Question about Crafts & Hobbies
Remove crazy glue from frabic - Crafts & Hobbies
Remove crazy glue from glass
Crazy glue crystallizes when in cures; when it sticks on glass it can be scrapped with a sugar edge razor, or other sharp edge object.
Mar 08, 2015 | Cars & Trucks
How to remove crazy glue from wood
If you go to a craft store, down their stains/glues/paint isle there will be a very very small section that has removers. I would suggest Goop Gone (I think that is the name of it). Make sure to check the back and see if it will damage wood. My sister recently got a nice mahogny door from http://www.kohlen.com.au and her three year old wiped glue (and who knows what) all over it. She was able to get it all off. Also, don't use magic eraser on it! (The soaps in it may damage the paint on the wood!)
Dec 06, 2013 | Crafts & Hobbies
There is no way to remove it, other than file it down or scrape it off.
Broken key in ignition of 1995 nissan 200sx...Any helpful tips on removal? Im using dental tool picks and anything else small enough to fit...
I use crazy glue and some patient and work fine. Put a little on the other side of the broken key, push back into ignition and hold for a couple of minutes until dry, when removing pull fast, if fail try again. I have a Sprinter and the keys are prone to breaking already happen twice and both time I got it out with crazy glue.
Oct 18, 2013 | Nissan 200SX Cars & Trucks
Remove crazy glue from gem stone
Try an acetone-based nail polish remover.
Aug 18, 2013 | Crafts & Hobbies
What solvent will remove crazy glue from sktn
Acetone or ordinary nail polish. See here.
Mar 06, 2013 | Car Audio & Video
HOW TO REMOVE CRAZY GLUE FORM ARBORITE
I would try either:
a) a razor blade and hot soapy water
b) acetone (nail polish remover)
c) if there is alot of it and neither of the previous 2 solutions worked, you can buy superglue solvent
Dec 14, 2012 | Elmer's Instant Krazy Glue
How do I remove crazy glue from control panel? The cover over the plus control(to raise oven temperature) was coming off so I thought I would glue it back on! Bad idea ....now that control remains...
Not to much can repair / remove the crazy type glues once they are applied to plastics and plastic overlays. Some people attemp to use these not knowing that some types of plastic will not bond. most of the solvents that can desolve the glues will also damage the panels.
Mar 27, 2012 | GE Microwave Ovens
How can I remove a lodged oil dip stick? Top part of grip has broken off. Someone tried to remove it but lodged it in further down.
Needle nose plyers.
If those wont reach in far enough - you might have to remove the dipstick tube..
Jul 22, 2009 | 2004 Nissan Sentra
The frabic is loose on the sunroof can I fix it
You might be able to fix it with fabric glue (spray can) or adhesive if the fabric is in good condition.
Jul 19, 2009 | 1999 Mitsubishi Montero Sport
Crafts & Hobbies Logo
69 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
