Stove oven door is locked - Washing Machines
  • 41 Answers
SOURCE: Oven Door Locked
the oven door does lock during self clean, otherwise it will not work. however, the door is supposed to unlock after the oven has cooled. if it is still locked, turn the oven to self clean and wait about a minute and then hit cancel and see if the door unlocks. if not, there may be a probelm with the door lock mechanism. Joe
Posted on Nov 18, 2008
aborcass
  • 2651 Answers
SOURCE: Frigidaire stove model gles388dsb
sounds as if there is a problem with the latch assy, there are 2 switches mounted on the latch mechanism for monitoring positon of hte switches, seems as if one has gone bad, not recognizing the door lock positon therfore continues to rotate without stop.part number for the motor latch assy w/switch and bracket 318095957 . located behind rear panel
Posted on Nov 24, 2008
SOURCE: GE Spectra XL44 Gas Oven, flashing "Locked Door". Can't use oven or close door
I had the same problem happen tonight. I have an XL44 self-cleaning gas range. We unplugged it for several minutes and pressed 'cancel' a bunch of times--neither worked. We finally lucked out--opened the oven door and pressed a black button on the upper left side of the front of the oven. It turned out the flashing words and unlocked our door. Weird. There was nothing in the manual about this...
Posted on Dec 28, 2008
  • 3 Answers
SOURCE: Maytag Oven Door is locked
I had the same problem.  Unplugging the oven didn't solve it, as the same "F9" message appeared when restarted.
Here's what worked:  start a cleaning cycle, and then hit cancel.  I leaned on the door just a little, the latch stopped making the "clicking" noise, and then the lock light turned off and the door opened.
Posted on Jan 30, 2009
philbran
  • 242 Answers
SOURCE: After using the self-clean cycle, display panel went black and oven door stayed locked.
Happens alot dont feel bad , self clean mode runs the elements at 500 deg. to cook off everything possible , what happens is the cabinet gets to hot and heats saftey temp. fuses until they go out and they are not resetable. they are always located in different areas of ranges but usaully in the back. you can ohm them out to check them if you have a meter.let me know if you have any other questions.
Phil
Posted on Apr 14, 2009
Power went out, now ovens are 'locked' - how to unlock?
I DO know the lower oven door can be released by lifting gently up and to the right, and a little 'joggling' will allow the door to be opened. It seems the lock latch swings to the (almost) locked position unpredictably and intermittently. I hate this @#$% stove. So does my wife.
The upper oven door has never seized. Upper oven has burned through several elements, and it's dangerous to replace. NEVER TRY ANYTHING WHEN CIRCUITS ARE STILL LIVE.
I hate thjis stove. I REALLY DO HATE IT.
Nov 08, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Frigidaire stove continuosly locks then unlocks
there is a small switch on the lock mech thats probly not making this is comon
Dec 25, 2009 | Frigidaire FEF336BC Electric Kitchen Range
F90 code flashing and i cant reset it
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%
Jul 07, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven Lock stuck open before start of self-cleaning cycle
Sounds like you bent the door where the lock is. You might have to replace the door.
Mar 12, 2009 | General Electric Stove/Oven/Range Chrome...
Oven door falling down on the Frigidaire stove
Try to replace the hinges the locking mechanism is going out
Feb 08, 2009 | Stoves 720EF Electric Double Oven
Jenn-Air stove locked
After the lock indicator light goes out, move the door lock lever to the left. The oven door can now be opened. Turn the selector and temperature knobs from clean to off AFTER THE DOOR IS UNLOCKED. If the temperature knob is turned to off BEFORE the door is unlocked, the door will not open. Forcing the lock will damage the lock mechanism. If this should happen, return the temperature knob back to CLEAN, unlock the door, THEN turn the temperature knob off. Source(s): Jenn-Air Grill Range with Self Cleaning Radiant Bake and Convection Oven models S136, S156, S161
Dec 10, 2008 | Ovens
Nov 24, 2008 | Frigidaire FEF336BC Electric Kitchen Range
OVEN DOOR LOCKED
IN THE CONTROL PANEL ON THE STOVE CLICK ON THE CANCELBUTTON AND LET THE STOVE COOL DOWN BEFORE YOU TRY TO OPEN.
Nov 02, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven door locked and stove wont work turned the oven on to self clean and it just blew cold air.It did not clean and now the door will not open Please help.
I woke up one morning recently with the oven door on "locked." The stove works, but the oven door will not open. As far as I know, nothing in the oven works. The "door" sign shows up on the window where the clock is.
Sep 19, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
