Question about Cub Cadet Garden
Turn key on clicks one time but will not turn motor over
Try to start turn key on- something clicks one time but motor will not turn over
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Cub Cadet Master
  • 1,917 Answers
Basd battery replace battery
Posted on Dec 17, 2014
`2005 Acura RL randomly wont start , key -on all works key to start -nothing dash lights stay on . even w/jump. Power start, sol. ,, starts right up . Next time you turn key=yes -no ? ? ?
lister for a clicking from the start motor you may need some to help you. if you or your friend hear the click on the starter motor then the motor and it does not turn the engine or goes crunch like its engaged but does not turn,It will need replacing or fixing, if no click this could be the starter relay or the ignition switch or you have a lose wire tot he relay.
Jul 11, 2017 | Acura Cars & Trucks
2005 Dodge Stratus R/T 3.0 Auto...No Start,No crank.
How many miles are on the beast? This vehicle has a timing belt and is an interference engine. If you have more then 60K on it and have never replaced the timing belt......well. There is the outside possibility that a broken timing belt could have occurred, causing other internal broken parts and possibly an engine lockup. Put a socket on the crank pulley bolt and try to manually turn the engine clockwise. If it turns, then things probably aren't too bad. It could just be a bad starter motor. If it won't turn clockwise, try counterclockwise. If something broke and jammed the pistons, this may allow it to break free. If this works, DO NOT TRY TO START THE CAR! Something is wrong inside the motor and trying to crank or start it will just make things worse.
Mar 20, 2015 | 2005 Dodge Stratus
Why Craftsman riding mower wont turn over & only makes click sound when turn key on??
1.try jumping the battery with your car battery. I have had same issue in the past with a brand new battery.
2. Try spraying starter fluid into the carb while cranking. If it starts or at least tries to start (assuming cranking is fixed), you have a fuel problem. Again, when I first tried to fire my Used mower, had to use starter fluid to get it to start the first time, but never since.
Jun 19, 2014 | Craftsman Garden
Will not start, battery is new, it just clicks and nothing. turn it off, try again and nothing, try again and it starts
Try cleaning and tightening well the battery connections along with the battery wires to the solenoid and starter motor.
Bad connections and low voltage of 12 volts can result in this anomaly.
Jun 12, 2017 | 1997 Lexus ES 300
Clicking sound until key is inserted
Tri and cycle the key 2 times in the driver door lock Make sure you have good batery voltage at least 10 volts
Jan 16, 2013 | 1999 Lexus RX 300
I have a 2003 N16 Nissan Pulsar sedan, 1.8L vehicle. Sometimes, when I insert my car keys into the ignition, and switch the car on, it doesnt start, and the car is making noises (trying to "rev"), but the...
Hi Kelly,
sounds like your battery is a bit sick. Or it could be the starter motor solenoid sticking.
The click you are hearing is probably the starter motor solenoid. If you hear a series of loud clicking its usually due to a flat battery in which case you need a jump start from another car.
If you can get someone to charge up your battery using a portable charger and the car starts OK, its a fair bet your battery is on it's way out. You can get your battery tested at any large reputable auto repair shop.
If the battery is OK, the solenoid can get stuck on your starter motor. Often a light tap with a rubber or wooden mallet can free up a stuck solenoid, but ultimately you will need a new starter motor. (BTW The solenoid is the smaller bit attached to your starter motor. There will be heavy wires attached to it) Have a look at link 1 below for more info.
Have a look here for some info to help you understand your starter circuit:
http://www.samarins.com/glossary/starter.html
or
http://www.caradvice.com.au/37/car-doesnt-start-engine-doesnt-start/
or
http://www.ehow.co.uk/video_5225934_diagnose-bad-starter-motor.html
Regards, Steve
PS Feel free to vote for my answer or give a testimonial if I have helped.
Oct 19, 2010 | 1990 Nissan Pulsar
My 2005 Polaris 500 H.O. will not power up. The batery is good, there is just nothing when I turn the key. I don't even know where to start looking! Please help, I need my machine! Thanks. Steve
Its probably the electronic control module. Try leaving the key on for a while, if you do start to get something and it comes and goes, its the ECM. I had the same problem with my 07 EFI 500.
Aug 24, 2010 | Polaris ATV
Electrical problem i think, wen i went 2 started it it wouldnt
i would get a friend to tap on startermotor body with a shifter or something and if car starts when being tapped by friend and you turn key,you need to get startermotor looked at or new one..
Mar 02, 2009 | 1991 Daihatsu Rocky
Garden Logo
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
