Question about HP StorageWorks Ultrium 920 LTO-3 Tape Drive
Hp lto 3 blinking - HP StorageWorks Ultrium 920 LTO-3 Tape Drive
How do I take apart an HP external lto drive?
If you never did, or don't have a manual, I would not do this. I think if you have the correct tork screw drivers and Philips screwdrivers you could open the drive. If it is to remove a tape, this is as far as you can go. If you disassemble the drive, I don't think you can get the timing correct. It would make the drive worthless.
Jul 25, 2014 | HEWLETT-PACKARD HP LTO3 TAPE DRIVE...
Canon ir 2230
Hi Sharma
I think you might need to review this question, The Canon IR2230 does not use LTO Data tapes.
Refurbished Tape Drives Stock List for download Refurbished LTO drive
May 13, 2013 | Imation 17533 Storage media - LTO Ultrium,...
Hp storageworks ultrium 448 drive light blinks orange
Hi John, not sure from your description which light you refer to.
But this sounds like your drive has either had a read / write issue - in which case you need to run a new cleaning tape through the unit and then retry using a brand new data tape - OR it has had a damaged tape loaded into it which has now broken the tape drive.
If the drive has been broken then try contacting www.tape-drive-repair.com who can repair or replace it for you and also look at
http://tape-drive-repair.com/tools-and-information/lto-media-inspection-guide/
The guide will tell you how to inspect ypoour media for damage and prevent you from reloading a damaged tape which will break your drive again
Sep 12, 2012 | HP StorageWorks Ultrium 448 LTO 2 Tape...
Ultrium LTO 3: Tapedrive won't accept tape / can't put in tape
the take up arms are not working it must go into a shop for pro fix this is a complex fault .
make sure the repairer is well trained with this type of machine as most are not
Jul 02, 2010 | HP StorageWorks Ultrium 960 LTO-3 Tape...
Tape drive HP LTO-3 (storage works ultrium 960) repair
You can download LTT from www.hp.com/support/tapetools
stop all the backup services services and perform a test
Apr 19, 2010 | HP StorageWorks Ultrium 960 LTO-3 Tape...
Blinking Front LEDs
It sounds like the drive is getting confused
Check all cables and try new ones if possible as well as the terminator.
Again try and make it the only device on the bus if you can.
Try upgrading the firmware with the hp ltt program
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=406731&lang=en&cc=us&taskId=135&prodTypeId=12169&prodSeriesId=406729
After that you could also try a cleaning tape and a new data tape for an lto test in ltt.
Failing that i think you need to send it for repair
Tape-Techie
Jun 02, 2009 | HP 301566-001 Storageworks Ultrium...
Ultrium LTO 3 Tape Autoloader Error
what software are you using? try not backing up the system state to see if that changes anything?
Feb 07, 2008 | HP StorageWorks ESL712e Ultrium (AA934B)...
HP StorageWorks Ultrium 920 LTO-3 Tape Drive Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
