525 Laptop
Laptop boots then shuts automatically off
If you haven't tried it yet, pull the battery out and try booting from the adaptor only. If it boots normally, then your battery pack may be bad (shorted cell) or the regulator that has the job of charging and monitoring the battery pack while keeping your system running may not be healthy.
If you own any multimeter (at the cost of Chinese DMMs, everyone should own one), check the battery pack for charge. Under normal conditions, they should measure a couple of percent higher than their rating. You will have either Lithium Ion or Nickle metal hydride batteries in the pack so should measure some multiple of the nominal cell voltage of one of those types that are respectively 3.6 & 1.2 volts.
Nov 28, 2008 | HP Pavilion dv9000z Notebook
Start up problem.
Does your laptop come with a recovery disc? If so, insert the disc, turn off pc, boot it up from the cd and do a start up repair.  Your OS start up is got corrupted. Don't worry, start up repair won't delete your data, it will only re install the OS start sequence.
Hope this helps.
Sep 14, 2008 | Dell Inspiron 1300 Notebook
Computer will not shut down
You can try the Ctl-Alt Del keys to see if you can get the task manager to come up. If you can then try to shut down using that. If not then the only choice you really have is to manually power down and restart. Chances are pretty good Windows will clean up after itself and should boot backup. During the process if you receive any error messages or warnings document them. Windows may also prompt you for a hard drive scan, let it. Let us know what happens and please don?t forget to rate this post.
Apr 16, 2007 | Compaq Armada E500 Notebook
Acer Aspire 5100 Notebook Logo
65 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
