Question about Husqvarna Garden
My backpack leaf blower runs idels but wont picks up very littel r.p.m
SOURCE: Need to replace fuel filter
Fuel filter is located inside the fuel tank. You have to make a hook out of about 10" of stiff wire (wire coat hanger works perfect) Hook end should be about 1/2" wide. Remove the fuel cap, insert the wire hook and snag the fuel supply tube with the filter attached to the end. Pull it back through the fuel filler opening, replace the filter and reinsert.
Posted on Apr 15, 2009
  • 398 Answers
SOURCE: homelite Backpacker II leaf blower start fine then
have you checked air filter? the carb may need adjusting. locate the adjustment screw(s) , screw them all the way in then back out 1-1/2 turns. try to start the engine. then let me know what happens.
Posted on May 17, 2009
  • 251 Answers
SOURCE: husqvarna 125bt backpack leaf blower. I put
if you've ran it for any length of time you will need a new cylinder and piston/rings and cylinder gasket ,
take the muffler off and look for scoring /scorching on the piston
Posted on Oct 21, 2009
  • 251 Answers
SOURCE: How do I adjust needle valves on a 25cc Homelite
Set the lowend & highend needles to about 1 3/4 to 2 turns each. Choke the carb or prime it, until the carb is wet. Fire up the engine and let it warm up. Let's set the topend first since it's the easier of the two. Go to full throttle. Adjust the topend needle for peak RPM. Leave it wide open for about a minute to see if it changes any. Should the engine go lean, open the lowend needle slightly, if this dosen't work... you will have to adjust the needle valve inside the carb.( I will explain this later) If the topend runs OK, then slowly pull the throttle down until the engine begins to "four cycle" hold the throttle there. Adjust the lowend needle until the "four cycling" barely stops. Now lower the throttle more until it "four cycles" again, and adjust the lowend again. Keep doing this until you reach full idle. Now, from full idle begin to throttle up until the engine starts to bog or hesitate. Open up the lowend needle just enough to eliminate the bog or hesitation.
http://tech.flygsw.org/walbro_tuneup.htm
hope this helps :)
if it does please vote
Posted on Oct 23, 2009
bbreton
  • 437 Answers
SOURCE: My Homelite backpack leaf blower only idles. when
Is the new gas some you just mixed up from the gas station or is from the can in the garage? If it is indeed fresh then you are looking at needing the carburetor adjusted. Sorry you can not do it yourself, The epa only allows qualified technician to adjust them. Plus the tool to do so are not available to the general public.
HTH
Good Day.
Posted on Oct 31, 2009
No power with Echo PB-755st Leaf blower
Try pulling the air filter off and see if it picks up. Also a minor carb adjustment may help. Also make sure your fuel isnt old or watered up. See if you can find alcohol free gas in your area. It may cost a bit more but it saves on repairs!
Mar 02, 2015 | Echo PB-755ST - Backpack Blower, Gas, 651...
Why will my blower only run on full choke
try getting a new carb 25 or 30 bucks rebuild kit about 18 bucks so it one or the other, good luck.
Jun 17, 2014 | Troy-Bilt Troy-built Tb2bpec 27cc 2-cycle...
Br500 wont start
fuel filter inside the tank and inline
bad start stop switch
bad carbiration
bad spark plug {burned}
bad ht cable
bad magnito coil
take your pick and rull them out one by one
Feb 08, 2014 | Stihl Br550 Br500 Backpack Blower Fan...
Echo blower wont start
ignition coil fixed my still backpack last fall
Apr 02, 2013 | Echo Pb265l 25.4cc Gas Powered 158 Mph Low...
My backpack leaf blower wont star. It was working fine yesterday now it wont star at all. Any suggestions?
Hi! Look for the spark plug,take it out and replace it with a new one,and then try to start it up.Also check if you have fuel and oil mixture right.
It is the most common failure in such hardware.Good luck!
Mar 06, 2011 | Ryobi Backpack Blower 25.4cc
My Homelite backpack leaf blower runs until tank is 1/2 full
thats what it is try opening the gas lid look inside to see where the fuel line lies if its up high them try pushing it down to the bottom
Nov 13, 2009 | Homelite Consumer Products Backpack...
Echo pb-260l won't spin up. replaced carb, plug, fuel filter and
i have aecho pb 260l backpack style leaf blower and it will not start. it turns over well and has spark and reasonably new fuel. any thoughts
Jul 17, 2009 | RTO Echo 25.4 Cc Backpack Leaf Blower -...
Carb adjustment tool
It is probably a star or a square head. You should be able to pick up at any auto parts store.
Hope this helps
Kurt
Mar 18, 2009 | Homelite Consumer Products Backpack...
Leaf Blowers types
* Handheld units are the most popular. Available in gas- or electric-powered versions, they're portable and convenient, yet powerful. These models can get heavy while using. Larger models can also vibrate a bit at full throttle. Consider the weight and balance of the unit when shopping. * Backpack leaf blowers are gas-powered. The blower fits in a harness that's worn on the operator's back. The hose reaches to the front where the user operates the throttle and blow or vacuum tube. Backpack blowers are normally used in larger areas. * Walk Behind leaf blowers cover the most acreage. Mounted on wheels, these gas-powered machines are normally the tool of choice for commercial users, but for regular homeowners, they can make short work of a home lawn. Vacuum units use a hose for picking up debris.
Aug 27, 2008 | Toro Super Blower Vac
Garden Logo
82 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
