Question about Garden
No water coming out of the hose - Garden
I have Beco WM616 7W washing machine...when I start washing...water should filled in washing machine but it comes out from somewere..all programms working...just water comes from bottom..
Check all your hose connections. Sounds as if the drain hose has come loose or burst. (common fault in all machines).
Open soap drawer, and check that water is flowing into it.
If no water is flowing into it, looks like the water connection hose at rear is not secure.
If water is flowing into the drawer, but not staying in the drum, then check the drainage outlet hose is secure and undamaged.
Jan 21, 2013 | Washing Machines
The washer just makes a buzzing noise when the temperature is on hot temperature selection
that buzzing is the solenoid on the water valve,no hot water coming to it or the valve is bad.shut off the house water,pull off the hot water hose,stick it in the machine or a bucket and turn it on,if water comes out,change the valve but it usually makes that noise when no water is coming to the valve,also if you have one of the hoses with a valve in it change it,those hoses are terrible,every time i go to a job that's having a water problem and one of those hoses are on the machine that's the problem.if no water coming out of hose change the water shut off from the house.
Mar 05, 2011 | Kenmore Washing Machines
This morning i turn on the washer and there was no water coming in to it
Turn off water to washer; disconnect hose from washer, and check for any debris in hose or where the hose connects to washer. put hose inside of washing machine and turn the water to the hose on, to flush out anything that might be in the hose; if no water check other end of hose for blockage; if water comes out of hose , call repairman.
Feb 25, 2011 | Washing Machines
Water pressure is very low, takes a minute to fill a glass. Its not the filter that has been changed
IT MAY BE A CLOGGE IN THE WATER HOSE. GO BEHIND THE REFRIDG CLOSE THE MAIN WATER LINE VALVE. PULL OUT THE HOSE SEE IF ANY WATER COME OUT FROM THE HOSE.
AND USE A SMALL BOKETT SO YOU CAN TEST THE REFIDG WATER VALVE CONTROLLER. PLUG BACK THE POWER SUPPLY AND FACE THE HOSE IN THE BOKETT AND DEPRESS THE WATER SWITCH AT THE DOOR AND SEE HOW THE WATER WILL COME OUT BUT THE MAIN WATER VALVE MUST BE OPEN. IF NO WATER COME OUT OR IT CAME WITH LOW PRESSURE. TAKE THE VALVE OUT AND CLEAN IT. MASKE SURE THE MAIN WATER SUPPLY WORKS GOOD.AFTER ALL IF YOU GOT POWER AT THE WATER VALVE WHILE YOU DEPRESSED THE SWITCH AND WATER STILL NOT COMING OUT SO, THEN IT GE TO BE THE REFRIDG WATER VALVE.GO AN A CHANGE THE WATER VALVE
Oct 24, 2010 | Whirlpool GD2SHGX Refrigerator
No water going through the heater hoses.
I would assume the water pump blade,on the inside,has come off,the car should be running hot also,if not,run a water hose threw the heater hoses to clear it out.
Jan 16, 2010 | 2000 Saturn SL
After 3 years we have ice but no water from the dispenser
Remove the bottom kickplate and the hose at the bottom of the door goes underneath the refrig about 3 inches , to a hose connector . Push in on the end of the connector and pull out the hose . Close the freezer door and press water . If water comes sprays out from hose under frig , then your door is frozen internally .If no water sprays out of hose , then your watervalve is bad . One coil is for ice and the other is for water but they come togather as one.
Jul 18, 2009 | GE GSH25JSTSS Stainless Steel Side by Side...
Leaks from a hose coming out of water pump and wraps around behind engine. what hose is this?
That hose appears to be your heating hose.On that line the warm water goes in to the cabin and makes your radiator warm,same size hose should be there as well as the water comes back on that one.
Jul 17, 2009 | 1999 Ford Windstar
Hose comes off back of the refrigerator going into ice maker
you have a clog.you need to remove ice between hose going in to freezer and where water comes thru to ice maker
Mar 05, 2009 | Refrigerators
Whirlpool Ultimate Care II - NO WATER COMING IN
take the hoses off the back of the machine. make sure that water is coming through. if water is coming through the hoses and the screens are clean then you need to replace your inlet valve
Dec 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Mavt634 cold water comes out the hot water inlet connection
Need to make sure that the water connections are correct - first that the hot water hose and cold water hose have not been interchanged and then if they are correct try interchanging the electrical connections to the water valves.
Mar 10, 2008 | Washing Machines
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
