Question about Microsoft Xbox 360 Console
How do you open the top of and xbox360? because i think something fell loose inside because the power wont work and it doesnt have red rings.
    Problem Solver:
  • 5 Answers
Go here
Posted on Jun 19, 2009
  • someguy13o Jun 19, 2009
    dude cant count tho theres actually 7 of those slots in the back.
    oh and also u need a torx 8 for the black screws and a torx 10 for the silver screws. i heard there might be gold screws in there too, and its the same thing. those would be torx 10 also.
After a piece of gyprock fell on top of the washing machine, it now no longer has any power.
as its a front loader
a few things can happen
i think you need to take the top off the machine
and using the plug for the mains
and a DVM meter {cheep } use ohms setting like 20 or beep or both
and then from the plug follow the mains from the plug
to the supply inside the machine
examine where the cable goes in etc
look for 'open circuit ' lines
if the two likes connected accross from mains in to inside
doesnt beep the wire is disconnected
L N should power on lines enable
your shure to track it down this way ...
machine dont have internal fuses
i think its a chopped cable cracked board or loose plug
rule out the obvious and what ever left must be the truth
it could have even just knocked off a plug on the main controller.....pcb
{underneath at the back right ..}
Jun 04, 2015 | Asko W6441 Front Load Washer
Power button pushed troughand fell it to the case, tv wont turn on power
Sounds like something came loose inside, the button falls in when the circuit board comes loose or breaks. You have to open the unit up and see what is broken or loose...
Nov 23, 2010 | Sanyo DS32224 TV
It wont turn on, it wont charge, Power Supply? how to fix it?
It's broke. Would probably cost more to fix it then to buy a new one.
If you are so inclined though, you can try opening up and see if you can find something loose.
Apr 04, 2010 | Nintendo Game Boy Advance SP GBA Red...
Xbox360 screen wont show
If it's under 3 years old and you've never opened it up then Microsoft(1-800-4MY-XBOX) will fix it under warranty. Otherwise you'll need to do the x-clamp fix. I've used the kit from http://www.llamma.com/xbox360/repair/ring_of_light_x-clamp_fix.htm to fix this problem for a friend. Good luck
Jun 12, 2009 | Microsoft Xbox 360 Console
Rings of death
the "3 rings of death" or the so called "3 red lights" is actually caused by GPU overheating and mainboard flexing. When you need to do is open your xbox360 (warning, this will void your warranty) add more cooling fan inside your xbox360, you'd want to use 80mm fans coz they fit perfectly. you can fit up to two 80mm fans inside your xbox360.
Also, if you notice that your xbox360's mainboard is warped you need to fix this by disconnecting all the connections from the board. then place the board on a flat surface. then use a hair drier to heat the board and flat it out. its kinda complicated. hehe, at least you now have an idea on whats causing the 3 red lights...
May 01, 2009 | Microsoft Video Game Consoles & Games
Sound
I just fixed mine. No ring or external sounds following a short drop. Found a loose internal header on the back, right side of the phone.
Remove back.
Remove battery.
Remove SIM.
Remove 4 screws (note will void warranty)
Starting from top, carefully de-attach rear plastic cover.
Inspect. Header on right side as you look at the back of the phone has black/white wire going to speaker.
Reattach.
Re-install in reverse order.
Crazy phone still works great!
R
Apr 07, 2009 | Cingular Wireless Cingular 8525 Smartphone
89 mustang door wont open from the outside.
i think i would spray it again instead of wd40 get some P.B. Blaster works 10x better for loosening rusty parts.id try that since it worked before. you can get P.B. Blaster at walmart or parts stores.
Dec 08, 2008 | 1989 Ford Mustang
Red lights games wont load
Hi calleyne
Im going to take a huge guess here and say your problem resides with the xbox360 and the three red lights on the ring of light around the power button,
ok there are 2 options you can take,
one, you can call Microsoft for a repair box, the good thing about it is now they will still repair it if its out of warranty, the bad part about it is they charge $100 and it can take some time before you get another 360 from them,
two, you can open the xbox360 yourself and see whats wrong on the inside, **note that even if you do this you can still do option one** the main things you can check are the processor, heat sinks, the disk drives, and the gpu and the heat sink on top of it, i found that what was causing my first xbox360 to get the red ring was the heat sink over the processor was touching and was causing it to get super hot, but really all you should have to do is lift the heat sink off the processor and put some liquid coolant like you would on a pc and place it back, thats what i did at least.
Hope that helps ^-^
Jul 29, 2008 | Video Game Consoles & Games
XBOX FREEZE
if you have 3 red rings on the power button aswell then you have to send it back to micosoft xbox360 .they will fix it for free.all xbox360 have a 3 year warrant.that what happen to mine and a have had mine for over a year too.
Apr 17, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
97 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
