Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
Chlorine My salt cell is not making chlorine. I have changed the sensor, cleaned the cell, and checked the voltage getting next to no reading. What should I replace?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Jandy Master
  • 1,448 Answers
Change cell
Posted on Nov 06, 2014
3 Suggested Answers
PartsCenter
  • 125 Answers
SOURCE: Have a Jandy aqualink clorinator.
link to the Trouble Shooting Guide
Posted on Mar 04, 2009
SOURCE: Aqualink Chlorine Generator not producing any chlorine
It shounds like that you might have a mustard algae issue. It feeds on chlorine. It is possible that your unit is producing chlorine but the algae is consuming it as fast as it can be made. You will need to do a shock treatment and use an Algae 30. It could be something else, but this is likely. You can google mustard algate treatments and read up on it to see if you have other symptoms.
Posted on Aug 04, 2009
No flow is red and no chlorine lights indicating chlorine
I assume you are describing a salt system.
Ensure all baskets are cleaned out, filter is clean and proper flow of water.
Check salt cell for calcium buildup.
Beyond that it could need a flow sensor replaced.
Feb 26, 2015 | Pool & Spa
Hayward Aqua Rite Not showing salt and temp readings
see if voltage from transformer if ok bad control board or sensor
Jul 09, 2012 | Hayward Pool Products Hayward Aqua Rite...
Why would our salt water system not be producing chlorine? Intex it was installed less than a month ago. to a very green pool we have put in chemicals and gotten it pretty well cleaned but its still is...
first crack union at return see if chlorine present with test strip if ok then pool needs super chlorination its eating up your chlorine if no chlorine at return have salt level checked if ok check sensor and cell if unit is working must keep balanced unit will only maintain
Dec 25, 2017 | Intex Automatic Salt Water System for ...
No chlorine registering; plates need cleaned every few days
The recommended amount of salt is just a guide> You say yours is ideal
would that be 3000ppm and are you using test strips for salt that are 3 reading or color reading
Go with # reading they are most accurate any lower than 2800ppm and you will not generate enough chlorine and could trigger low salt code any higher than 3500 and it will taste bad and could trigger high salt alarm
when adjusting salt you need to filter only for 24 hours before trying to generate chlorine
I have never cleaned my electro cell
other chemicals should include a non foaming algaecide once a week follow direction for your gallons of water
Also chlorine stabilizer once a month or so depending on conditions this helps hold the chlorine level
and a water clarifier this helps the minute particals clump together thus being possible for the paper filter to catch it.
The paper cartriges let to much small debris through that you cant see
The key to using an intex system is filter filter filter if you do not filter enough you will next go green and that is a nightmare
Have 2 filters so that while one is being used the other has been blasted out with a garden hose and drying An inserted dry filter works better than a freshly cleaned wet one
I have had the same 2 filters for this being my 4th season
I run mine 24/7 it is like keeping a 40 watt bulb on
Jul 09, 2010 | Intex Automatic Salt Water System for ...
Intex chlorine generator no working
check sensor if ok cell or check voltage to cell
Jun 14, 2017 | Intex Automatic Salt Water System for ...
Intex salt water chlorinator not producting chlorine
You can test if the 8110 is generating any chlorine by taking a water sample directly at the pool return. You can invert your container so it stays filled with air until you have it positioned in front of your return. Make sure your test chemicals are not expired and test the sample. You should get a high reading if the 8110 is producing any chlorine. If it is producing chlorine, you may want to make sure you have the correct level of Cyanuric Acid. In my pool, if the Cyanuric Acid level is low, the chlorine level drops to zero quite quickly.
If the sample indicated your 8110 is not producing any chlorine, I would check to see if you have approx. 24V DC between B+ and Gnd on the screw terminal strip on the main circuit board. The transformer supplies two voltages to the 8110. One voltage powers the electronics and the other powers the electrolytic circuit. So it is possible for part of the unit to work if one voltage has failed.
Jul 03, 2009 | Intex Automatic Salt Water System for ...
No chlorine reading
Salt is sodium chloride, you can only measure salt levels now as your CL (cloride) is bound to a NA (sodium). Table salt =NACL, Your Intex system will tell you if your salt level is too high or too low but your old test equipment for free chlorine will continue to tell you no chlorine as it can't react with the chloride any longer as it is bound to the salt. That is why they tell you you never have to add more because the salt stabilizes it. Your chlorine is there it's bound to the salt. Use the pool it's fine and it makes your water feel really soft! Just keep the salt level right and your fine> It's confusing as they call the unit a chlorine generator! I had the same issue, called Intex and they told me the above.
Jun 01, 2009 | Intex Automatic Salt Water System for ...
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
152 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
