Question about Saeco Magic De Luxe Espresso Machine
Saeco magic temperature light is on - Saeco Magic De Luxe Espresso Machine
5 Suggested Answers
  • 7 Answers
SOURCE: saeco magic
I believe the model you have has no user-selectable temperature settings. The manual for the Magic line suggests preheating the cups as the fix. You can use the electronic cup warner OR run your tap/faucet water as hot as possible, fill the cup you're going to be dispensing espresso into with hot water while your Saeco warms up...right before you hit the button to dispense espresso, empty the hot water, dry the preheated cup and you're set! It only takes a few seconds. This way, you waste none of your coffee's thermal emergy on cup heating and your coffee will stay hot longer. Hope this helps!
Posted on Jan 04, 2008
  • 40 Answers
SOURCE: Saeco Magic De Luxe dregs light problem
Make sure that both the tray and dump box are placed correctly- otherwise the machine will not start. Both have a switch and when that switches are not engaged, the machine will not turn on.
Posted on Jun 19, 2008
  • 1089 Answers
SOURCE: Saeco Magic Deluxe temperature control.
Hi
Yes it can, but it takes a special computer that plugs into the back of the power board in the machine.
Posted on Aug 18, 2009
SOURCE: Temperature control on Saeco magic deluxe
boiler is trip after one minute due to temp. meter setting is wrong how can i manage its.
Posted on Jan 13, 2013
Panel won't light on Saeco Magic Delux
Sounds like a board issue. It was something that happened on the Saeco Magic Deluxe's enough to be noticed. The board is not available for magic deluxe's with oval buttons.
Parts for your magic deluxe
May 29, 2011 | Saeco Magic De Luxe Espresso Machine
Saeco Magic Delexe water light flashing
The brew unit is blocked, check the shower screen under the red o-ring.
Dec 03, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco Magic Deluxe temperature control. can this unit have the water temp increased
Hi
Aug 15, 2009 | Saeco Magic De Luxe Espresso Machine
No it cannot. I am not sure why you would want the water hotter. It is designed to be at the perect temperature for passing through the brew group for coffee brewing, its kind of a simple science.
If your machine has been producing less hot coffee gradually, that marks an issue. Try descaling the boiler per the manufacturer's inscrutions even if the warning light isnt on. The other option is that the thermal fuse mounted to the boiler is bad and turns off the boiler prematurely, those cost about $15 and are simple to replace. Lastly, the boiler heating element may be 'burnt out' new boiler is $120+
Saeco Magic Deluxe - Coffee Cold,Lights not working
The thermoblock (boiler) element is burnt out and must be replaced.
Feb 10, 2009 | Saeco Magic De Luxe Espresso Machine
Making Espresso shots... how does the macine do this? Not in man
www.partsguru.com look to the left for Saeco Home Models, select that, then go the model you have and download the manual.
On a magic comfort it has two settings for adjusting the espresso shot besides the amount of the shot. .
On a magic comfort plus,
you can adjust the grind size, the amount used for the shot, preinfusion (a short shot of hot water on the grinds before the unit passes all the water through the puck (coffee grinds), temperature and amount of water for shot
Also, when setting the strength on this machine, don't use a full grind amount as it can jam the machine. use a setting of 6 or 7 max for strong shots, not the 8 or 9 setting!!!
Dec 03, 2008 | Saeco Magic Comfort Plus Espresso Machine
Mar 09, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Magic 2nd light to the left (ON RED LIT)
Sound like descaling warning light, need to run descaling solution through the machine (follow instructions, you can download a manual on saeco's website) this light can be turned off by pressing and holding the steam button for 5 seconds.
Jan 21, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco magic
Jan 02, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
22 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
