Question about jigzone.com
The new ads that "flash" on the bottom of the puzzle prevents people with epilepsy disorders from coming to the site. Flashes and strobes induce seizures. Not a real smart idea.
The flashing ads are so distracting. They are an irritant. If I bothered to look at the advertisers, I would never buy anything from them, ever!
What is Urbanol 10mg prescribed for
10 mg is probably a standard tab.
Urbanol is clobazam. Used for epilepsy, seizures, anxiety, and a few other psychiatric disorders.
Clobazam Wikipedia
Sep 18, 2017 | Health & Beauty
What are large white pills marked M177?
M 177 (Divalproex sodium extended-release 250 mg) used in the treatment of bipolar disorder; mania; migraine prevention; hyperekplexia; epilepsy
Jun 17, 2015 | D. Joey Prescription Pill Identifier
Large white pill with marking M177
Pill imprint M 177 has been identified as Divalproex sodium extended-release 250 mg.
Divalproex sodium is used in the treatment of bipolar disorder; mania; migraine prevention; hyperekplexia; epilepsy (and more), and belongs to the drug class fatty acid derivative anticonvulsants. When treating epilepsy and manic episodes associated with bipolar disorder: There is positive evidence of human fetal risk during pregnancy. When treating migraine: Not for use in pregnancy. Divalproex sodium 250 mg is not subject to the Controlled Substances Act.
Pill Identifier Pill Finder Drugs com
Jun 17, 2015 | Health & Beauty
My York furnace sometimes doesn't completely ignite
A noisy inducer probably is headed for replacement.
The igniter can produce a healthy glow and still be defective. Mine had to be replaced with a new, improved one.
The thermocouple could be defective even though it seems to open the gas valve when it should.
The heat sensor in the bonnet could be defective. That controls main blower operation.
The heat exchanger could be cracked.
Jan 10, 2014 | Heating & Cooling
I AM IN SOWETO, SOUTH AFRICA ,AND I NEED A PHARMACY WHERE I CAN BUY EPI-STILL FOR PREVENTING EPILEPSY
About the only way you can purchase it is online. Google Epi-Still and you will come up with a bunch of sites where you can purchase online. Also, closely read the Opinion sites concerning this native remedy. It's not for everyone. Nor, does it work for everyone.
May 09, 2011 | Native Remedies Epi Still For Preventing &...
Ttl auto does not work
Digital Camera Fully Compatible, Newly Developed S-TTL System "S-TTL" enables TTL auto shooting by an external strobe for a digital SLR camera as well as for a point & shoot digital camera.
INON S-TTL auto strobe supports any manufactures' model providing highly accurate exposure control.
Film camera era without strobe selection problem TTL stands for "Through The Lens" and TTL auto strobe system controls flash amount to provide correct exposure based on calculation by camera's internal sensor metering reflecting strobe light from a subject through the lens. This TTL system meters actual light amount reflecting from a subject providing accurate exposure.
When we start with the history of underwater TTL auto strobe, underwater camera?"NIKONOS V" released in 1984 was the first to provide automatic TTL flash control for underwater strobe SB-102, SB-103 succeeded by NIKONOS V compatible underwater strobes form other manufactures. The 5 pin electrical sync connector for NIKONOS V is most popular and widely adopted to connect an underwater strobe and underwater film camera (underwater camera/housing).
A film SLR camera has flexibility to select an underwater strobe. As far as housing has NIKONOS type electrical sync connector and properly wired, automatic TTL flash control is usable with any TTL auto strobe like Nikon SB-105, INON Z-220, Z-22 connected via electrical sync cable.
NIKONOS type 5 pin electrical sync connector and NIKONOS V with INON Z-22 strobe
Film camera compatible strobe is not usable for a digital camera!? Underwater TTL strobe circumstances have been drastically altered with the spread of digital camera among divers. Some underwater housing for digital SLR camera has NIKONOS type electrical 5 pin sync connector as same as film camera housing. Since the housing has same NIKONOS type sync connector, existing film camera compatible underwater strobe has been considered compatible with a digital SLR camera via 5 pin sync cable but happened to experience error message on the digital camera or blackout on an image even the strobe worked. Why this happened?
This is because automatic TTL strobe system difference between a film camera and a digital camera.
The film TTL auto system makes single flash while digital TTL auto system employs pre-flash type making two to three flashes. Film TTL auto strobe system starts firing at the same time the shutter opens and reflecting strobe light from a subject is recived at a film. The reflecting light on the film is metered by the sensor to determine when to cease firing for correct exposure. This process takes only about 1/1000 second.
In contrast, digital TTL auto strobe system can not calculate adequate exposure based on reflecting light from a subject since image sensor (CCD/CMOS) reflectivity is comparably low comparing to a film. So digital TTL strobe system gives preliminary flash for very short period of time (pre-flash) just before the shutter opens metering reflecting light from a subject by the sensor to calculate necessary amount of light for correct exposure and starts emitting main flash at the same time the shutter opens. Canon E-TTL and Nikon i-TTL employs this system.
When we connect conventional film camera compatible TTL strobe to pre-flash type digital SLR via sync cable, the strobe makes full dump by pre-flash signal then the shutter opens before the strobe has been fully charged resulting in quite under exposed image only with ambient light. Even two time flash compatible strobe like INON Z-220 strobe, does not fully support a digital TTL and force to use Manual flash mode.
Film SLR:
A strobe starts firing at the same time the shutter opens and quenches firing when correct exposure has been obtained.
A film compatible TTL strobe connected to a pre-flash type digital SLR via electrical cable flashes does not support TTL auto exposure resulting in synchronization only with first pre-flash or totally uncontrollable.
The birth of digital fully compatible S-TTL S-TTL auto compatible INON D-2000 strobe and Z-240 strobe works in TTL auto mode by simply setting their main dial to S-TTL position. A film camera seems to depend more on photographer's skill, experience and feel since the camera does not allow checking images on site. A digital camera allows us to check images right after shooting and enable to try to shoot again as much as we like. And high capacity memory card further allows to shoot hundreds of images. The digital camera makes entry level of underwater photography getting down and nowadays more people buy a digital SLR camera and underwater housing even they have just started underwater photography. However underwater photography gets more difficult because underwater strobe does not work in TTL auto.
INON is among the first to support digital TTL auto system with "S-TTL" auto mode equipped D-2000 strobe and Z-240 strobe.
The proper name of S-TTL is "Optical Synch TTL". S-TTL enables to perform in TTL auto exposure as same as genuine TTL strobe from camera manufacture, based on camera's built-in flash light to use as a signal to be transmitted to a strobe. S-TTL uses digital camera's built-in flash light not as a light source but as like a controller to trigger S-TTL strobe.
The built-in flash of a digital camera makes weak flash (pre-flash) before main-flash to calculate exposure. This pre-flash is transmitted to S-TTL strobe to control the strobe to make pre-flash to a subject. The reflecting light from the subject goes through the camera's master lens to an image sensor then a processor calculates main flash light amount for correct exposure.?Finally the built-in flash makes main-flash which is transmitted to the S-TTL strobe to cause main-flash of the S-TTL strobe.
Digital camera's built-in flash lights are transmitted via an optical fiber to the
S-TTL strobe to make pre-flash and main-flash instead of the built-in flash.
Apr 30, 2010 | Olympus FL-20 TTL Flash
Hayward Colorlogic Light flashes like a strobe
OK I GUESS U HAVE A AUTHOMATIC CONTROL CHECK T RELAY FOR 120 V THAN CHECK FOR V AT THE JUCTION BOX IF V LIGHT MUST BE REPLACE.
Jul 07, 2009 | Hayward 12v LED Color Logic Pool Light...
The display flashes...
unplug everything. press power button continously for one minute.
helps sometimes. sometimes repeating multiple times helps. sometimes repairs the issue for a few months and then finally breaks for good.
Mar 23, 2009 | Gateway XHD3000 LCD TV
580ex not flashing at all
after using it many flashes at 1/1 power the strobe doesn't work anymore
Jun 19, 2007 | Canon SPEEDLITE 580EX TTL Flash
jigzone.com Logo
29 people viewed this question
Top jigzone.com Computers & Internet Experts
David Payne
David Payne
Are you a jigzone.com Computer and Internet Expert? Answer questions, earn points and help others
