Question about Brother HL 1440 Laser Printer
Plastic labels jammed inside of printer.
While printing plastic labels one sheet of the labels became jammed. I was able to pull most of the sheet out but can still see several bunched up together from the back of the printer. Please help! Any suggestions as to how to un-jam the labels!
  • 33 Answers
They are stuck in the fuser unit, try to take out the toner cartridge to see if you can get it from their. if not you may have to call for service help. you have to take the back of the machine apart and take out the fuser unit to get out the lables. sorry that i didnt have better help.
Posted on Nov 02, 2007
I am trying to print a label through the document feeder and keep receiving error messages on my Brother MFC9320CW AllInOne Printer .."Open the Top cover and pull out all 4 drum units completely and...
Try putting more than one sheet of labels in the paper tray. Even if you're printing one label, it helps the printer grab the paper without that error somehow. If you're already using more than one sheet, I don't know. Good luck either way!!! :)
Jan 18, 2011 | Office Equipment & Supplies
Paper feed problem
This is happening due to paper jam on the gear or roller of the paper feed mechanism. Check for any small bits of paper or sheet stuck. To check lift up the top plastic lid of the Canon printer. Check to see if a jammed sheet of paper is visible inside the printer. Remove the cartridges and check for any small paper bits stuck under the print head. Pull the paper out gently through the bottom end of the printer(if any). Close the top plastic lid. Power On the printer and check.
If it doesn't work then power off the printer, wait 10 seconds and power it back on. try once again to print. If it doesn't work then Open the Canon printer software. Click "Options" and then select the "Clean Print Heads" button.
Daniel Scott
Jun 14, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Canon MP210 Paper Jam
A common issue is moisture. As the relative humidity changes, the paper will absorb some of the excess moisture. (Ink jets don't get as hot as other printers; but they do have temperature changes during operation.)
Unfortunately, the only solution that I have ever found is to use paper from a just opened package. Try to keep only enough paper in the printer for a short duration of printing (1-2 weeks). Keep the rest of an open package of paper somewhere else where the temperature and humidity stays fairly constant.
I hope this helps.
Feb 26, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Cartridges crash against the inside of the printer
100 percent that said small piece of plastic had give you a trouble in to your said priter. open your printer and find or locate that small plastic where come from inside your printer find the broken plastis inside your printer and join it
May 04, 2009 | Lexmark X2580 Wireless All-in-One InkJet...
Paper jam in hp deskjet 5900 series. how do i correct?
 Follow these steps to remove a paper jam:
1. Press the Resume button.
  If the paper jam does not clear, then go to the next step.
2. Turn off the printer.
3. Remove the rear access door. Press the handle to the right, and then pull out the door.
4. Remove any paper that is inside the printer by pulling it out from the back of the printer.
  If you are printing labels, verify that a label did not become detached from the label sheet while passing through the printer.
5. Replace the rear access door securely.
6. If the paper jam cannot be removed from the back of the printer, raise the printer cover, remove the paper jam from the front of the printer, and then lower the cover. Caution Remove the paper jam carefully as it is possible to damage the
  printer when removing paper from the front.
7. Turn on the printer, and then press the Resume button.
8. Reprint the document. Note If paper jams occur frequently, try using a heavier paper. See the reference guide for paper weight specifications.
Jan 29, 2009 | Office Equipment & Supplies
Printing labels and it jammed. pulled nose to get out label.
if you r trying to print from word , changet the papet type in the printer . this will solve the problem
Dec 14, 2008 | Dymo LabelWriter 400 Thermal Printer
Paper Jam - ADF
Open ADF cover
Lift up Pickup roller Assy
remove spring from pickup roller assy
Remove pickup roller assy gently pull it towards you
Carefully remove green plastic diverter
note this is held in place by 4 plastic pins 2 on each side
look in the opening for foreign objects.
( I have found labels, money, paperclips, plastic pieces,jammed paper in this area)
Aug 20, 2008 | HP LaserJet 3055 All-In-One Printer
'paper jam' error on canon pixma ip4300
Hi guys, I eventually found a solution to the problem for my printer. With the top cover open, I pushed a sheet of 120 micron thickness A4 clear plastic binding cover through the exit tray as far as it would go to rest against the bottom row of rollers. I switched the printer off then back on again and as the rollers lifted momentarily, I pushed the sheet of plastic as far up through the machine as I could before the rollers went down again - it went in a fair distance. The printer then ejected the plastic sheet. I then put the plastic sheet into the paper tray and tried to print a blank document page. The plastic fed through cleanly and my printer has been working since without any error messages. I hope this works for you.
Aug 22, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Paper jam
I used the cardboard backing from an 8x11 tablet; I pushed it into the paperholder; it pushed out a small bit of paper which could not be seen; behold, the paper jam was no longer. I paid a computer repairman $15 to do the same thing with a plastic sheet.
Mar 30, 2007 | Dell 924 All-in-One InkJet Printer
Brother HL 1440 Laser Printer Logo
70 people viewed this question
James Cagle
James Cagle
Jim Keysor
