Question about Whirlpool Dryers
Where can I light the pilot
There is no heat coming from my dryer.
  • 82 Answers
You're dryer has an ignitor not a pilot. To check, either pull the lower front panel or pop out the key hole. Start dryer and watch if the ignitor comes on it should shine brightly almost white. If it does'nt light at all(should at least turn red). there could be no voltage to the ignitor.
Posted on Jun 19, 2009
Hooked up roper dryer and it's propane everything seems to be hooked up right but won't get hot or even heat up. This is first time ever having to use propane. Any idea what it might be or could have...
1.is the pilot light lite burning.
2. if pilot light light is on ,does the blue flame of the pilot light touch and heat up the thermocouple.
the dryer will not turn on the heat if the pilot flame does not touch and heat up the thermocouple.
3 is the dryer plugged in to the electricity.
4. is the dryer actually getting electricity.
If the dryer has electricity and the pilot flame is touching the thermocouple, then try buying and installing a new thermocouple.
****have you purged the air out of the gas lines so that the dryer is actually geting pure propaine and not just air getting pushed ahead of the propaine.
how old is your dryer, if new, warranty service will trouble shoot & repair for free.
you need to tell us more so that we have some facts to work with. vagueness does not cut it.
Oct 09, 2013 | Dryers
Stops and all the lights come on
Instructions
    • 1 Make sure the home's gas supply valve is turned on. Check your Maytag owner's manual to find the location of the dryer's gas shut-off valve. This is usually behind the dryer's front panel or in the back of the unit. Open the valve to allow gas to flow into the dryer.
    • 2 Open the lower front panel of the dryer to access the pilot light assembly. Press and hold the starter button as you light the pilot with a handheld lighter. If you have trouble getting it to light, release the starter button and wait a few minutes before trying it again. Once the pilot is lit, hold the starter button down for another minute to make sure it will stay burning.
    • 3 Close the dryer's front panel and run a test cycle to see if it is producing heat. Call a repairman to evaluate the problem if lighting the pilot did not restore the heat.
Jan 15, 2013 | Kenmore Dryers
The pilot lights up, but when the thermostat is calling for heat nothing comes out. Basically the pilots on but the burners wont light.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 19, 2011 | Dryers
Whirlpool dryer will not ignite.JET FLAME WILL NOT GO ON.
if the ignitor is lighting up, or if you have a actual flame pilot light, depending on the machine, if you have a pilot light, check the thermocouple that the flame from the pilot is supposed to heat , but thats on very very old machines , if you have a glow plug , ( a heat source that comes on electrically and glows , then you need to check the 2 coils that are on the gas valve, they have gone bad
Jul 13, 2011 | Whirlpool Dryers
Do we need to light a pilot light in order to start the dryer? how do we know what year the dryer is?
No pilot light just a hot surface ignitor that starts the fire in there...
get the model and serial of your dryer and then do a search for the year... it will come up...
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 19, 2010 | Dryers
Old maytag gas dryer. Does not heat anymore, gas
Maytag dryer series 05. How do I light the pilot?
Apr 04, 2010 | Maytag Dryers
Dryer won't heat. Replaced sensor and ignitor. Flame initially comes on and heats temporarily but then shuts back off. Any ideas?
Make sure the thermocouple is in the flame of the pilot light,and using compressed air clean out the pilot light,and see if that will solve the problem.
Nov 02, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
Kenmore 90 series propane gas dryer
Hi, You should not have a pilot light, There are electronic ignitors on the dryers. Unless this dryer is 40 years old, just start the dryer and the heat should come on.
If the heat does not work, there must be another issue.
Please let me know if I can help you further.
Thanks
Vic
Jul 21, 2009 | Kenmore 63942 Dryer
How do I light the pilot light
this dryer does not have a standing pilot it has an ignitor that comes on when you start the dryer if the dryer is not heating then you will more than likely have to replace the ignitor first make sure the dryer is plugged in
Jul 11, 2009 | Whirlpool LGB6300 Gas Dryer
Finding pilot light for a Kenmore dryer model # 97581110
theres no standing pilot in dryers is it on a heat setting or air dry .then look thru that small hole while in aheat setting on the timer. when you press the start button you will hear two clicks the see the glow ignitor glowing.if its not glowingyou would need to check voltage at the ignitor if no voltage problem will be thermol cut out fuse
Jan 01, 2009 | Dryers
Dryers Logo
171 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
