Question about Dishwashers
Kichenaid dishwasher kudio1ilwh3 normal light flashing
Looking for reset code
  • 172 Answers
SOURCE: KENMORE ELITE DISHWASHER - MULTI-LIGHTS FLASHING
Look at your manual, usually available on net for reading or downloading. Blink lights are often used to code out a problem with various combinations and repetition rates to indicate trouble code number for look-up in manual.
Posted on Feb 22, 2009
  • 38 Answers
SOURCE: Whirlpool Gold flashing 'NORMAL' light, will not reset or work
Could be either the keypad is faulty or the control board is bad.
Posted on Feb 23, 2009
KevinWhite
  • 1902 Answers
SOURCE: Viking Dishwasher VDB450SS Unit appears
Hello & Welcome to FixYa
Check the door latch switch mechanism as that seems to be bad and needs replacement as everything else is working fine. Please get back to me if you have any other questions.
Kevin
Posted on Jun 18, 2011
Daniel S
  • 4323 Answers
SOURCE: need to reset dishwasher, normal light keeps
Hi
It may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Posted on Jul 25, 2011
  • 3 Answers
SOURCE: dishwasher won't start - lights for Normal Wash and Cancel are flashing
check the controls,make sure that they are not stuck.
Posted on Dec 31, 2011
I have a whirlpool dishwsr. model GU2400XTPB7 that has been flashing the normal light and I cant use it for over a week. I turned off the breaker to the house for 30 min. & that did not work. I tried...
Hi Melinda,
Thanks in advance for using Fixya.com. Now then firstly by pushing the heated dry and normal buttons then repeating is the proper procedure to reset the control board,below is a the exact buttons to push to reset the control. Also please take a count of the number of times the light flashes befroe going off breifly then repeats the same number of flashes; the number of flashes indicates a error code...if if flashes 5 times that error code 5 and if it flashes 7 times its error code 7 etc,etc.. please get back to me with the number of times it flashes.
Here is what i copied and pasted from my online service manual for Whirlpool dishwashers that shows which buttons must be pushed to reset the board,after pushing the buttons shown push the cancel/off button and the board should be reset so the machine will start at least one time where ya can take note of the number of times the nirmal light flashes,
GENE
Mar 01, 2012 | Whirlpool Dishwashers
Dishwasher won't start - lights for Normal Wash and Cancel are flashing
Dec 31, 2011 | Dishwashers
I can't turn on my KitchenAid Superba dishwasher. I pushed Normal and Start, and the Normal light started flashing, but didn't turn on. Pushed Cancel and now both the Normal and Cancel are...
Did you try turning off the power and then connecting it again?
If still problem is there open the door. Press the following sequence of buttons HI Temp Scrub, Energy Saver Dry,HI Temp Scrub, Energy Saver Dry. Now close the dishwasher door and latch it too and press the cancel button. This must reset the dishwasher.
Aug 13, 2011 | KitchenAid 24 in. KUDU02FR Built-in...
Feb 22, 2009 | Kenmore Dishwashers
Jan 13, 2009 | Whirlpool 24 in. GU3200XTP Built-in...
Whirlpool dishwasher reset code
Yup, found it on another site..I had the same issue today.
Reset code: Push 1. Heat Dry 2. Normal 3. Heat Dry 4. Normal
wait about 2 minutes as the controller resets itself. You should see all the leds flash on and then wash and rinse leds stay on for about 30 seconds. A minute or so later ..presto, my machine worked again.
My machine is not the GU3200XTP, but in the same Whirlpool tall tub series (same manual) so leds may not have the same name.
Mark
Oct 19, 2008 | Whirlpool 24 in. GU3200XTP Built-in...
Light flashing
reset the dishwasher by touching heated dry and normal let it run through that cycle then through a normal cycle got the error blink again. Reset dishwasher by touching heated dry and normal, ran the test cycle, next ran a normal cycle but turned off the heated dry. This allowed the dishwasher to run through a complete cycle did not get the error blink and confirmed that the heating element was out.
Aug 30, 2008 | Whirlpool 24 in. GU2500 XTP Built-in...
Kenmore ultra wash quiet guard 3 dishwasher problem
call sears, 1-800-4MY-HOME. They have a trouble-shooting department that will get rid of this problem. It is caused by water temperature being wrong at the start of the cycle.... blah, blah, blah. The representative will tell you to push a certain set of buttons in a certain order and that unlocks the dishwasher.
Sorry I don't know the sequence
Jun 08, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
I need to reset the mother board on my Kenmore dishwasher. Do you know the code for the Kenmore model 665-17032402. I was told by sears that they used to give this out but, because of a fire hazard they...
The clean light sometimes flashes and just needs to be reset. To do so hit the keys in the following order. <Heated Dry> <Normal Wash> <Heated Dry> <Normal Wash> <Cancel>.
The dishwasher will go through a cancel cycle (drain the tub) and will then let you start it up again.
Apr 19, 2008 | Kenmore 17024 Built-in Dishwasher
Clean light on dishwasher won't stop flashing
yust reset press heated dry-normal-heated dry normal-and it will work 100% remember that code it is reset code for wirpool quiet partner and many other models
Jul 02, 2007 | Whirlpool 24 in. GU3200XTP Built-in...
Dishwashers Logo
16 people viewed this question
Top Dishwashers Experts
Owen Barnes
