Question about Uniden DECT 6.0 Cordless Phone
Base not charging - Uniden DECT 6.0 Cordless Phone
My charging base is not charging my motorola T5950 2 way, as no lights come on. what are the numbers 03192-0091835 can i use another drop in base with different number to charge ni-cd battery packs?
You may be able to use a different base to charge the battery but chances are you may not be able to use the base with the phone since the base electronics are matched to those of the original phone and they will not match up.
Aug 26, 2017 | Motorola Radio Communications
Hi i have a uniden ZO68 i want to add another hand set to this i have brought another uniden ZO68 second hand hand set and i can't set it up can you help me please
did you get the charging base with the hand set
is it a charging base or a base station base
if it is just a charging base , follow the instructions as how to get the base station to recognize the next phone
if it is a base station, probably won't work as you will have 2 base stations trying to work and that will create conflicts
talk with a telephone technician to see what can be done
Oct 30, 2016 | Uniden Lands Phones
My panasonic landline phone is not charging on the small base
Use a pencil eraser to clean the contacts. Check your battery, as if it is bad it will not charge even if the charging base is providing the electricity it needs.
Mar 23, 2015 | Panasonic Lands Phones
Why did my Panasonic phone quit charging in base unit?
Check the condition of the charge contact tips in the phone cradle, there are uaually two or three spring loaded pins that contact the phone charge contacts. Make sure these are clean and the springs still work. If these are good, you can check the output of the charger with a volt meter at the spring loaded pins, you can get the correct voltage off of one of the satellite units and compare it to the base. If the base is not putting out the same voltage the charger has likely failed.
Feb 27, 2012 | Panasonic Lands Phones
Base unit not charging phone
hi,
if the base unit is not charging phone,did you test it with another phone to confirm if the base unit is working?
if after doing this and the base unit is working confirm if the d.c. power is okay, because if the current is low, the base unit will not charge the phone.
if after doing all these and the phone is still not charging, then, your charging port is bad.
you have to replace the charging port with a good one.
the charging port is the place where the base unit will enter.
i hope i have answered your question correctly?
thanks for using fixya
Jun 08, 2010 | Lands Phones
Charging problem
The fact that one charges on all 3 base units rules out any problem on the base units. Sounds like the batteries on the 2 faulty handsets need to be replaced. I suggest you return it to the store, and get yuh money back, or replacement
Dec 10, 2009 | Uniden Cordless Phone
VTech 2651 base (2.4GHz) +3 phones - base not charging, has power
email me, i may have a bbase for you, put vetech phone base in the subject line. thanks
tim
my email tpmtpm@aol.com
Nov 04, 2009 | Vtech Lands Phones
Remote control could not be charged at its base
I have the same remote. Clean the contacts on both the remote and the charger base. Then place the remote in the charger. If it does not start charging, wiggle the remote back and forth in the base while pushing down gently. It should begin charging. I have found I must clean the charging contacts every few months.
David
Mar 26, 2009 | Logitech Harmony 880 LCD Remote Control
Panasonic KX-TGA101S base not charging.
Here are a couple things you can try.
Clean the charging contacts, this can be done two ways. The manufacture's recommend using a pencil eraser. I recomend using a q-tip and some rubbing alchol. Just rub the alchol soaked q-tip on all the metal contacts on the bases and the bottom of the handset.
Gooo luck.
Hope this helps
Mar 12, 2008 | Panasonic KX-TG5632 Phone
Base won't charge handset
the base of your handset needs to be repair take it to a tech
Apr 04, 2007 | GE 26938GE1 Cordless Phone
Uniden DECT 6.0 Cordless Phone Logo
19 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
