Question about Boating
Shakespeare lx 2500 ultra lite
I need the line roller and all washers and screws associated withat part of the bail.
3 Suggested Answers
#1 Taper
  • 1040 Answers
SOURCE: NEED INSTRUCTION SHEET FOR LINE INSTALLATION
If it is a duel line trimmer then:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
If it is a single line trimmer: Then just wind a single piece of string clockwise onto spool. This may need to be longer than 7ft.
Jim
Posted on Dec 02, 2009
  • 74 Answers
SOURCE: Do you know where I can get a replacement remote for the Proxima
The projector is kinda old but your best bet would be ebay or call projector doctor. I know from time to time they have some old remotes.
Posted on Apr 21, 2010
My line won't rewind on my Shakespeare Encore reel. After casting, the bail snaps in place, but when I reel in, the line won't reel in. The spool turns with the bail, but doesn't retriev
Your line is on the wrong side of the bail. Rethread the line so its over the bail so that after the cast you flip it up it catches the line and retracts it.
May 05, 2012 | Sport & Outdoor - Others
Does not flip arm to lock to reel in line
Normally when you **** the bail, the reel allows you to discharge the line with a flip of the wrist. Then when you touch the crank and execute half a turn it releases the bail to lock the line and allow you to reel in. If this action is not happening, then the release pawl is stuck and holding the bail in place. You must disassemble the reel, clean the parts and re-assemble with proper lubrication. Checking the parts for wear replace all worn parts.
Jun 22, 2011 | Shakespeare Agility Spinning Reel 6825
I have a Shakespear Tiger model TSP50A. I cannot set the on/off so that the handle ends up going both ways. I inspected the gears and suspect a manufacturing defect. I have had it for over 3 years but used...
Remove the spool, you'll find a little screw by a hex nut, remove the little screw then you can remove the hex nut. by removing this nut you will be able to remove the whole bail assembly. There you'll find the workings of the on/off leaver. There is a fine spring that raps around a brass piece that looks like a washer, looking at it from the side you'll see a grove in it, that is where the spring goes then to the leaver of the on/off control. This spring hardly has any spring to it so don't think it needs a replacement. If the spring is in place check to be sure that the knob isn't striped. Just take the little screw off that holds it in place and inspect it. I hope this helps!
Jun 17, 2010 | Shakespeare Agility Spinning Reels
How to thread a Shakespeare fishing rod and reel
feed the line down through the eyelets on your pole ,now open the bail on your reel tie the line on the spool,and start reeling(keep tension on the line,prevents line from tangling) when i resting mine I only go about two thirds on my spool.
Jun 05, 2010 | Shakespeare Agility Spinning Reel 6825
Need a Popeil Pocket fisherman manual
For the original pocket fisherman. I believe the design has not changed. Once you do it the first time it is actually quite easy.
Two things to note. Read this whole thing first.
1) the location of the bail spring (Keeps the metal bail cover up so line does not get stuck when casting.
Note: This is important cause the metal bail cover must rise enough so that the line casts smoothly. (A complaint about this product. But when calibrated correctly it is quite good for what it is)
2) The little **** that the crank gear plastic housing will fit into (Must be on top when you put the whole bail back in. The crank shaft lip fits into that ****.You'll get it when you see it.
Remove the panel screws (2) as you did. Pop out the crank shaft (copper). **** is in top when replacing. (remember that). Remove the bail. On the top of the bail there is a screw. ( becareful and remember how the little metal bail spring in situated here. Turn upside down with metal bail cover in your palm as it conects to the bail spring). Pull off metal bail cover. The plastic line holder actually comes apart and holds a lot more line than you think. Replace line. Feed the line back up the rod. Assemble the opposite.
Feb 05, 2010 | Sport & Outdoor - Others
Need to know were the long spring on my sons spider man rod and reel goes
The long spring (only one in the reel) goes under the bail arm plate. To get it back in, remove the plastic cover plate on the side that pickes up the line (has a line roller on that side). The spring will fit over a small metal or plastic post and rest in a cavity at the bottom.
Screw the cover back on and you're good to go!
Best of luck
Mike
Sep 26, 2009 | Shakespeare Surf Fishing Rod and Reel...
Need the manual for the popeil pocket fisherman. I have one that is not working properly and need to fix it
Sep 08, 2009 | Omega Juicers Rock & Ice Climbing
What do you do with the line before threading it through the eyes
Take the line off the spool in such a way that the line will be caught by the bail after you cast the line. The easiest way to get it right is to raise the bail like you are going to cast the line, thread the eyes, then trip the bail with the handle, as though you were reeling 'em in.
Happy fishing. I'm jealous.
Best regards, --W/D--
Jul 20, 2009 | Shakespeare Surf Fishing Rod and Reel...
How do you cast?
flip the bail(the round rod in front of the reel)hold the line tight with your finger first and cast(make sure you let your finger off the line when you throw the rod forward.
Jul 17, 2009 | Shakespeare Agility Spinning Reel 6825
Boating Logo
57 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
