Question about Dryers
I need to raplace belt
How to replace belt
  • 547 Answers
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Posted on Jun 19, 2009
I have a daihatsu mira 2008 car. Is there a timing belt or chain in this and when do I need to change this
Belt
Daihatsu timing belt change interval Questions & Answers (with ...
www.fixya.com > Forum > Tags > timing belt change interval
...timing belt on my charade having 67800 Km since i never replaced it manual says 10000 Km. thanks Andrew malta INTERVAL IS 80.000 KM OR 5 YEARS. ... when I have to change the timing belt for daihatsu materia 2008 Should be change out every 60,000 miles, this is an interference engine, if timing belt failure, there ...
Replacing Timing Belt ' Daihatsu Drivers Club UK
www.daihatsu-drivers.uk/node/81 Replacing Timing Belt. Replacement Interval Guide Daihatsu recommend the raplacement of the timing belt for the Sportrak every 60,000 miles although you must take into consideration the service history and the mileage into account.
daihatsu mira 2008 mileage to change timing belt Google Search
Mar 10, 2018 | Daihatsu Cars & Trucks
Crank window assembly
the cable wires might be damage i replace mine with a brake cable from a bicycle
Mar 22, 2014 | 1997 Mitsubishi Mirage
I have a ys 4500 with hydro transfer I pedal operates forward and reverse it goes forward but at times will not go in to reverse. The mower was partially disassembled when I got it are there any...
Check linkage to transmission if no adjustment you will probably have to rebuild or replace that is if the belt is tight and operating correctly.
Sep 08, 2017 | Craftsman Garden
How solve toner exhausted problem in samsung scx 4300
either replace toner cartridge or in case of refilling You need to raplace chip on cartridge
Jun 03, 2011 | Samsung ML 1610 Laser Printer
My timing belt went out and i'm tring to raplace it
Email me at sernst@insightbb.com to receive instructions and diagrams of how to replace it.
Mar 28, 2011 | 1995 Isuzu Rodeo
I need to raplace the timing belt on a kia sportage. the belt was broke and the timing is lost. i just want to know the position of the marks on the camshafts inteke and exaust.
look at the cam sprokets they should have an I and an E stamped on them then by the gear they should have a notch. the back timing cover will have a V symbol. then match them up the cam close to the intake side will have the I mark up and the cam on the exhaust side will have the E up.
May 07, 2010 | 2001 Kia Sportage
Prints dusty darker pages with streaks, already replaced toner
Your developer is in need to raplacement - also verify that the developer waste bottle is not full.
Jan 30, 2010 | Kyocera Mita KM-3035 All-In-One Laser...
Wondering about special tools involved to raplace timing belt on Hyundai Santa Fe 2004? Are any needed?
No "special" tool that I'm aware of...you've posted related question about this task...I do NOT recommend doing this at home...A mechanic shouldn't charge all that much, say $150 max to do this job and then it'll be done right the first time...If you "accidentally" knock the engine out-of-time you could cause engine damage $$$$
Jun 23, 2009 | 2003 Hyundai Santa Fe
Repair elictric window moter replacment
your going to take off the cover of the panel you need to raplaced, then take off the window by loosing the 2 bolts under the window attached to its mechanism, after that take off the mechanism coz this is where the motor attached by screw...
May 11, 2009 | Ford Taurus Cars & Trucks
Dryers Logo
50 people viewed this question
Top Dryers Experts
Marvin
Marvin
