Question about Golds Gym MAXX Crosswalk 650 Treadmill Rear Roller
Rear roller makes noise - Golds Gym MAXX Crosswalk 650 Treadmill Rear Roller
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 132 Answers
Most likely the bearings are going bad.try loosing the walking belt and rotate the roller by hand. if you feel any grinding or its not smooth it shoud be replaced. normally only the two adjusting bolts hold it in there
Posted on Apr 20, 2014
Dryer is making a loud screeching noise
Most likely, the rear drum bearing, a drum roller, or a drum slide has failed. Most models do not have all three types of drum support, usually one or two types. (Rear bearing with front sliders, rear rollers with front sliders, front and rear rollers, etc.)
Could possibly be a belt idler pulley or motor bearings, too.
You should diagnose and find the problem, before buying the parts.
Mar 05, 2017 | Dryers
NOISES DURING COPYING
open rear cover and check the fuser to see if there is wear on the heat roller, if there is a line worn in the roller and it makes a grinding noise,
it will need the fuser replaced, also it may need a firmware update.
Apr 02, 2014 | Copystar Kyocera Fs-1135 Mfp Multifunction...
Nordictrack 3700 makes a knocking sound when I run on it
Hello.
Knocking noises more than likely come from the rear roller, there could be a small chance it's coming from the motor it's self though.
Have some walk on the machine and make the noise while you locate which end of the treadmills coming from.
If it is the rear roller the bearings will need to be replaced, this can be done by removing the rear roller and taking it down to any bearing shop and have them locate the bearing numbers. Ask them for advise on removing them as well.
If the noise is coming from the front of the treadmill then have a look at the fly wheel coming off the motor, locate grub screws and tighten.
GymWorld.net.au
Jan 11, 2014 | Nordic Track Nordictrack Track E 3700...
Kenmore 86582800 drum has a high pitched squeak after been on for 5minutes. 1983 model
see this steps and fix it. God bless you
Drive Belt
If the dryer makes noise, the belt may be frayed or damaged. If the belt is damaged, it will make noise every time it travels around the pulleys. The drive belt is a long, narrow band that wraps around the entire drum, then around a tension pulley and the motor pulley.
er
Drum Roller
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers. If one is worn out replace all of them at the same time as a preventative measure.
Drum Roller Axle
Over time the drum roller axles can wear out, causing the rollers to wobble. If this happens the dryer makes noise. If the dryer is making a rumbling noise, check the rollers and axles. If any are worn out, replace them all at the same time.
Blower Wheel
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
Drum Bearing
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
Drum Support Roller & Axle
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers or axles may be worn out. After removing the drum from the dryer, inspect the rollers and axles. If one is worn out replace all of them at the same time as a preventative measure.
Drum Support Bearing
The drum support bearing is at the rear of the drum. If the dryer makes noise check this bearing. If it is worn out, replace the entire bearing.
Drum Slide, Glide, or Pad
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
Drive Motor
Although not very common, if the dryer makes noise the drive motor may be worn out and the motor bearings can become noisy. If this happens the drive motor must be replaced. The bearings are permanently sealed and cannot be lubricated.
Jul 13, 2013 | Dryers
Drum is making a knocking noise
it could be the rear drum bearing going out or the rear drum rollers going bad or the roller wheels beginning to flatspot or the front rollers in the same shape,you would need to remove the front cover on the unit by removing the lower kick panel screws,then remove the top cover and removing the drum belt,then remove the drum from the machine to examine all the above issues noted
Apr 27, 2010 | Kenmore 63942 Dryer
Dryer is making a very load almost vibrating or rumbling noise when operationg.
It sounds like the bearings on your rear rollers are bad I would need make and model to help you further. If its a maytag its almost definitely your rear rollers. hope this helps. MJ
Apr 14, 2010 | LG Dryers
Griding noise while spinning. the unit heats and spins but makes grinding noise as if the drum were off track
Hello Friend, Your problem is very simple to fix. You need to replace the Rear drum support rollers. To replace the Rear drum support rollers just remove front of dryer body exposing the drum, look under the drum and you will see the belt and tention wheel in front of the motor. Now, release the tention on the belt and remove belt from motor shaft. At this point you can remove the drum up and out of the dryer cabinet. Look towards the rear of the dryer cabinet and you will see the rear drum rollers. The roller on the left has a support strap held on by a press on clip. just pry this clip off and remove support bar. Now there will be a plactic triangular clip holding the roller in place. Just remove the plastic clip and replace roller. The roller on the right just has the triangle plastic clip just remove and replace that roller as well. Be sure to lubricate the roller shafts with some 3 in one oil prior to re-installing the new rollers. Make sure you re-install all of the retaining clips. After re-assymbly of your dryer if should run like new. Happy to help, Tim. And please don't forget to give me your rating for my help. Thanks.
Jun 28, 2009 | Whirlpool LEQ8000JQ Electric Dryer
My HP laserjet 1200 is making a terrible noise when printing - do you have to oil the rollers?
No Please don't oil any part of the printer, oiling may damage the complete printer first check if the nopise is coming from rear, Top, Front or side.
If noise is coming from Top than possibly top outbin roller are making noise.
If side tham may be toner cartridge or cartridge motor is making.
If noise is coming from rear than either fuser or the gear which rotates the fuser are making noise.
If noise is coming from from than Tray 2 pickup assembly or faulty tray is making noise possibly faulty registration assembly can also mak noise none of the part should be oiled only the faulty part should be replaced.
May 11, 2009 | HP LaserJet 1200 Printer
Golds Gym MAXX Crosswalk 650 Treadmill Rear Roller Logo
160 people viewed this question
Top Golds Gym Exercise & Fitness Experts
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Propulsive
Level 1 Expert
Are you a Golds Gym Exercise and Fitnes Expert? Answer questions, earn points and help others
