Question about Ariens Zoom 42 In 165 HP Briggs Stratton Zero Turn Riding Mower ()
When i star the toro riding mower Z4235 the fuse blow
How do i install a starter cylonoide on a toro timecutter rear engine lawn mower that has a kawasaki 22 hp motor i dont know were the green and blue wires go
do you mean a solenoid? if so then the 2 wires fix to the spade terminals on the solenoid just below where the 2 large red ires are bolted to the solenoid
May 06, 2015 | Toro Garden
Have z4235 right control just stoped working left works fine any suggestion
There are adjustments for this problem on each side of machine. Just follow the arms and you will see. This happens due to vibration. GOOD LUCK FRIEND.
Apr 20, 2015 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
I have a Z4235 22hp Kawasaki with a 42 inch deck. The mower does not evenly. What can I do?
make sure you dont have a bent blade.if not check the mandrel housing and level the deck
Aug 15, 2011 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
My Toro LX425 keeps on blowing 20 amp fuses when I am mowing the yard. Why is it doing that?
a fuse will blow if: a positive wire is being grounded to the frame or two much current is being passed thru it.
Jun 28, 2009 | Toro Lawn Mower With Toro Power Tools
Toro 280H regulator fuse keep blowing ,no visable shorts in wireing ? I am not sure if it might be the regulator on pto or mag .
Check to be sure there is not a rubbed spot on any wiring that is grounding the fuse out.
If not, the regulator is going bad and may need replaced.
Jun 24, 2009 | Garden
Toro mower won't start. No sound when I turn key.
definately connection some where i would use a volt meter and make sure where power is and make sure it is getting too where you need it, if its getting too the soliniod or not then too the starter.
May 08, 2009 | Toro Lawn Mower With Toro Power Tools
Ariens Zoom 42 In 165 HP Briggs  Stratton Zero Turn Riding Mower () Logo
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
Are you an Ariens Garden Expert? Answer questions, earn points and help others
