Question about Mongoose Exile 26 Men's Full-Suspension Mountain Bike
How do I loosen the front shocks on the mongoose ledge
Please i just bought a mongoose ledge 2,1 bike today and it became locked, how can i unlock?
I WOULD RETURN IT AND HAVE THEM UNLOCK WHATEVER IT IS THAT IS LOCKED, YOU NEVER SAY.
Nov 17, 2016 | Mongoose Cycling
What is a decent replacement rear derailleur for a Mongoose 26" Ledge 2.1 Mountain Bike?
Get the kind that has a lever shift instead of the grip shifter. The plastic part that holds the spring breaks easily. The lever shifter has been going strong on my bike for 6 years without a problem
Aug 31, 2016 | Mongoose 26" Ledge 2.1 Mens Mountain Bike
My chain is sliping on my26" Mongoose Ledge 2.2 Men's Mountain Bike
Its usually a bad freewheel. Its a complex operation to replace, contact local bike shop for assistance
Jul 15, 2014 | Cycling
Mongoose Ledge 2.1 pedal thread size
Measure the threads on the crank. Use or borow a pair of calipers. Measure with two threads as the outside edges to get proper diameter.
Apr 17, 2014 | Cycling
Mongoose mozo m30 forks are sponggy
Change the spring to your load.
Adjust Mozo M30 Fork Suspension - Beckman Du-70 Forum
efratoium.xyz/Adjust-Mozo-m30-fork-suspension/
Results 1 - 15 of 15 - Mongoose XR 150 mozo m30 front forks rebuild. A quick ...Mongoose mozo m30 forks are sponggy on my XR150 mongoose mountain bike.
mozo??- Mtbr.com
forums.mtbr.com/shocks-suspension/mozo-167281.html
Feb 20, 2006 - 15 posts - ‎6 authors
... of a mozo m30? is it the junk im assuming came on my mongoose? ... into a halfway decent bike. and all i can get off the fork is mozo m30 ...
Mongoose XR250 Suspension Upgrades ' Bicycling Magazine Forums
forums.bicycling.com/topic/54635607127666779
Sep 30, 2012 | Mongoose Exile 26 Men's Full-Suspension...
Bought a 26" Mongoose Detour
For the gear problem.Find the shifter.Use a pair of pliers and loosen the nut where the cable is passing through the shifter.Now withe the pliers pull the cable tight.Very tight.Spray the shifter with WD-40.That should fix it.
For the front rim,tighten all the spokes.Pliers will work,but a spoke too; will make the job faster.
May 16, 2011 | Mongoose Cycling
Hi I have a problem, I've just recently bought a new mountain bike from eBay. It's a mongoose, can you tell me how to tighten the suspension, so it's for road use not cross country. I deflated the air...
Since you've let the air out of the shock you need to go to a Bike Shop for a refill anyway because a normal pump doesn't reach the pressures supplied by a shock pump. While you're there, have them set the bike up for your preferences and instruct you in shock operation.
Aug 18, 2010 | Mongoose Exile 26 Men's Full-Suspension...
Adjust front suspension on a Mongoose XR-75
i dont think you can......because these bikes are made for confort at a cheap price..........
higher value bikes can be adjusted....they have special shocks and you can adjust on either soft or stiff ride.....
May 13, 2009 | Mongoose Exile 26 Men's Full-Suspension...
Mongoose Exile 26 Men's Full-Suspension Mountain Bike Logo
65 people viewed this question
Top Mongoose Cycling Experts
Michial Gueffroy
Jim Goldsmith
Jim Goldsmith
Rommel Balcita
Are you a Mongoose Cycling Expert? Answer questions, earn points and help others
