Kazuma meerkat 50cc manual
Where are the timing marks on a kazuma 50?
4 Suggested Answers
ryan_18_2k10
SOURCE: Looking for a owners manual for a kazuma meerkat 50
What do you call the wires u Attach to the battery on a 50cc Meerkat Quad - it has the 2 rings on the end - WHAT ARE THEY CALLED WHATS THE PROPPER NAME FOR THEM
Posted on Dec 26, 2012
SOURCE: the gas leeks from the overflow on my kazuma
Strip the carb down take the the float bowl off remove the float and its fork and the little tapered needle out then look in the hole where u took it out of see if they is any dirt also give the needles a clean
Posted on Aug 28, 2013
gopakumarg43
  • 73710 Answers
SOURCE: Has anyone got spare manuals for kazuma meerkat
Kazuma Meerkat ATV Owners Manual Try this link to download the manual. Electro help
Posted on Jun 06, 2014
Hi folk ! My problem is. I put a new starter motor on my kazuma meerkat 50, I think it was made in 2003. So when I press the little button to make it start it just make a clicking sound but it not really...
Normally, that clicking sound coming from your starter, because your battery don't have the charge to turn the starter over. The clicking sound your hearing happens every time you start it, just usually goes unnoticed because the starter itself is louder. The clicking sound is the solenoid engaging, which is a good thing. But otherwise if you have already tried jumping it(I mean jump it your battery could be bad) you may just have a loss wire, bad starter, or a bad battery. I have got Brand New Starters that where bad, it don't happen often but it does happen.
But odds are, your battery is dead or bad
Good luck! Hope this helps!!!
Jun 06, 2014 | Motorcycles
The gas leeks from the overflow on my kazuma meerkat 50cc atv
Aug 28, 2013 | Motorcycles
My 50cc Meerkat kazuma Quad does not have enough compression to start. it's at about 30psi?
Sounds like you need to replace the carb reed. you will know by checking if there is air blowing out of the carb when you crank it over. There should be nothing coming back out. if this is not the case you need to replace the piston rings.
Aug 26, 2013 | Quad 47 cc / 49 cc Pocket Mini Bike...
i have just got a kuzma meerkat 50cc av cleaned all the carb out washed the tank cleaned all the pipes thers a spark but it still wont turn over the only time it will run is wen a pour petrol in the carb from the top into were the pin coz in the carb eny idears eny help or idears wiil be most welcome
Aug 18, 2012 | Cycling
Hi, bought my son a kazuma meerkat quad 50cc 2010 model electric start, unable to start the quad with the electric start? when ignition on & start button pressed selonoid clicks once & a sometimes...
I had the same problem. My positive wire would arc with the key off when connecting the battery showing a short somewhere. I disconnected the regulator/ rectifier, (where the #16 positive lead from the battery goes to), and it quit. I found a new one on e-bay for $9.90 after shipping and it corrected the problem. Check to make sure your positive is not arcing with the key off. Hope this helps.
Dec 15, 2010 | Quad 47 cc / 49 cc Pocket Mini Bike...
On a kazuma 50cc engine carb adj screw location
The lower of the 2 screws is the fuel/ air mixture- the upper screw is the idle adjust screw
Jan 22, 2010 | Quad 47 cc / 49 cc Pocket Mini Bike...
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
