Question about Kenmore Refrigerators
My kenmore 6992 fridge is running too cold. Even fruit in the tray above the freezer is freezing.
We always have to remove ice from the bottom of the fridge but now the unit runs too cold.
  • 958 Answers
SOURCE: HOOVER HNMF2605A FRIDGE\FREEZER
main stat? what is a main stat?... do you mean thermostat?...that is the thing that controls the compressor to stop if its already cold inside the compartment. or your compressor could have been hot wired already. has anyone repaired your ref before?
Posted on Feb 22, 2008
SOURCE: Sub-Zero 550 - freezer unit is chilling, but not freezing
Ice maker was intermittent at best - ice was often just a shell. After two failures to correct we had the ice maker (a Whirlpool - on a Sub Zero - Go figure) replaced. Then the paddle that detects the ice level broke. Next step a new GE.
Posted on Aug 22, 2008
drpepper106
  • 25 Answers
SOURCE: bottom freezer "on" but not freezing and not making ice
Refrigerator running but not that cold, freezer running also but not freezing at all. Also not making Ice
Posted on May 24, 2009
freetek
  • 5568 Answers
SOURCE: fridge does not keep cold, but freezer is over freezing, icemaker not making ice also.
You should be able hear, and feel the air from, a running fan inside the cabinet, in either side. The common arrangement is having the coils located (behind the wall) in the freezer section and then the fan moves a controlled amount of the frigid air to the refrigerator section via openings located in the rear of the compartment. The vents are normally adjustable so the temperature can be balanced between the two compartments.  If there is no noticeable air coming from this vent, then the fan has died.
Posted on May 25, 2009
  • 44 Answers
SOURCE: top of freezer not freezing, bottom of fridge is?
Could be the evaporator fan motor is not working. This is what circulates the air from the freezer to the refrigerator section.
Posted on Aug 25, 2009
Kenmore elite coldspot model 106.74219400 freezes in the fridge never gets above 5 or 10 degrees and it never shuts off.
there is a flap in the refrigerator side usually near or behind the light bulb the freezer side is thermostatically controlled with the compressor being controlled. On the refrigerator side the cold air comes from the freezer side. when this flap is open the refrigerator will cool continuously, Check the flap or the duct assembly
here is an illustration of the part
http://www.repairclinic.com/Kenmore-Refrigerator-Model-10674219400-ID-927868-Duct-Venting-Parts
Apr 14, 2013 | Kenmore Refrigerators
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
May 11, 2012 | Kenmore Side by Side Refrigerator
Ice maker overfills tray
Sounds like a probe fault. It should stop freezing when the set point is reached and defrost for a short while. Have you set it to fast freeze?
Apr 05, 2012 | Thermador Refrigerators
I have a GE Side by Side (model GSL22JFRJBS) and am having several problems and I'm not sure if they are connected or if I just have bad luck. 1st: the freezer and fridge are not staying cold. The freezer...
HI change the main board its about $150-200. Will fix all your problems except the lightbulb would be a lightsocket problem or the bulb you put in is bad, or door switch.
Sean
Mar 30, 2011 | GE GSL22JFPBS Side by Side Refrigerator
21' bottom freezer kenmore refrigerator-no ice maker-the fridge is super cold and freezes all my vegetables and fruit. We have cleaned the coils, cleaned the fridge, and it just keeps freezing. Fridge is...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Oct 02, 2009 | Kenmore 21.0 cu. ft. Bottom Freezer...
Bottom drawer of the refrigerator freezes the fruit.
I think the thermostat is faulty. Thus it makes the freezer extra cold. Try replacing it. Regards, Nandini.
Sep 07, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Top of freezer not freezing, bottom of fridge is?
Aug 24, 2009 | Refrigerators
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Kenmore Elite Trio 795
check the damper controller at the center of the fridge. this regulates the air that is coming from the freezer dependent on the signal from the thermistor of the fridge compartment. that is the other thing to check. check it for rresistance and it should change as you change the temperature of the sensor.
i hope i was able to help;;
May 06, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
18 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
